Question about AOpen F2715-8S Monitor
My monitor has a green hue that will not go away when I adjust the colors in the screen. The blue adjuster doesn't seem to do anything. When I use auto adjust, It looks amazing for about 5 seconds then goes back to the green shade.
  • jarahamme May 08, 2009
    It's definitely the monitor. I've been looking into it and it seems that others have had the same problem, but no one seems to have the answer.
    Problem Solver:
  • 9 Answers
If you have another PC try it on the monitor, see if the problem persist. I f it doesn't check your video card's control panel. Some configuration there, may be overriding your monitor's. If you have an nvidia based card run the "optimize my display wizard"
Posted on May 08, 2009
  • r390gt1sp623 May 08, 2009
    Ok, have you tried changing the color warmth to 9300K??
    If the green hue is more like a stain in the corner or certain area of the screen try "demagnetizing " if that doesn't work take a magnet or if you don't have one, take a magnetized screwdriver and put it close to the screen. You'll have to play with it a little moving it out of the screen. till it slowly takes the stain away.
    However if the problem is in the whole screen this wont help.
    Check the VGA connector and see if it has a bended or missing pin.
    Unplug the monitor from the AC and the pc, leave it like that for 24 hours and see if that helps.
What is the perfect amount of red,blue,and yellow hue for the screen
that's got t o do with personnel preference and room lighting , but as a general rule adjust color hue's till the edges of a white color object on screen has just lost its primary color edge
the older projection TV's actually have voltage numbers for the service tech to adjust them too , but im not remembering seeing any in the LCD manuals
Mar 29, 2016 | Element Electronics FLX3210 32 in. LCD TV
No green or yellow color
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
Aug 29, 2017 | Sony FWD-50PX1 50 in. HD-Ready Plasma...
Problem with the Toshiba 50H13 50 in. Rear Projection Television. Green tint
The tubes have aged and the colour balance between the tubes has shifted. You will need to redo it using a black/white test image: first the black (the cutoff point), then the white (the gain) on each tube - always start with the green colour. This is done on the final video amplifier of each tube by adjusting the corresponding semiadjustable resistors.
Jun 02, 2011 | Toshiba Televison & Video
Pink shade more in NEC WT-610 PROJECTOR
Using the on screen menu, check the hue or wall color settings. [Hue]
Varies the color level from +/- green to +/-blue. The red level is used as reference. This adjustment is only valid for
Video, Component and TV standard inputs (not valid for RGB and DVI digital).
Using the Wall Color Correction [Wall Color]
This function allows for quick adaptive color correction in applications where the screen material is not white.
The following nine options are available.
• OFF • Blackboard
• Blackboard (Gray) • Light yellow
• Light green • Light blue
• Sky blue • Light rose
• Pink
Dec 30, 2008 | NEC WT610 DLP Projector
Color is weird.
Component Video Jack was loose.
Dec 14, 2008 | Sony KP-48V45 48" Rear Projection...
Blurry screen KP61hs10
Yes, Convergence settings should be tried first before any color adjustment or any fluid changes are done. Remember that there are 3 colors to notice. Red, Green, Blue. The Green is the only one that you can not move with an adjustment The Red and Blue is ligned up on green. Some cases it does matter how linear the Green color is across the board, just how close you get the blue and red on top of green is what matters.
Mar 25, 2008 | Sony KP-61HS10 61" Rear Projection...
Colors are off after auto adjust
I seem to have found the solution (and the cause, perhaps?) for this problem!
I was having the EXACT same problem with a monitor I'm repairing for a friend. The capacitors on the power supply board were blown (CapXon capacitors, who'd've guessed), which was keeping it from powering up. After replacing the capacitors, the screen worked beautifully. But it had this weird yellow tint!
The strange part was that pure colors - red, green, blue - all appeared perfectly OK on screen. Curiously, the menus would show in the proper colors, except for one: the manual color adjustment menu, which illustrated "Blue" as a sort of off-green in the icon. Auto-Adjust would always fix the colors for a split second, then go back to yellow. Reset didn't fix it. Color reset didn't either. So, exactly the same problem as above.
The solution I found was hidden within the main menu itself, a sort of "easter egg". <b>Hold the Menu button down while pressing Power, and hold it down until the screen, and menu, appear</b>. There will now be a hidden selection, "Auto Color", printed in a red-on-black font at the bottom of the menu. Use the +/- buttons to access it, and press Menu. Voila! PERFECT COLOR! Perhaps this menu was accessed by accident, and calibrated to an incorrect color key. But now my picture works great, and the setting lasts through Auto-Adjusts and Resets!
Hope this helps some people, it sure saved my ****! ;)
Dec 05, 2007 | AOpen 19" LCD
57" Sony Wide Screen Projection TV with a green hue
You were given some pretty good advice but what you need now is a BK467 crt tester and the pin-out connections. Each tube, especially the green, will need to be tested for high/low emmisions and shorts. Don't take it on faith that having it rejuvenated will work for anything other than temporary either. You're probably lloking at replacing at least the green crt and it ain't cheep..
PS, don't kill the messenger either - - I don't like giving bad news and any shop you take it too will not relish in telling you what I just did.. I have 20 years in the repair industry and it's never pleasant telling a customer it's time for considering an new TV...
Nov 05, 2007 | Sony KP-57WV600 57" Rear Projection...
AOpen F2715-8S Monitor Logo
639 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
Matthew Spark
Matthew Spark
David
David
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
