Question about Kenmore Ovens
Did not realize that burner was under the bottom of stove. Put in an aluminum drip pan on the bottom and turned ove n on for the first time. The pan is now melted to the bottom of my brand new oven. What can I do?
    Genius:
  • 1,198 Answers
Can you see that the pan has actually melted, or is it just stuck? Aluminum melts at over a thousand degrees, an oven only gets half that hot.
Try to pry it up with a putty knife.
Worse case scenario would be sanding it out with a rotary power sander after cutting as much out as possible with tin snips.
Posted on Nov 28, 2013
2 Suggested Answers
SOURCE: aluminum foil stuck to new oven bottom - how to remove
(Wear a professional n95 mask and rubber gloves). Use a straight razor and scrape off as much foil as possible. Get a hold of Mercuric or sulfuric acid. BE CAREFUL not to spill anywhere, work close to a stainless steal sink. Poor a little in a small glass container and bring over stove porcelain surface. Pour the acid onto the foil and wait 3-4 minutes, use paper towel to wipe off the acid, and then a soapy wet rag. Repeat process until all foil is dissolved. Then wash surface thoroughly and repeatedly with a soapy dish towel. Once complete run water in the sink for 5 minutes till any possible remaining accid is flushed from the sink. The foil is gone and the porcelain is preserved. Works great! (Don't breathe the fumes and ventelate the area or move the stove outside)
Posted on May 27, 2009
I have a brand new kenmore oven. I did not realize that the burner is under the bottom of the oven. I put an aluminum drip pan on the bottom of the oven and turned it on for the first time. The pan is...
You may be able to scrape off the remains of the pan but you must be careful to avoid damaging the oven lining. The alternative is to buy a new oven.
Nov 27, 2013 | Kenmore Ovens
Tip
Electric Oven Problems - What not to Use in Your Electric Oven
If you have an electric oven, there is one thing that you do not want to do. It does not matter if you have a wall electric oven, a wall double electric oven, or a freestanding electric oven. If the heating element in your oven is electric you do not want to do this.
After normal use of your oven the broiler pan, the oven racks, and the drip pans in the bottom of the oven can become soiled to the point where they will not clean properly anymore. Many people try to make the inside of their oven “look” better and give it a cleaner look by wrapping or covering these things with aluminum foil.
While this may give the oven a good clean look it also creates a problem for you and your oven. Aluminum foil is highly conductive and will “short” the electric elements in your oven if it comes in contact with them. This short means that the electricity will flow through the element and out of it at one point in an uncontrolled manner. This will cause a surge through the element to that point, which will cause the element to fail.
What many people also fail to realize is that the foil they wrap around these thing can move as the oven heats and cools. So even though the foil is far away from the element when you wrap it on, it can move till it comes in contact with the element and then in a moment it is too late to correct.
It has also come to my attention that some people may use aluminum pans in the bottom of the oven to catch any spillover that may happen. In my opinion that is just as bad as the foil wrap. These pans will warp with the heating and cooling also. If you can get a pan on the bottom rack and your food on the top rack, then you are good... the aluminum cannot get to the element in anyway...
If you have racks, pans, or other things in your oven that are too dirty and bother you…you are better off to buy new rather then take the chance on ruining your day in a flash.
http://www.fixya.com/support/r4388324-oven_fault_codes_ge_xl44_oven
http://www.fixya.com/support/r4391163-range_stove_oven_door_glass_replacement
http://www.fixya.com/support/r4404788-electric_oven_problem_oven_will_not_shut
http://www.fixya.com/support/r4319588-electric_oven_problems_not_use_in
http://www.fixya.com/support/r4154940-fault_codes_admiral_range_stove_oven
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
on Mar 12, 2010 | Ovens
Tappan self cleaning oven
You plobably have the incorrect drip pans that do not have the proper holes for the grates to fit in, I would chech with an appliance repairman, he should have a source for the correct drip pans.
