Question about Dell Computers & Internet
Battery wont charge
I just bought a new replacement battery for my dell xps L502x laptop.it is saying"plugged in,not charging".what can i do please
    Problem Solver:
  • 6 Answers
A lot of electronic equipment nowadays is pretty finicky about the power supply and battery. Did you buy an approved battery for you laptop? The computer may refuse to charge the battery if it does not recognize it as compatible.
Posted on Nov 27, 2013
Kegtapper
  • 94 Answers
SOURCE: Dell latitude D600 battery charge light flashing
You have a ground fault issue in the DC JACK.
There are escentially 4 circuits in the jack and one is not making contact.
1: Negative Charge circuit (outter ring)
2: Negative Run circuit (outter ring)
3 Positive (Inner Ring)
4: Signal (center pin)
I believe the negative charge circuit (outter ring) is not making contact internally. Typically what happens on that model DC Jack is the tension contact metal becomes fatigued, and does not touch the outter ring.
This could come from Heat causing early fatigue of the metal.
Or normal wear, the metal has simply worn out from regular insert/removal.
Don't forget to rate suggestions
Posted on Apr 01, 2008
  • 159 Answers
SOURCE: not charging
Dell PA-10 & PA-12 have internal serial ROM chips that communicate with the PC via the tiny center pin in the powerr plug.
If that pin gets bent or is not making proper contact, the laptop USUALLY complains and runs from AC adapter but refuses to recharge the battery ..
Posted on Apr 16, 2008
ArnWuLF
  • 55 Answers
SOURCE: DELL INSPIRON 6400 BATTERY CHARGE PROBLEM
The battery has 5 small dots in it. Those are there for no reason. Those are actually LED lights. There's a button you can press. If we number the lights 1-2-3-4-5 with 1 being closest to the button, check the lights when you press the button. If 1-3-5 are lit, that means that you have a dead battery and needs to be replaced. Other than that, you're battery might still be working but nearing the end of its life. Goto support.dell.com -> drivers and downloads -> enter your service tag or system type -> download Dell Quickset. Once Quickset is installed, it will diagnose your battery automatically and let you know if your battery already needs a replacement. It is just sad that batteries are covered with a separate 1-year warranty only. You can also go to www.dellbatteryprogram.com and check if your battery was part of the Dell Battery Recall Program.
Posted on Nov 25, 2008
Joed911
  • 4338 Answers
SOURCE: Replacement battery for Dell Inspiron 1501 won't charge
If your old battery was doing the same (not charging), then is is because the charger is not charging the battery. Do you have a friend with a Dell laptop? Maybe you can use a borrowed charger to test and see if it will charge the batteries. To answer your question , no Dell does not have anything built in to prevent you from using a 3rd party battery.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 28, 2008
SOURCE: Battery charge issue with Dell XPS M1530
when the battery is fully charged the circuit inside the laptop, automatically. stop charging to increase the the life of the battery,,, thank you,, plz rate me.,,,
Posted on Jun 29, 2009
I bought a new battery for laptop and it still wont charge
Dell uses proprietary equipment. IF the laptop wont work when plugged in and it is the original Dell charger, you need to check the charger, if the charger wont work then the battery wont charge. Note that it might be the connection on the board inside the laptop especially if the cord got pulled on while plugged into the laptop.
Oct 05, 2015 | Dell Computers & Internet
Plugged in, not charging
First, try another charger. Perhaps your charger isn't providing enough volts to the laptop
Feb 27, 2014 | Dell Inspiron 1545 Notebook
Dell xps is plugged in but not charging?
I would guess the battery is done. How old is it? How many charge/ discharge cycles? Do you leave it in when using on AC at home?
Jan 04, 2013 | Dell XPS M1330 Notebook
Dell Xps 15 Laptop Battery Not Charging
If your battery will not charge, you need to run a test on some components on the laptop. The battery, the charger and the laptop itself. Once you detect the faulty conponent then you replace it with a new one.
To test the battery:
1.Power off the laptop,
2.Take out the battery,
3.Insert it in another laptop,
4.Check of it will charge,
If the battery holds a charge there, then it means the problem is not from the battery, but if it does not hold a charge, then it means the battery is defective and need to be replaced with a new one.
To test the charger:
1.Unplug the charger from the present laptop,
2.Connect it to another laptop to see if it will charge.
If it charges the laptop, then it means the charger is alright, and if it does not charge the laptop, then it means the charger is bad and need to be replaced.
To test the laptop:
1.Turn off the laptop,
2.Disconnect your present charger,
3.Remove your present battery pack,
4.Insert a well tested battery into the laptop,
5.Connect a well tested charger to the laptop.
If it powers on, then it and charges, then it means the laptop is working fine, but if it does not charge, then it means the connection port of the laptop is bad.Hope this information was helpful.
Dell XPS 15 AC Adapter Charger
Nov 01, 2012 | Dell XPS Computers & Internet
I have a dell xps m1330. I just bought a new battery and I have it plugged in and it states plugged in and not charging. Why is it doing this, and how can i fix it
Try buying a new charging cord and see if that corrects the problem. If it dosnt let me know and we can go from there.
Aug 09, 2011 | Dell XPS M1330 Notebook
My dell battery will not charge anymore. it says
Charging circuit on motherboard or you can try a different A/C adapter. Start with the adapter first, they're pretty inexpensive $20-$35. If that doesn't fix it then a motherboard replacement is your solution unfortunately. Check with Dell on your warranty options.
Jul 12, 2010 | Dell Inspiron 1525 Laptop
I have a Dell XPS M1210 laptop for which I have just purchased a new 9-cell compatible battery. It worked great for a couple of hours, but now shuts off immediately when unplugged from the AC power supply....
You might want to try what I did when I had a completely discharged battery for my Dell Laptop. I attached the battery to the computer, make sure the computer is off and plug in the charger for a full twenty four hours (undisturbed). And this really worked. I had no problems with the battery. Good luck.
Feb 26, 2010 | Dell XPS M1210 Notebook
My dell will not charge> at battery icon says plugged in and not charging
Battery light may sound charging but it is common for batteries to easily loose holding charge.
G
Feb 19, 2010 | Dell XPS M1730 Laptop
My dell xps M2010 laptop is not working with the battery but it comes on when i plug in the ac adaptor charger. when i checked the bios setting it says battery not recognized and later, when i turned on...
Hello and thank you for using Fixya's services.
Your power adapter is bad and is not able to charge the battery at all (which is why the battery is dead). Yes, this is common with laptops because of the constant plug in and plug out. Yo can purchase a new adapter for less than $25.00 on eBay. Anywhere else it will cost three times more.
Once you replace the adapter, the battery will get a full charge and you will be up and running again.
Please let me know if you have any questions and I will assist.
Oct 27, 2009 | Dell My XPS M2010 Notebook
Jun 28, 2009 | Dell XPS M1530 Laptop
Computers & Internet Logo
50 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
