Question about Alcatel Sparq OT-606a T-Mobile Unlocked GSM Qwerty Slider Cell Phone
Turn off airplane mode
Airplane modeis on i want it off
Irola tablet stuck in airplane mode.can't turn off airplane mode
You have to do a hard reset its not seing your sim card ask me how if you don't know how
Jan 29, 2016 | Cell Phones
After installing Windows 10, why won't airplane mode turn off and wifi is limited?
How to turn on or off Airplane Mode in Windows 10
Option 1:
1. Open Action Center (Windows Key + A)
2. Click/tap on the Airplane mode quick action button to toggle on or off.
Option 2:
1. Click/tap on the network icon in the taskbar notification area.
2. Click/tap on the Airplane mode button to toggle on or off.
Option 3:
1. Open Settings, and click/tap on the Network & Internet icon.
2. Click/tap on Airplane mode on the left side, and turn on or off Airplane mode on the right side.
3. When finished, you can close Settings if you like.
Airplane mode issues can be of different ways. One might be unable to turn off the airplane mode as its toggle indicates the function is unavailable for the time being. Few users might not be able to activate the wireless connections as they are not willingly glued to the Airplane mode. And there are situations where Airplane Mode turns on automatically refusing other wireless devices to perform correctly. So, we provide you different solutions to try for the above mentioned Airplane Mode issues. So, let us head towards the main topic and see How to Fix Airplane Mode Issues in Windows 10.
How to Fix Airplane mode not turning off in Windows 10:
Solution 1: Change Network Adapter Properties
1. search for Device Manager in Start Menu or Cortana and open it.
2. Make your way to the Network Adapter section and expand it by double-clicking on it.
airplane-mode-turn-off-after-installing-qxiko4mbhn3xwpbyjhiay14v-2-0.png 3. Figure out your wireless modem from the available list and right click on it to navigate to its Properties.
airplane-mode-turn-off-after-installing-qxiko4mbhn3xwpbyjhiay14v-2-2.png 4. This launches the Properties dialog box of your adapter. Hit on the Power Management tab. Clear off the option that saysAllow the computer to turn off this device to save power.
airplane-mode-turn-off-after-installing-qxiko4mbhn3xwpbyjhiay14v-2-5.png 5. To apply the changes, press Ok button. This will Fix Airplane mode not turning off issue in Windows 10 and resume its slider to be turned off.
Check the other solutions here Airplane mode not turning off in windows 10 Fixed
Aug 15, 2015 | Lenovo Computers & Internet
How do I turn OFF airplane mode on kindle fire?
From the home wage swipe down with finger from the top of your kindle then select "wireless." You will see airplane mode on/off on the right. Select the option you want.
Feb 22, 2015 | Amazon Kindle Fire HD
Why cant i turn off airplane mode on a huawei m920
You can simply turn off or disable airplane mode by following these steps:
1. Press the Application Icon.
2. Then, click Settings and choose More.
3. Next, tap Airplane Mode to change the settings. Make it sure you`ve Unchecked Airplane Mode.
4. You can now go back to the Home Screen by clicking the Home Key.
Jul 06, 2014 | Huawei Cell Phones
Airplane mode
I presume you have a Windows 8 operating system.
1. Press [Windows Key] + Q key.
2. Type "airplane" in the Search box,
3. Click the "Settings" (it is found in here)
4. The "Turn Airplane mode on or off" note will be displayed; click it.
5. PC Settings screen with airplane mode slider will be displayed,
6. Slide the Airplane mode slider to off.
Mar 09, 2014 | HP Compaq Presario V6000T 15.4" Notebook...
Remove flight mode
Turn on / off Airplane mode
Airplane mode turns off the wireless radio. This allows you to use programs while travelling on an airplane, but not make or receive calls.
To turn on airplane mode, follow these steps:
  1. From the Home screen, select Go to.
  2. Scroll to and select Profiles.
  3. Scroll to and select Flight.
  4. Select Activate.
To turn off airplane mode, follow these steps:
  3. Scroll to and select Normal (or a profile other than Flight.)
  4. Select Activate.
Jan 04, 2014 | Nokia Lands Phones
How do i get my computer out of airplane mode
To turn Airplane mode off, press the Windows + I keys to open Settings, and then click the airplane mode icon. Move the airplane mode slider to Off .
Nov 12, 2013 | Computers & Internet
I have droid phone. Says on airplane mode. How do I turn airplane mode off?
1. Press and Hold the Power button for 2 Seconds. A menu pops up. On that list, you will see "Airplane Mode" (under which should state "Airplane mode is ON").
2. Now tap "Airplane Mode" to switch it Off. If you press the power button again after a few seconds, it should now say "Airplane Mode is OFF". This is how you want to leave it. Done.
Sep 14, 2011 | Apple iPod touch
What is airplane mode and how do i get out of it??
Airplane Mode (Motorola CLIQ™ with MOTOBLUR™)
NOTE: Airplane mode turns off the wireless radio. This allows you to use programs while travelling on an airplane, but not make or receive calls. An Airplane icon appears on top of the signal bar when airplane mode is active.
To turn Airplane mode on or off, refer to the following:
Using the Lock key
To use the Lock key to turn off Airplane mode, perform the following steps:
1. At the Home screen, press and hold the Power/Lock key on the right side of your phone.
2. At Airplane mode, tap On or Off.
Using the Settings menu
To turn the Airplane mode on or off using the Settings menu, perform the following steps:
1. At the Home screen, press the Menu key.
2. Tap Settings.
3. Tap Wireless controls.
4. Tap Airplane mode to turn on or off.
Dec 04, 2010 | Motorola Mobility CLIQ Cell Phone
Cant open phonebook,messages
To fix the problem and restore your connection (turn OFF airplane mode), click "Menu," then "Settings," then "Phone Settings," then "Airplane Mode," and then set the mode to "Off." Once you turn off the airplane mode, your Samsung phone will function as normal.
Oct 04, 2010 | Samsung Cell Phones
Alcatel Sparq OT-606a T-Mobile Unlocked GSM Qwerty Slider Cell Phone Logo
228 people viewed this question
Top Alcatel Cameras Experts
Steve
Are you an Alcatel Camera Expert? Answer questions, earn points and help others
