Question about Bosch Microwave Ovens
The door on the combination oven/microwave slammed shut and all the power cut off from it
  • 4 Answers
1 check main cable connection maybe its pull uot or cuted from fuse bass
Posted on Nov 27, 2013
4 Suggested Answers
MicrowaveSvc
  • 9047 Answers
SOURCE: glass continually shattering on combination neff oven
That's a huge gap.
You might ask their customer service people to authorize the replacement of the whole door or the glass and the inner door panel where the gap is.
If they won't help you, you could clean it thoroughly, then carefully caulk the gap with high temperature caulk.
Posted on Oct 09, 2009
Testimonial: "Thanks for your help. Customer Services were no help. Can you please advise which type of caulking to use."
SOURCE: Kenmore Microwave Hood Combination oven Model Service code (SE) ?
I have Microwave Kenmore model 401.80082700 about more than a year. After about 6 months, it stated to have some probles such as some number keys not working. Then button START become nor working some times. I can use only button of 30 secon increment to cook something. OK, the fan is working for most of the time but the levels are stuck, not adjustable. I can't changer the fan levels. Now the lamp buton is dead. Sometime, the fan level control is working by itself level 1, 2, 3.... then it appears -SE- on the display. nothing work now. I unplug.... then plug back, it ask to input the time or date... I can't do any thing. Later some time I can cook by using 30 secon button.... It is anoying. Please how I can fix it? Thank you.
Posted on Nov 09, 2009
  • 17 Answers
SOURCE: replace light bulb on the Neff H7871 combined oven and microwave.
The bulb is positioned at the top of the oven, accessible only from the outside. You'll need to pull off the top and bottom trim strips, remove the bottom trim strip locators, remove 2 fixing screws from the left edge of the oven (with door open), and the 2 fixing screws from behind the top trim strip. The oven should then just slide out. You only need to pull it out 6 inches or so to gain access to the bulb cover. You'll need a T20 driver to remove the cover, then the bulb unscrews as it has an SES fitting. Bob
Posted on Dec 01, 2010
Microwave will not operate unless I slam the door shut then program to cook.
of course it is , most likely needs a new door switch .
Oct 21, 2015 | Microwave Ovens
Microwave power off, but will flicker when door shuts
Please inspect the plastic latches that should actuate the door switches. Sounds like you may have broken one when slamming the door too hard
Mar 20, 2014 | Samsung SMH9151 Microwave Oven
The door of the combination oven microwave slammed shut and the oven lost all power
check the main cable of mven maybe its Rupture test it if it give 220v ac or 110 vac
if it ok then check fuse bass wich the cable connect on it maybe it damaged
Nov 27, 2013 | Bosch Microwave Ovens
Viking Microwave Model DMOC205SS, manufactured June, 2004 does not have any Power. It is Not a fuse problem. Any ideas?
Have you tried toggling the door button? I have found that we need to hold the door button to get power on. One person said this due to slamming of the microwave door.
Aug 24, 2012 | Viking VMOC205SS Microwave Oven
GE microwave oven model#JVM1441BH04 when you close door on switch activates and oven comes on. Only goes off when door is opened.
HELLO.
the problem your are experiencing with your microwave oven is a failed interlock switch.
Be careful when closing your microwave door. Slamming the door too hard is one of the main reasons that the interlock switch is damaged.
Slamming the microwave door shut can easily blow the microwave fuse, but they can also blow due to problems with the interlock switches.
A microwave oven will not function until the fuse is replaced.
Instruction on how to replace fuse on microwave.
1. Unplug the microwave from the electrical outlet to prevent electrocution. Place the microwave in a well-lit area to be able to locate the fuse.
2. Use a screwdriver to remove the outer cabinet of the microwave, and follow the power cord to the fuse. The fuse is located 2 to 3 inches within the microwave and is attached to the power board.
3. Observe the fuse to determine if it is blown. Blown glass fuses will produce burn marks on nearby surfaces, or the internal fuse wire will be black and melted, while ceramic fuses show no outward appearance of being blown.
4. Determine if a ceramic fuse is blown by testing it with an ohmmeter. If the ohmmeter reads zero ohms, your fuse is not blown. Other readings on the ohmmeter show that your fuse is blown.
5. Replace the blown fuse by popping it out of its holder, and snapping a new fuse in its place. Tighten the fuse clips by squeezing them together with your fingers.
6. Replace the outer cabinet of the microwave, and plug the microwave back into the electrical outlet. Test the microwave to see if it's working properly.
thanks.
Sep 22, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Kenmore hood microwave door was slammed shut, now it won't power on. Fuse is good, door switches don't look damaged or dislodged. I haven't ohm'd the switches. They should not be the problem as the...
While the door was slammed it is possible that the connection to the main board was disconnected. so since there is no display I recommend that you check the power to the processor board, check if the LT circuit is working , if the board fuse has failed or if the power supply here is faulty.
Only if the display comes back will it confirm the working o the processor.
Apr 01, 2011 | Kenmore Microwave Ovens
My wife slammed the door and now the microwave does not work. it popped the fuse box and also cut the power to the stove. i flipped the switch in the fuse box and the stove came back on but not the...
You can try to take the unit down and open the cage. Look at the door safety switches and see if they also popped out of place. She might have permanently damaged the door. But don't panic just try what I just explained. Turn off all power first at the breakers.
Jan 05, 2011 | KitchenAid KHMS155L Microwave Oven
NEED TO REPLACE THE WHITE PLASTIC CATCH ON NEXT TO THE CONTROL PANEL AS IT SNAPPED OFF AS MY SON SLAMMED THE DOOR
By the nature of the oven main face plate and the locking latch being attached to the safety system the replacement cost is usually higher than a replacement microwave oven.
In your case replacing the microwave with another one is more sensible. Your oven is an obscure model as it is, I'd suggest a sharp brand.
Regards,
Worldvet
May 15, 2008 | Zanussi ZM24STX 900 Watts Microwave Oven
No Power Whirlpool MH7140XF
does it not light up at all? A microwave has a fuse on it. Probably accessible from the back panel. if not you would need to disassemble it. Most likely cause of this is slamming the door broke one of the safety switches the door has so the microwave knows when the door is open. And it shorted against something when it broke. It might have simply blew the fuse but then again you might have fried it.
Oct 01, 2007 | Whirlpool MH7140XF Microwave Oven
Microwave Ovens Logo
46 people viewed this question
Top Bosch Microwave Ovens Experts
William Miller
William Miller
Shehu Pro
Shehu Pro
Are you a Bosch Microwave Oven Expert? Answer questions, earn points and help others
