Question about Stiebel Eltron DHC-3-1 Tankless Electric Water Heater
Leaking My water heater is leaking at what appears to be a "Pressure Relief Mechanism" i was looking for the reset button pressed it and realized it was not. How do i repair this problem... thanks... http://postimg.org/image/dl1ecmcul/
    Genius:
  • 1,198 Answers
I would continue to push it, hoping it would clear itself. You have nothing to lose.
Posted on Nov 28, 2013
Leaking relief valve on solar panel
I had to replace mine a few years ago. Just look on line. Search for pressure relief valve, or add solar. You will get a lot of responses. Comparison shop and buy. On line auctions work well also.
Mar 07, 2014 | Caleffi Solar Collectors
Pressure releif valve leaking
Hot water pressure relief valves serve two functions. The first is to remove high-pressure water from the hot water tank. The second function is to act as a high temperature valve to remove water that exceeds a predetermined point for the valve. Both of these relief settings are preset at the valve factory. Many pressure relief valves will come with a metal tag that identifies these release points. If you're attempting to remove the hot water heater pressure relief valve, pay careful attention to ensure that you replace with the correct valve.
Your hot water heater has a pressure relief valve safety mechanism. When pressure inside the water tank exceeds certain limitations, the valve opens up to allow the pressure to be released. A faulty pressure relief valve will not release excess pressure, which could cause extensive damage to your home. You should test the hot water heater pressure relief valve once every six months to ensure proper operation. If the pressure relief valve fails the test, replace the valve with a new one immediately
Locate the pressure relief valve on your hot water heater. The pressure relief valve has a lever handle on top with a drain pipe attached to it. The pressure relief valve is most often on the side of the water tank toward the top. Newer models of hot water heaters have the pressure relief valve on top of the water tank.
  • Inspect the area around the pressure relief valve for signs of leaking water. If there is leaking water near the relief valve connection, replace the relief valve. If no leaking is evident, proceed with testing the pressure valve.
  • 3
    Examine the area below the pressure relief valve drain pipe. Most water heater closets either have a drain in the floor below the pipe or the pipe is inserted into another pipe to direct the water out of the home. If the end of your drain pipe is not in another pipe or there is no drain in the floor, place a bucket under the drain pipe to catch water when you test the pressure relief valve.
  • 4
    Pull the lever handle on the top of the pressure relief valve up with your fingers. A working lever will lift up without difficulty.You should begin to hear water going through the drain pipe. Slowly release the lever to shut off the pressure relief valve. The pressure relief valve is good. If you did not hear water running through the drain pipe, lower the lever on the pressure relief valve and replace the valve. If the lever is difficult to raise, do not force the lever. Replace the pressure relief valve.
  • Now with all that said if you have a closed loop water supply system and you have a pressure vessal/expantion tank it may have gone bad and is making the TP valve leak. you can call your water provider to see if you have closed loop system.
    Feb 04, 2011 | Whirlpool Water Heaters
    Just purchaced a 99 jamboree with an atwood G6a-8e water heater. while on a trip I lit the water heater, and after 30 minutes someone told me water was leaking from the side. I noticed the pressure relief...
    It's gas operation only, but has electronic ignition for propane. ( just to confirm, if you look at back of water heater, it would have a metal or black plastic cover and hydro cable going in side or top of it.)
    There are usually 3 things that may cause pressure relief to leak. 1) Faulty,corroded pressure relief valve, which usually needs to be replaced if it goes faulty. 2) water temperature is getting too hot, which could indicate a faulty thermostat. 3) If your hooked up to city water, the pressure may be too high, causing excess pressure build up in hot water tank, thus pressure relief opens. If your running off your on board pump, this is probably not the cause, as they are usually set at 40 psi.
    Ist, - try pulling lever on relief valve slightly open ( careful it's hot !!) to clean out any calcium that may be logged on seal thus causing leak. If that doesn't do it, and the hot water isn't running out steady and appear to be under extreme pressure while leaking, then I'd change the pressure relief valve. Remember when you do, shut off water to system, and relieve pressure by opening a tap, and pressure relief as well after that. New one shouldn't be too expensive, just make sure you get same thread, 1/2"NPT or 3/4"NPT. Use a little teflon tape, or pipe dope whatever you prefer when re-installing as well as clean threads a little before.
    If it really starts gushing out pressure relief when heating or heated, and water seems hotter than normal, it's more than likely a faulty thermostat. I'll wait for your reply on what condition your experiencing before I go in to how to change the thermostat.
    Nov 17, 2010 | RTO Atwood Water Heater - 6 Gal LP
    Pop off valve on gas water heater making racket. Can just the pop off valve be replaced?
    Yes it can be replaced. This is a temperature/pressure relief valve and is the second most important safety device on your heater. They rarely make racket. Is it leaking? if so yes replace it. Water heaters should have a portion of water drained annually along with operating the relief valve. IF you raise the handle a few times, and it continues to leak, then it should be replaced. If you replace it be sure to replace it with EXACTLY the same temperature and pressure rating that is on it now. Allow the water heater to cool, and drain pressure before removing. If it is rumbling inside, you might have calcium deposits bouncing around in the bottom. Drain some water and see how it looks. (Often if you operate drain, and haven't in a long time it won't reseal)
    Aug 11, 2010 | American Standard 40 G Natural Gas Water...
    Water puddles leaking our of overflow pipe onto floor
    sounds like your pressure relief is leaking. Make sure your home water pressure isn't abnormally high (above 80 psi). As long as your water pressure is fine, you should replace the pressure relief.
    May 25, 2010 | Noritz 6.3 Gallon Residential Tankless...
    Pressure relief valve
    The pressure relief valve only leaks when there is excess pressure in the system, possible causes could be excessive static pressure, overheating, faulty pressure vessel or undersized pressure vessel.
    Apr 11, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
    Leaking pressure relief valve
    what is the water pressure on the cold side? You may need to install a pressure reducing valve at the water heater inlet to reduce inlet pressure and keep pop off valve from opening when not needed.
    Feb 27, 2010 | Emerson Part UWL Chrome Ultrasystem water...
    The red pressure relief button on my GE Smartwater GXWH35F whole house Water filer system is leaking water, any suggestions? Oring, what do you lubricate the Oring with?
    Don't lubricate this O ring. Your trouble is not there.
    There is probably a small piece of dirt in the bleed valve (you are calling this a pressure relief though its purpose is to let the air out not provide relief from excess pressure). Press it several times to try to wash the dirt out.
    If this doesn't work, you might have to work on the valve from the inside.
    Jan 15, 2010 | General Electric GE SmartWater Household...
    Vulcan everhot water heater leaking at pressure relief valve
    look can look to wear the water nis comeing from
    Dec 13, 2008 | Water Heaters
    Boiler leak
    Hi, it appears you have a defected relief valve. you can try one solution. lift the handle on the relief valve and let some water out. sometimes that can flush out materials thats blocking the stem in the valve. if it's still leaking it must be replace.
    If this doesn’t work for you please write back. Thanks,
    Nov 23, 2008 | Watts 3/4 Pressure Relief Valve
    Stiebel Eltron DHC-3-1 Tankless Electric Water Heater Logo
    47 people viewed this question
    Top Stiebel Eltron Water Heaters Experts
    chargerhp
    chargerhp
    Andrew Taylor
    Andrew Taylor
    Gil Shultz
    Are you a Stiebel Eltron Water Heater Expert? Answer questions, earn points and help others
