Question about Canon PIXMA iP3000 InkJet Photo Printer
Canon Pixma ip3000
Ink carriage will not go back to docking station.
Ink carriage can only be moved to where it is put by hand positioning.
I was using excessive ink and tried to clean the pads on the right side below the ink carriage docking station.
Now, there is a white flatish moulding 'Maybe a trip switch' that slides 'from front to back' that is staying towards the front.
I think this white moulding should be settled towards the back of the printer.
Is there a return spring for this white moulding?
Have taken all the ink cartirages out and gently cleaned many times.
This is the first time it has happenned.
[email protected]
Green orange lights flash.
Error 6A00 comes up.
    Genius:
  • 1,601 Answers
The code strip is the plastic strip that runs across the printer and through the head
carriage, it is supported at each end (one end under spring tension).
If it has become dislodged it will cause this problem. carefully try to place it back into place
Posted on Nov 19, 2007
  • Thomas Christopher
    Thomas Christopher Nov 19, 2007
    "AP position error [6A00]", which indicates that the Sheet
    feed unit.
    If your still under warranty, canon does give you the option to deal
    with an authorized repair shop, or sending you a referb unit. A new
    head will likely not solve the problem as we are dealing with the guts
    of the printer, feeder or the brains. Whether or not the local repair
    shop will "fix" it or get you a referb is something I don't know, nor
    do I think they would know until such time as they looked at it.
SOURCE:
Error code 6A00
Step by Step troubleshooting canon pixma MP800 error code 6A00
The Problem Canon PIXMA MP800 Error 6A00
1. The print head cartridge keeps locking itself up on the right hand side.
2. Frequent 5100 errors even when the printer is on standby
3. Even when I wipe up the print cartridge, the next print will
mess up the bottom of the print cartridge with ink again.
Step for troubleshooting canon pixma MP800
1. Opening the cover and wait for ink carriage to center
2. Pull out power cord
3. Pushed carriage to far left (should slide easily)
4. Used paper towel and wiped purge unit a lot of times
(press down to soak paper towel with ink). Repeat until the paper towel is relatively clear.
5. Used diluted napisan (oxygen-based cleaning agent in the
ratio of 1:3 with powder:water) and soaked paper towel
6. Repeat step 4 with wet paper towel. Repeat until purge unit is near-white.
7. Pulled and pushed clear plastic wiper (north of purge unit) and wiped it down
8. Slided carriage back to original position
9. Removed Print head cartridge and wiped out excess ink stuck on bottom.
Mar 01, 2011 | Canon PIXMA MP800R All-In-One InkJet...
Error code 6A00
Hope this helps.
Feb 10, 2011 | Canon Pixma MP800 All-In-One InkJet...
Cannon PIXMA iP3000 (Waste ink absorber full)
The waste ink absorber is a pair of pads at the edges of the ink carriage path near the bottom of the printer. Canon will sell you a new set to replace them if you want to d-i-y. Alternatively, you can just rinse the pads until the water runs clean once you open up the printer. Dry the pads well before reinstalling. You need to take the printer apart from the top and get under the ink carriage.
Once you reinstall the pads, you can reset the counter by:
Pixma IP3000
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal.
I hope this helps.
(most inkjets waste ink counters are set to hit their fill point at the expected end-of-life of the printer. Additional failures may happen soon.)
May 21, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
Pixma MP610 will not start up. Was working OK. Just under 1 year old. Printer detected by computer, and print carriage lifts, but will not move. Ink in all the cartridges Front lights blinking alternately...
6A00 indicates a problem with the carriage lifting mechanism. Simply put there is beam kind of thing that the cartridge carriage assembly on which the print head rides on and something on it is obstructing the carriage assembly. The fix? Open the printhead cover and turn on the printer. You will see that the carriage arm is extended and tries to move back to the initial printing position but it can't. Just give it a little helping hand and bingo! The print head moves to the correct position. You will then have to clean up whatever is blocking its path. Usual culprits being ink, paperclips, tiny bits of popcorn(or anything else you prefer eating while printing!:)
Let me know if you need more help,
Sai.
Jan 03, 2010 | Canon Office Equipment & Supplies
How to replace canon print head printer ip90
After you open the cover and the carriage comes to the center for new ink, you press the resume button for a few seconds and the carriage will go to the printhead changing position. You don't want to ever force the printhead to move. Hope you didn't break something already. Sorry for the stupid help.
Oct 04, 2009 | Canon PIXMA iP90 Mobile Printer
Canon IP3000 unkown part..
the images do not exist on the url submitted
Jun 20, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
I need help with installing ink
Open the front cover when the printer is turned on, wait until the ink tanks move to the change position. push the clip on front of each tank in and lift the tank up. take the tape off the new tank cartridge if it has one (only if it says to remove it) put the cartridge in and press down until it clips. close the front cover and the ink will return to its normal place and initialize
Jun 16, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Pixma mp210 problem
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
546
Jan 10, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon Computer Pixma printer ip3000
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Oct 11, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Canon PIXMA iP3000 InkJet Photo Printer Logo
272 people viewed this question
Clive
Clive
old marine
old marine
Ekse
