Question about Coby MP-C7085 MP3 Player
My computer won't recognize my coby mpc855 mp3 player.
There was no disk that came with the mp3 player, so how do i get my computer to recognize it? help!!
silveradoman
  • 58 Answers
SOURCE: computer does not recognize usb device
Dbl click on "my computer" desktop icon and see what you have listed before you hook it up then dbl click again after you hook it up,,,see if there is anything new listed there,,,if so then that should be the MP3 even though it may not say MP3.Mine says Mass Storage.If its there then just double click that drive and you should be able to drag and drop.
Posted on Apr 25, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: COMPUTER NOT RECOGNIZING MP3 PLAYER
Hold in the volume + button, and then reconnect to computer while holding in the volume + button, after 10-30 seconds of holding in volume +, a Found New Hardware Wizard should pop up.
Posted on May 16, 2008
SOURCE: Charging the coby clip 1gb m582 mp3 player
MINE HAS NO SWITCHS JUST THE USB PORT AND I CANT GET IT TO CHARGE
Posted on May 27, 2008
SOURCE: coby mp3 mp-605-4g is not recognized by any computers
I have the same problem. If you turn the unit over, you can see a small hole on th bottom right hang side - (next to USB symbol) - The RESET button is located inside. If you insert a small paper clip and press the button for approx 20 seconds it should function again.
Works for me
Posted on Dec 04, 2009
  • 29 Answers
SOURCE: Coby 610 MP3 not powering up or being recognized when plugged in
The same thing happened to me. Have you tried resetting it? Open up a paperclip and poke it in the back hole. The mp3 should reset. If this doesn't work, you are going to have to reformat it, although I did not have to do that so I don't know how.
Posted on Feb 13, 2010
My computer is not recognizing the coby MP815-8GB and saying that it is corrupt. Please suggest me how to fix this problem?
On the MP3 player itself, go to Setup > System > put the USB mode to MSC.
Reconnect the MP3 player to your computer, it should appear as a 'Removable Disk' drive under 'My Computer'.
If that doesn't resolve and you still get the 'USB Device is corrupt', try replacing the USB cable.
Jun 28, 2011 | Coby MP815 Digital Media Player
I plug my mp3 player into the usb port on my computer and it doesnt turn on to charge like it did before. i tried to turn on my mps player and it acts like there is no power. i just got this mp3 player and...
Hello
Check the connections on both ends to make sure they are attached securely. If the MP3 player is still not recognized, go into the player settings and change the Online Device from Media Device to USB Disk. Use a different USB cord if you have one because it could be broken and not allowing your computer to recognize it.
connect the device to a different USB port on your computer. If the MP3 player is still not charging, plug it into a wall charger. Try charging the Coby device overnight. If it still will not charge, the battery may be bad and you'll need to contact Coby for assistance
Apr 30, 2011 | Coby MP620 MP3 Player
Good morning today I come to your help, I recently bought a coby MP620, but the moment I attempted to use it could not. I connect and my computer does not recognize and no sign of that charge I come...
Hi Linares,
Here are some steps that will hopefully fix your problem.
  • First I would attempt to restart your computer with MP3 player plugged in the USB.
  • Then once restarted, Locate the MP3 Player under "MY Computer". The MP3 player will be listed as a "Removable Disk".
  • The Coby manual suggests that you use Windows Media Player 11. You can find that here:http://www.microsoft.com/windows/windowsmedia/player/download/download.aspx
  • You can find the Coby manual here: http://www.cobyusa.com/files/setupguide/MP610_SG.pdf
Good luck.
Mar 05, 2011 | Coby MP-610 MP3 Player
My system is not supporting coby MP-7052gb I want coby software for file transfer
Your system should support it, most likely your computer doesnt recognize the device on MTP mode, you can switch this on the device, go to Setup Mode > System > USB Mode > put the USB Mode to MSC, and then reconnect the MP3 player to your computer, the MP3 player should then show up as a Removable Disk drive under 'My Computer'.
May 21, 2010 | Coby MP-705 Digital Media Player
I have a coby c582 that my computer does not recognize i am operating windows xp home edition my f drive appears but says empty I can not open it it asks me to intall a disk. my wmp recognizes it but will...
Try this tip posted here on this site, this may be the answer.
http://www.fixya.com/support/r3774047-solve_mp3_player_connection_problem
copy and paste this address in to a new window.
Jan 22, 2010 | Coby MP-C582 MP3 Player
Deleting songs from a Coby MPC855 player
When using Windows Media Player 11 as this is common for the MPC885, you can delete songs running this software and making connection from the player to the computer using the provided USB cable.
In the Library menu of WMP11, the Coby player should show up on the left side in the list.
When clicking Music in the left corner of the second bar on top of WMP11, all music shows up from preselected synchronization maps on the computer plus the player.
Click on the player to see the content and delete the songs you'd like to remove.
Only setup guide available for this player:
http://www.cobyusa.com/files/setupguide/MPC885_SG.pdf
Need more help ? Just post a comment.
Dec 30, 2009 | Coby MPC885 MP3 Player
Computer doesn't recognize mp3
Following these instructions for fixing your Coby Mp-610 MP3 Player will replace the internal programming of your mp3 player, and allow your computer to recognize it.
Nov 22, 2009 | Coby MP-610 MP3 Player
No file
I'm not sure how this problem got fixed. I went into Windows Media Player and went into sync. It downloaded about all the music that wasn't already in my MP3 Player. It's working!!
I also changed UBS mode.
Dec 31, 2008 | Coby MP-C858 MP3 Player
Coby MP-C7085 MP3 Player Logo
197 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
