Question about Kenmore Microwave Ovens
What does E01 code mean on a Kenmore Microwave?
When I use preheat on the convection setting for a Kenmore microwave an error of E01 comes up.
MicrowaveSvc
  • 9047 Answers
SOURCE: my microwave is sweating
No. This is usually a sign of poor venting or air flow. It's possible that the coling fan is not circulating the air properly due to a problem with it or maybe the air vents are blocked. Also, there needs to be a couple of inches around a countertop model on all sides - especially the back - to ensure air flow. Look for buildup on the back vent grille. You can listen for the fan to be running and feel the air flow while it's running. If it's weak or not there, it needs inspection / service. A lack of air flow can cause the magnetron to overheat and be damaged. If this is a built-in model also check your air filter, air duct work and outdoor vent flap. Write back if you still have trouble.
Posted on Mar 13, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: kenmore elite utra microwave 721.63763300
Your model number prefix of 721 means it's made by LG / Goldstar.
F9 code on an LG means either a bad door switch or a loose door switch mount.
Even though a door switch clicks, it may still be bad inside.
This can be caused by slamming the door or by habitually opening the door while it's cooking without hitting the Stop pad first.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://www3.sears.com (the 3 is correct)
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jan 20, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Sharp Microwave R-950A
Chances are your thermistor is defective.
This UK model is probably similar to the US model R-930 or R-820.
We have both service manuals at our site and while the part numbers will not necessarily be the same, they will be handy for safety, disassembly and troubleshooting. They are here and here.
When you're ready to order parts, visit Sharp UK for spares dealers and servicers.
Posted on Jun 08, 2008
  • 25 Answers
SOURCE: microwave KENMORE code error F6
F6 is a relay failure
Posted on Jan 14, 2009
jsrock516
  • 5911 Answers
SOURCE: Unit "Locked"
"Locked" on the display is an indication that your microwave oven has a Safety Lock feature that allows you to lock the keyboard. It can inadvertently be set as a result of the consumer pressing and holding the wrong buttons and during power interruptions. You need to refer to the owner's manual under the Operator Controls section to see which buttons you need to press and hold to turn the feature on/off. If you no longer have an owner's manual, please post back with your MODEL NUMBER, so that I can provide you with a more conclusive solution. To answer your initial question, the oven SHOULD still be operational, but it needs to be unlocked in order to fully determine this. I hope this helps you.
NOTE: On many microwave oven models simply pressing and holding the CANCEL/OFF button for 3 to 5 seconds will turn the lock on/off. If not...please let me know.
Posted on Jan 19, 2010
Kenmore Elite Microwave Model No: 79080373310 giving E-11 error code
I do not know what an E-11 code is on that unit. But the fact you say no buttons are working gives me a clue that you may have a bad touch panel. Could be a Goofed up Microprocessor on the board. A Lot of units will give a code for a bad pad. If an air pocket in a pad colapses, the microwave thinks you are pushing and holding down a pad, so it will give a error code. An E-11 code may mean a bad touch panel on your unit. Try to unplug the unit, give it a minute and plug it back in, try to set the clock first and see what it does. When setting the clock try all of the number pads and see if they all respond. If one doesnt that mey be your bad pad. Or if a number comes up on its ownwithout pushing it, that pad could be shorted.
Aug 18, 2017 | Kenmore Microwave Ovens
F80 code on Kenmore Elite Microwave/convection oven....I keep getting error code F80 and the microwave stops working. Any way to fix this myself without calling a tech?
microwave ovens are simple radio transmitters , putting out high intensity radio waves in the oven
so unless you are a radio tech or fully trained in microwave ovens, it will be cheaper to take it in for a proper diagnosis and quote
not what you want to read but generally if the unit will not work, the cheapest fix is a new unit
Feb 28, 2017 | Kenmore Microwave Ovens
FFFF error code on convection preheating
F is for fan. Why is your fan not doing its job I ask?
Jan 13, 2015 | Panasonic Microwave Ovens
How do i operate the convection part of model 863-5973-50 jcpenney microwave
Press convection button, then press button with temp you want, then press start to preheat. Once preheated, either press cancel once, to allow time to be input, or engage door button, an press Time and enter your cooking time. Then press start again
Nov 18, 2012 | Microwave Ovens
What does F2 mean?
The error code F2 on your GE microwave indicates "Shorted thermal sensor", this condition will occur if a shorted thermal sensor is detected continuously over 5 seconds on convection, combination or roast cooking.
. It takes a minimum of 5 minutes of convection run time before this code will be
displayed. More information on this error code, as well as other error codes, can be found at
http://www.applianceaid.com/micro_faultcodes.html#gemicro
Best of Luck with your microwave.
Jan 25, 2011 | GE Microwave Ovens
Kenmore Elite micro/convect model 64289. Convect not heating...F1 error
F 11 code. it is a touch pad error.
if you just cleaned the control panel it may have water in the panel causing a key to stick.
If after a day or 2 it hasn't dried out - then you will need to replace the touch pad.
Visit www.searspartsdirect.com and enter in your full model number for a parts breakdown and schematics.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 18, 2010 | Kenmore 63672 Convection/Microwave Oven
Sharp Carousel Convection Microwave R-9H56 suddenly stops heating
at highvoltage section wiring may bae problem, check wiring and connectrors of magnetron and capacitor and transformer.
Dec 11, 2007 | Sharp R-510HW Microwave Oven
Microwave Ovens Logo
97 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
