Question about Stihl Saws
Husqvarna pull cord
My disc cutter pull cord has gone slack on occasions almost from the first day of use
  • Stihl Master
  • 1,807 Answers
Remove the recoil housing and add an extra turn on the recoil cord on the spool to take up the slack.
Posted on Mar 14, 2016
HOW DO I RESTRING MY 2 LINE HOMELITE 13" CORDED TRIMMER
On trimmers I have you take out the spool by pushing in the lock ears and pulling out the spool. Then put the end of the line in a little hole in the spool and wind the line in the direction shown on the spool till it is full. Do the same for the other line. Leave a little slack so you can put a few inches of line through the hole in the cutter head as you snap the spool back into place.
Jul 31, 2013 | Garden
Wot is the fuel mix for a partner k 750 disc cutter
50-1 with Husqvarna two stroke oil, but 25-1 with other two stroke oil as the quaility is unknown, always try to use Husqvarna two stroke oil
Mar 09, 2013 | Stihl Ts400 Cut Off Saw Carb Carburetor...
HuskvanaDesigner 1 , automatic thread cutter stopped working.it was working fine .I turned of machine for about 15 minutes. When I turned it on again the cutter didn't work. Can you help? Olga
No real idea what has gone wrong, but first thing I would do would be to clean out the bobbin area thoroughly. There may well be a piece of lint stuck in there that is preventing the mechanism from operating. Is the cutter not working manually i.e. when you touch the cutter button, or not working at thread changes in embroidery? If it in the manual situation you might find that the button is not connecting with the electronics behind that panel correctly and it will need a machine technician to correct it.
Jan 09, 2011 | Husqvarna Viking 1
Brake spring recoil will not open
I assume you are speaking of the starter cord return spring. Make sure to turn it CCW to wind it, but leave enough slack so that the spool can turn about four more turns without binding the spring when starting. If the cord broke, the spool may have over-run it's stops--try to to pull the spool outward when trying to wind the spring. Leave the cord off until you get the spring correctly wound. When wound, wedge the spool to prevent it from unwinding. Be sure to melt the cord ends before tying the overhand knot--but leave the outer end alone until the handle is slipped over the cord. Hope some of this helps!
Jul 10, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
The pull cord for starting the cutter has detatched
normaly there is 4 bolts holding the cover on take them out and the pull clutch in under there,,, put the string back in the cover and tighten the clutch up first so it pulls the strin in when you let it go,,,tiy a good knot in the pull start string or you will just pull it out again!
Jul 01, 2010 | Ryobi Garden
The selective thread cutter not cutting thread.
You need a new blade in the cutter. It is a simple repair job, but needs to go to the repairman for it to be done.
Feb 28, 2010 | Husqvarna Designer I
My pull cord will not spring back properly
pull the cord cover off and check to see there is not to much slack in the cord when fully wound...if there is you can rewind the slack onto the spool...the spring may be broken and needs to be replaced
Mar 08, 2009 | 2005 Honda CG 150 Titan KS
Saws Logo
231 people viewed this question
Top Stihl Saws Experts
Joseph Mueller
Joseph Mueller
Spud Howell
ray gallant
Are you a Stihl Saw Expert? Answer questions, earn points and help others