Aug 14, 2013 | Ovens
My new oven has melted the tin foil onto the bottom of the oven that I put to catch cake drips. I don't know how to get it off as it has adhered. The smell right from the start of the oven and during my...
With the older models of self-cleaning ovens one could put aluminum foil on the bottom tray of the oven, but with the newer models there is a warning (hidden in the last line) of your booklet for models of stoves where aluminum foil should 'not' be used! Even though print in small and many consumers are complaining regarding their stoves and melted aluminum stuck to the bottom tray of their oven (nothing will get it off) all manufacturer do 'not' cover this problem under warranty and thus, it will cost you $44 to buy a new tray. You unscrew the two screws to the bottom of the damaged tray of your oven and then install the new one and put back the screws. Letters of complaint should be written to the manufacturers to have them put this warning in clear bold print right on the front cover of the instruction brochure.
Jan 20, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
I don't have a Kenmore I have a Fridgidare and I have burned on foil on the bottom and cannot remove it. It is a self cleaning overn and I am afraid to turn it on??? I have tried scrapping, soaking, but...
With the older models of self-cleaning ovens one could put aluminum foil on the bottom tray of the oven, but with the newer models there is a warning (hidden in the last line) of your booklet for models of stoves where aluminum foil should 'not' be used! Even though print in small and many consumers are complaining regarding their stoves and melted aluminum stuck to the bottom tray of their oven (nothing will get it off) all manufacturer do 'not' cover this problem under warranty and thus, it will cost you money to buy a new tray. You unscrew the two screws to the bottom of the damaged tray of your oven and then install the new one and put back the screws. Letters of complaint should be written to the manufacturers to have them put this warning in clear bold print right on the front cover of the instruction brochure.
Apr 26, 2010 | Kenmore 33169 Gas Single Oven
The oven burner will not ignite.
Because the glowbar is glowing does not necessarily make it good.
Turn off the gas to the stove. Remove the oven racks. Remove the bottom oven pan. Remove the flame spreader. This gives you access to the glow bar and gas valve.
Put a clamp on amp meter around one wire of the glowbar. Turn the oven control on to BAKE.
If the glowbar reads 3 amps or less,replace the glowbar ignitor.
If the glowbar reads good,check the burner tube for a white ash buildup. It can be cleaned with a wire brush. Look closely near the glowbar section of the burner.
Check all the wire connections for the gas valve.
If the glowbar is good and the ash deposits are gone and the oven still will not ignite,the next step is to replace the gas safety valve.
Dec 01, 2009 | Amana Ovens
How do i get an aluminum foil pan stuck from the
You may be able to get it opff with the oven hot. Whatever is holding it was liquid when hot before, so should at least loosen enough for you to remove it.
Nov 04, 2009 | Kenmore 47783 Electric Single Oven
Where is the pilotlight on a ge xl44 gas stove I belive it is in the door under the oven well I turned the gas on and stuck a flame down there and nothen took off is there a certian place to put the flame....
In general lets be clear. The OVEN pilot is located under the oven door at the top of the Broiler.It is a small piece of metal just before the GAS safety Valve which acts on temperature so gas won't flow unless Pilot is lit,That's the OVEN PILOT.The stove's RANGE is the top burners where you heat Pots and Pans.It has either 2 Pilot lights that connect the burners to the Flame they are under the Range Top.Newer Models use electronic ignitions no flame.Please note if you had your stove/oven disconected or Gas off when you turn it back on there will be air in the line that needs to escape before you light.This is why in NYC when Utility Co.works on steet main the MUST re-light your appliances.Be Careful with Gas.Good Luck.
Sep 19, 2009 | Ovens
Need to know if the burners come out of my stove
Hi, The burners should pull up and out. They plug into a receptical and should release fairly easy.
While you have the burners out, check the ends and see if there is any sign that they have been burning/arking. Thet should be clean before putting them back in. I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 02, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Aluminum foil stuck to new oven bottom - how to remove
Jan 20, 2009 | Kenmore 47783 Electric Single Oven
Ovens Logo
151 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
