Ideal H18 boiler and the standby light does not come on
Boiler does not show standby led. Pump comes on when no call for heating then flashing led is on. been told that i need another extra wire'local source' to the boiler and it is an installation fault. BUT i have had the boiler fitted 8 yrs ago and its just recent the problem has occured.
4 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: I have an ideal standard he30 boiler instaledi
You have a problem that the installer does not know how to fix so they are just stringing you along hoping that you will give up and find some one else or forget about it..
You need to tell them to
1. fix the boiler correctly
2.take it back out and give you a new one at their expense
3. or tell them you will call another comapny to fix it and will give the bill to them to pay.
You did not get what you have paid for... do not pay them any money to come out and troubleshoot the boiler.
The boiler should work as the instructions say or someone did something wrong...
Sometimes it is best to call the boiler company and talk directly to their Tech. Support people.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Posted on Dec 24, 2009
Testimonial: "offerd good advice"
SOURCE: ideal response 120 seems to fire up but burner
If this an older style boiler remove thermostatwires
at boiler terminal board and put jumper between R and W, if boiler starts you have bad thermostat.
If it does not come on then it appers that you have
a problem with the spark ignition or glow coil is
bad
Posted on Jan 09, 2010
  • 3239 Answers
SOURCE: new thermocouple fitted but pilot light keeps
Hi check the size of the pilot flame see if this is playing on the thermocouple , check if nut on gas valve from thermocouple is tight
Posted on Apr 05, 2010
What is the best boiler for heating and hot water in Europe for a flat?
I would suggest the Wilford boiler is a great option. In particular, the Zhangjiagang Wilford Boiler as it is a combination boiler meaning it is small, can easily be stored in a cupboard and is economical to run. Get in touch with them to see if it is ideal for you.This brand of pressure hot water boiler is the best choice of transforming of the heating boiler of coal-fired. The horizontal structure of the boiler can absorb the heat with high efficiency ,heat transfer fully, the efficiency of heat transfer can reach 98%, and with good quality of steam, not pollution, no noise ,is the real green and environmental protection product. you can go its website for more
Hot Water Boiler Hot Water Boiler Products Hot Water Boiler Manufacturers...
May 08, 2017 | Miscellaneous
I've just moved and the boiler is an Ideal Classic
it should be a fully pumped system , which pumps heating and the hot water i take you have ahot water tank /cylinder for hot water with a 3 way valve on it , hmm set the boiler thermstat to number 5 put you clock /programer to hotwater only,once aday or twice , its down to how much water you need . see if this helps .
Aug 24, 2011 | Heating & Cooling
Ideal response 120 seems to fire up but burner light does not come on and boiler runs for a while and stops,no hot water or heating ???
bad
Jan 09, 2010 | Honeywell CT87B ROUND HEATING&COOLING...
I have an ideal standard he30 boiler instaledi have an ideal standard he30 boiler instaled about 6 weeks ago. the boiler keeps losing presure about half a bar every 2 days if i dont top it up it will trip...
Heatman101
Dec 24, 2009 | Heating & Cooling
I have an ideal standard he30 boiler instaled about 6 weeks ago. the boiler keeps losing presure about half a bar every 2 days if i dont top it up it will trip the fuse on the fuse board acording to the...
All the combis I've come across merely fail to fire if the pressure is not up. not only do they not fire, nothing else works including the pump and in any event the pump should not overheat just on low pressure.
water loss - try turning off the valves on the flow & return pipes [3/4 inch ones] 1 valve per pipe . This will isolate the rest of the system - rads etc Note pressure over a time period. In this mode the hot water circuit will still work but do NOT use the heating circuit
1/2 bar over 2 days is not serious but it should be found
Once you have either mended the leak in the rest of the system or found there is not one, insist on a replacement boiler
In any event having looked at the reasons given for the fuse blowing, I would definitely get a replacement.
These problems should not happen on a new boiler
I list Worcester.-Ariston-GlowWorm-Ideal- and many others who would confirm this
Dec 24, 2009 | Water Heaters
I have an older model Ideal Mexico 2 floor standing open flue boiler running a fully pumped system. The central heating isn't working properly despite being flushed etc. The initial problem is still there...
You could undone the return at the boiler to release any air ? if you think there is a air lock . Or turn the pump up to max with the heating on and try to push the air out .
Jun 08, 2017 | Water Heaters
Missing instructions for setting timer on boiler
if the timer is built into the boiler there is a small switch on the right hand side. this can be moved up and down to bring the timer on and off.
if you log onto the ideal web site you should be able to download a copy of the programing instructions.
Feb 21, 2009 | Water Heaters
Heating & Cooling Logo
22 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
