Question about Kenmore Ovens
I have a brand new kenmore oven. I did not realize that the burner is under the bottom of the oven. I put an aluminum drip pan on the bottom of the oven and turned it on for the first time. The pan is now melted to the bottom of the oven! Help!
    Top Expert:
  • Kenmore Master
  • 36,467 Answers
You may be able to scrape off the remains of the pan but you must be careful to avoid damaging the oven lining. The alternative is to buy a new oven.
Posted on Nov 27, 2013
2 Suggested Answers
SOURCE: aluminum foil stuck to new oven bottom - how to remove
(Wear a professional n95 mask and rubber gloves). Use a straight razor and scrape off as much foil as possible. Get a hold of Mercuric or sulfuric acid. BE CAREFUL not to spill anywhere, work close to a stainless steal sink. Poor a little in a small glass container and bring over stove porcelain surface. Pour the acid onto the foil and wait 3-4 minutes, use paper towel to wipe off the acid, and then a soapy wet rag. Repeat process until all foil is dissolved. Then wash surface thoroughly and repeatedly with a soapy dish towel. Once complete run water in the sink for 5 minutes till any possible remaining accid is flushed from the sink. The foil is gone and the porcelain is preserved. Works great! (Don't breathe the fumes and ventelate the area or move the stove outside)
Posted on May 27, 2009
Does a GE Profile double oven have a removable bottom pan
It says right in the owner's manual not to use aluminum foil on the bottom of the oven. Try to remove it with steel wool...
Aug 29, 2016 | GE Ovens
Tip
Electric Oven Problems - What not to Use in Your Electric Oven
If you have an electric oven, there is one thing that you do not want to do. It does not matter if you have a wall electric oven, a wall double electric oven, or a freestanding electric oven. If the heating element in your oven is electric you do not want to do this.
After normal use of your oven the broiler pan, the oven racks, and the drip pans in the bottom of the oven can become soiled to the point where they will not clean properly anymore. Many people try to make the inside of their oven “look” better and give it a cleaner look by wrapping or covering these things with aluminum foil.
While this may give the oven a good clean look it also creates a problem for you and your oven. Aluminum foil is highly conductive and will “short” the electric elements in your oven if it comes in contact with them. This short means that the electricity will flow through the element and out of it at one point in an uncontrolled manner. This will cause a surge through the element to that point, which will cause the element to fail.
What many people also fail to realize is that the foil they wrap around these thing can move as the oven heats and cools. So even though the foil is far away from the element when you wrap it on, it can move till it comes in contact with the element and then in a moment it is too late to correct.
It has also come to my attention that some people may use aluminum pans in the bottom of the oven to catch any spillover that may happen. In my opinion that is just as bad as the foil wrap. These pans will warp with the heating and cooling also. If you can get a pan on the bottom rack and your food on the top rack, then you are good... the aluminum cannot get to the element in anyway...
If you have racks, pans, or other things in your oven that are too dirty and bother you…you are better off to buy new rather then take the chance on ruining your day in a flash.
http://www.fixya.com/support/r4388324-oven_fault_codes_ge_xl44_oven
http://www.fixya.com/support/r4391163-range_stove_oven_door_glass_replacement
http://www.fixya.com/support/r4404788-electric_oven_problem_oven_will_not_shut
http://www.fixya.com/support/r4319588-electric_oven_problems_not_use_in
http://www.fixya.com/support/r4154940-fault_codes_admiral_range_stove_oven
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
on Mar 12, 2010 | Ovens
Did not realize that burner was under the bottom of stove. Put in an aluminum drip pan on the bottom and turned ove n on for the first time. The pan is now melted to the bottom of my brand new oven. ...
Can you see that the pan has actually melted, or is it just stuck? Aluminum melts at over a thousand degrees, an oven only gets half that hot.
Try to pry it up with a putty knife.
Worse case scenario would be sanding it out with a rotary power sander after cutting as much out as possible with tin snips.
Nov 27, 2013 | Kenmore Ovens
My new oven has melted the tin foil onto the bottom of the oven that I put to catch cake drips. I don't know how to get it off as it has adhered. The smell right from the start of the oven and during my...
With the older models of self-cleaning ovens one could put aluminum foil on the bottom tray of the oven, but with the newer models there is a warning (hidden in the last line) of your booklet for models of stoves where aluminum foil should 'not' be used! Even though print in small and many consumers are complaining regarding their stoves and melted aluminum stuck to the bottom tray of their oven (nothing will get it off) all manufacturer do 'not' cover this problem under warranty and thus, it will cost you $44 to buy a new tray. You unscrew the two screws to the bottom of the damaged tray of your oven and then install the new one and put back the screws. Letters of complaint should be written to the manufacturers to have them put this warning in clear bold print right on the front cover of the instruction brochure.
Jan 20, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
I don't have a Kenmore I have a Fridgidare and I have burned on foil on the bottom and cannot remove it. It is a self cleaning overn and I am afraid to turn it on??? I have tried scrapping, soaking, but...
