My remote was dropped, the batteries came out. the light comes on, but it wont program.
    Top Expert:
  • Televison & ... Master
  • 74,136 Answers
If the remote have hit hard, the carbon tracks inside its circuit board might have minute brakes. It is almost irrepairable. It will be better to buy a new one.
Posted on Nov 28, 2013
The power won't come on when i push the power button
If you are using a universal remote the program is lost anytime the batteries are removed or sometimes when the remote is dropped the program is lost.
If that is the case you only have to reprogram it.
Oct 16, 2014 | Televison & Video
Infrared indicator light will not come on all buttons flash multiple times
um..you wont see the infra red with the naked eye..you can only see it using nite vision style equipment..something that shows in monochrome which is that frequency..if it lights up it is supposed to be working..some need reset to the units in use when the batteries are replaced..use the search mode on it..
Feb 06, 2014 | Universal Urc R6 Avex Pre-Programmed...
Remote wont work
Check the battery if its good.
First see your remote is sending an infra red out to TV.When you press the remote button look through a digital camera. If you see a light coming out of the LED it means remote is transmitting a signal.
Apr 02, 2012 | Westinghouse LVM-37w1 37 in. HD-Ready LCD...
The remote was dropped and now the fan does not work. It is not an easy task to get to the fan to replace since the ceiling is 18 ft high. We were sent a new remote and told it would work, but it does...
The remote has to be programmed to match the existing fan's receiver code. The programming information should have come with the hand held remote. If it didn't, contact whomever you purchased it from.
Jul 20, 2011 | Hunter Heating & Cooling
Tv has power but wont turn on, NO picture , no hum , nothing but a red light
When the TV power button shows and no signs come on it could be caused by several things. But the most common cause is a faulty battery in the remote control. If the battery in the remote is out then the remote will refuse to work and therefore the TV will not come on. Simply try pressing the program button on the TV either upwards or downward and the TV should come on if the battery is the problem.
Hope this solution has been helpful?
Feb 08, 2011 | Televison & Video
Our son dropped our Jensen Universal Remote, the batteries fell out, I no longer have the manual or code to reprogram it, can you help me. Have replaced batteries, red light is on, just can't get TV to...
Manually turn on the component you want to
program.
Find the three-digit code numbers for the
component brand.
Hold the Device key down until the green
indicator light comes on.
Release the Device key. Within 30 seconds,
enter in the three-digit code number. The light will flash when the right code has been entered.
press the Power key. If the component turns
off, you have found the right code.
Send me a mail get your tv code
Feb 18, 2010 | Jensen JR400 Remote Control
2001 ml320, remotes quit working. new batteries,
Synchronization
Turn ignition switch to position II. Turn ignition switch to position 0 and remove key. Within 1 minute: Press and hold key lock button. Press unlock button 5 times. Remote control should now operate system. If not: Repeat procedure.
Programming
When
Key remote control added or replaced. System malfunction.
How
Keys can only be programmed using diagnostic equipment
Jan 09, 2010 | 2002 Mercedes-Benz C-Class
Genie excelerator/
Check to see if the Vacation switch is locked on your wall console. It is a switch on the top of the black wall button. If that is not the problem it sounds like you need to program your remotes. Drop down the plastic cover towards the back of the unit There is a learn button push that and a red LED will come start flashing press and hold the button on your remote until the LED stops flashing (solid red) press the button on your remote again and the light will go off. This will program a remote
Here is a copy of your manual
www.geniecompany.com/docs/GENIE%20EXCELERATOR-ENG.pdf
Oct 12, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
Electro Med Services...
