Question about Kenwood EW7507EK Oil Radiator
How do I set the timer on my electric kenwood heater
Trying to set the timer
Can not find the instruction manual for my III Woods #50016 outdoor timer. I do not know if it is similar to any of the other Woods timers that you've already answered questions for.
Here is the manual Janet
[PDF]Timer Instructions in English https://www.muni.org/Departments/health/.../timer%20instructions2012%206.pdf
  1. Cached
  2. Similar
Woods 50016 digital timer for use with engine block heaters. Refer also to enclosed directions for additional safety cautions and Spanish and French translations. Set timer to supply electricity to your vehicle's engine block heater 2 to 3 hours ...
[PDF]Woods 50016 timer manual - Water Heater Timer
waterheatertimer.org/pdf/Woods-50016_Instruction-manual.pdf
  1. Cached
  2. Similar
Page 1. http://waterheatertimer.org/Woods-timers-and-manuals.html#50016.
Woods 50016 Digital Timer for Engine Block Heater: Amazon.ca ...
https://www.amazon.ca/Woods-50016-Digital-Engine-Heater/dp/B006LYHG4W
  1. Cached
Rating: 2.2 - ‎8 reviews Set timer to supply electricity to your vehicle, s engine block heater 2 to 3 hours before ... Woods 50016 Outdoor Digital Block Heater Timer, 24-Hour. ... rating: 15A, 1875-Watt; tungsten rating: 10A, 1250-Watt 8A ballast; controls up to 1/2 HP. .... This causes it to go into a setup phase and not provide power to my block heater.
Nov 15, 2016 | Woods Hardware & Accessories
Kenwood oil filled heater timer starting making a ticking noise. Is there a way to fix it?
Most of these model are not repair able but seems like thermostat problem
Feb 03, 2015 | Kenwood Heating & Cooling
How do you program this heater
temp setting
1. press the temp/timer button untill the temp icon blinks
2 use up and down arrows to set temp.3 the temperture icon will stop blinking and the current room temperture will appear after desired temp. is set.
4 the heat will turn off shortly after the desiredtemp. is reached and the temp. ndisplay will blink.
5 the heater will turn back on when room temperture drops below the set temp.
timer : auto -off press the temp/time button untill timer icon blinks. the hour display will apear. the auto off icon will also appear.
2. use up and down arrow buttons to set the heater operation time between 1 and 10 hours. this function will activate once the timer icon stops blinking.
3. the heater will automaticly turn off when time runs out.
set temperture first so heater will cycle on and off till shut down time reached
Feb 02, 2011 | Comfort Zone CZ9009 Oil Filled Electric...
Timer will not turn water heater ON at set time, has to be done manually. However, it will turn water heater OFF at set time.
If this is new installation, check wiring. Hot and Load wires might be reversed.
Check that ON OFF trippers are both attached to yellow dial.
http://waterheatertimer.org/How-to-wire-WH40.html
If timer worked fine before, and started missing recently, then tripper pins probably worn out.
Trippers contact mechanical lever, and push lever on-and-off.
Trippers are softer metal and designed to wear out before lever.
If lever is worn out, timer needs to be replaced, but try new trippers first.
Buy trippers at Grainger
http://www.grainger.com/Grainger/INTERMATIC-Timer-Tripper-2E054?Pid=search
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
How WH40 timer works:
Clock motor rotates dial.
ON-OFF trippers on dial contact lever.
ON tripper pushes lever one direction.
OFF tripper pushes lever other direction.
Lever moves electrical contacts together, or pulls contacts apart.
When lever moves on-and-off, manual override lever also snaps back and forth with audible clicking sound.
Using q-tip, add touch of white grease to lever where trippers contact.
Nov 25, 2010 | Intermatic WH40 - Water Heater Time Switch...
I have a patton puh682 1500 watt heater and after a while it just seems to turn off is there some kind of timer or heat control?
Under the main black knob is a bi-metal switch which shuts down the heat at various temps depending on your setting. Their is no timer.
Sep 21, 2010 | Patton Electric Patton PUH680-U Electric...
Just got a new hot water heater, the other one was 40 gal...this one is 50 gal...I got a bigger one because it seemed like I was running out of hot water...now I am still running out of hot water when only...
Typically, a timer is not used with a hot water heater unless someone planned on being away from the dwelling frequently and didn't want to run the heater.
Another possibility would be that the heater shares a circuit with something and can't be on at the same time.
Anyway, excepting the above, it's ok to not use the timer - the heater should have a thermostat to regulate the water temperature. The "normal" setting should be high enough.
Mar 14, 2010 | Intermatic Electric Water Heater Timer...
How do I set up the timer for the water heater?
My friend came over and did it for me. It was easy once he showed me how. Thanks anyway.
Sep 05, 2009 | Electric Intermatic Wh 21 Water Heater...
Need Instruction Manual, Kenwood Electronic Heater #EW6708K
I have an original Kenwood instruction Manual for the Model
EW6708EK oil filled electronic heater (eng. and spanish)
Nov 21, 2008 | Heating & Cooling
Kenwood EW7507EK Oil Radiator Logo
Top Kenwood Heating & Cooling Experts
ray gallant
Electro Med Services...
Are you a Kenwood Heating and Cooling Expert? Answer questions, earn points and help others