With the older models of self-cleaning ovens one could put aluminum foil on the bottom tray of the oven, but with the newer models there is a warning (hidden in the last line) of your booklet for models of stoves where aluminum foil should 'not' be used! Even though print in small and many consumers are complaining regarding their stoves and melted aluminum stuck to the bottom tray of their oven (nothing will get it off) all manufacturer do 'not' cover this problem under warranty and thus, it will cost you money to buy a new tray. You unscrew the two screws to the bottom of the damaged tray of your oven and then install the new one and put back the screws. Letters of complaint should be written to the manufacturers to have them put this warning in clear bold print right on the front cover of the instruction brochure.
Apr 26, 2010 | Kenmore 33169 Gas Single Oven
How do i get an aluminum foil pan stuck from the
You may be able to get it opff with the oven hot. Whatever is holding it was liquid when hot before, so should at least loosen enough for you to remove it.
Nov 04, 2009 | Kenmore 47783 Electric Single Oven
How do I remove aluminum foil from the bottom of my oven? I have a brand new Kenmore wall oven that I have only used once. I had put a piece of foil on the bottom in case there were any drips. it baked on...
To all those who think this problem description couldn't be true, you're wrong. You're right that the aluminum did not get hot enough to melt though.....What happens is that the non-stick teflon coating they put on the aluminum get's too hot and bonds with the oven bottom.... like a crazy epoxy!
Furthermore, this isn't a problem in older, conventional-type ovens... this is moreso a problem with ovens that have a hidden bottom element.... The bottom element is actually directly below the oven bottom, and lining the oven bottom with foil is basically like putting it directly on the element. And that part gets extremely HOT!!!
Thankfully I've got the solution to this! But it takes some extreme patience, a lot of respect for what you're working with and some good ventilation.
I went back to my high school chemistry class to get the answer. It's Lye, aka Caustic Soda aka, Sodium Hydroxide.
I used Drano Kitchen Crystals off the shelf of the grocery store..it's about 70% lye with some added salts to aid the chemical reaction.
You'll need some plasticene, the drano, water, GLOVES!!, a lot of paper towels and wood skewers and GOOD VENTILATION.
Start the ventilation and open a window or door.
Put on your gloves.
Use the plasticene to create a dam about .25"-.5" high around the area in the oven you're looking to remove the aluminum from... the area's you're working in should be about 2.5" in diameter.
Pour in some of the drano into the dam and add enough water to touch all the sides of the dam......if the chemical reaction hasn't started (should be almost instant) keep adding the drano bit by bit until it does... the dam contents will start to boil and ammonia fumes and a little hydrogen gas will form....... hence the need for some good ventilation!!
Once the reaction is done, poke around with the wood skewer to see if the oven bottom is clear... if you're satisfied with the results, add some some vinegar in to help neutralize the solution a bit.... then use the wood skewer to remove the plasticene dam to a dish to be rinsed off ASAP.
Use paper towels to wipe up the mess on the bottom of the oven.... See your results! the area of the oven botton you treated should be free of aluminum and just be discoloured instead..... not from the drano, but from where the teflon bonded.
Repeat the process until the oven bottom is clean.
To get a 'feel' for the chemical reaction and what to expect, experiment first!... take a square of aluminum foil, go to the backyard with the foil shaped in a littlebowl and place it on a dish or pan, add some drano crystals to it then add a little water... step back from the dish and try not to breath the fumes!.. the dish will be hot!!
It took me about 6 hr to clean the bottom of my oven when this happened to me.
Hopefully this helps some other poor unfortunate souls who finds themselves in this situation!
Oct 15, 2009 | Kenmore Ovens
Aluminum foil stuck to new oven bottom - how to remove
Jan 20, 2009 | Kenmore 47783 Electric Single Oven
Melted Tin Foil in bottom of oven
Unfortunately, it's too late. The tin foil has melted into the panel and can't be removed. The melted foil will not affect oven operation. You should never place anything on the bottom of a stove that has a hidden element. You will damage the panel. The only option you have is to replace the panel (if replaceable) or the entire oven liner...
Jun 05, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Use "The Works Toilet Bowl Cleaner" to dissolve the foil. *Caution* when the cleaner is applied to the foil a chemical reaction occurs releasing some harmful fumes so please use outside or in a well ventilated area. I just did this to a Frigidaire oven I bought from Lowes at a discounted price. The previous owners bought it, did not read the owners manual or just disregarded the warnings on using foil in the oven and thought they would line the bottom pan with foil to help make it easier to clean (Good idea, but don't try it on the hidden element ovens). With the heating element being hidden under the drip pan the heat is hot enough to melt the foil and fuse it to the pan. Now most of the pans on these ovens are removable by just a couple of screws and I strongly recommend removing the pan when doing this. Squirt some Works toilet bowl cleaner on it in a well ventilated area and watch it go to work. It took about 15 minutes for it to dissolve all the foil on my oven, then I rinsed it clean and reinstalled it in the oven. The pan does have a slight discoloration on it, not from the cleaner but from the foil being melted onto the pan, if you choose you can buff this out. Most of the modern ovens have the ceramic coated drip pans in them so the Works toilet bowl cleaner will not harm them, unless you have scratched the finish off. Works Toilet bowl cleaner contains a fair amount of hydrochloric acid which is what makes this work so well.
Oct 23, 2007 | Kenmore 33169 Gas Single Oven
Ovens Logo
73 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
