Dishwashers Logo
A
Anonymous Posted on Nov 27, 2013
Owners manual power winch 603
Owners manual
The winch pulls in powerfully all the time irregardless of winch lever position.
Bad electrical control system. A kind of voltage regulator. Id try to get a repair manual. Or you may find part numbers in owner's manual if not available, try manualslib.com A starter alternator repair shop may be able to help.
2answers
KFI winch won't spool in or out there is power to it I can hear it clicking
If your wiring a remote control to the winch or inside control,,, 4 solinoids type,,make sure the solinoids have ground on the brown wire(warn)...if you don't have a ground all it will do is click,,,even if power is applyed
Winch won't wind in
Bad ground or check the power to the winch if it has power the motor went bad
Motorcycle dies when you turn key to turn on lights. Could this be a problem in the wiring, or a bad lighting coil?
My issue with a quad i owned had the same issue. The prior owner added a winch and attached the power wire to the lights. When i turned the lights on it turned off unless i gave it some gas while turning the lights on. I disconnected the winch and i was ok. Is the fuse proper amp, bad ground or any new electrical additions? I would take a meter reader and start checking where the power source comes in and goes out like a regulator.
Wire diagram for 9' ATV Rocker Winch Handle Bar Mount Remote Control Thu to the winch
Here's the owner's manual - it includes wiring & installation information:
http://mediacdn.shopatron.com/media/mfg/4377/media_document/4398/10991.pdf
If you're looking for information that is not provided in the manual, you should contact Superwinch directly:
In the USA:
Superwinch, Inc.
Winch Drive
Putnam, CT 06260
U.S.A.
Tel: (860) 928-7787
Fax: (860) 963-0811
e-mail: [email protected]
Elsewhere:
Superwinch, Inc.
Unit D, Union Mine Road
Pitts Cleave Ind Est
Tavistock, Devon
PL19 OPW England
Tel: 44 (0) 1822 619222
Fax: 44 (0) 1822 615204
I hope this helps & good luck!
2helpful
Spare tire tools
From the owner's manual for that model, see link below also, page 299 of the PDF has a nice picture.
Spare Tire Removal
Fit the jack handle extension over the drive nut. Use the
Lug Wrench to rotate the nut counter clockwise until the
spare is on the ground with enough slack in the cable to
allow to pull the tire out from under the vehicle.
CAUTION!
The winch mechanism is designed for use with the
jack extension tube only. Use of an air wrench or
other power tools is not recommended and can
damage the winch.
When the spare is clear, tilt the retainer at the end of the
cable and pull it through the center of the wheel.
http://www.jeep.com/en/owners/manuals/index.html?year=2006&nameplate=Grand%20Cherokee
Top Dishwashers Experts
Mike Cairns
Mike Cairns
john h
