Question about Ariston Technologies Ariston FO98P Stainless Steel Electric Single Oven
When fridge/freezer switched on, power trips - Ariston Technologies Ariston FO98P Stainless Steel Electric Single Oven
Have a BEKO TZS490 Freezer. It is tripping my House RCD . is there a fuse in it, (other than the plug)?
no fuses
the tripping of the rcd indicates a dead short or faulty insulation of the unit
check the power lead to the unit for broken wires
other than that it is possible that the compressor motor has burnt out
call a technician for an electrical check
Jan 13, 2017 | Ovens
My range oven has tripped the power and now it's not heating up. However this grill is still working. What could be the problem?
one of the elements has gone
this tripped the power off
now the element is prob switched off
if you switch on the unit again it will trip or not work and do nothing to the power
you need a new element
try ebay if you want to do it yourself
usually one screw and two connections per element
{power off at the mains to the unit}
or what i would do is buy the element and get a tech to do it
saves time and added cash they will add to the cost of the parts
Apr 19, 2015 | Ovens
Lamona fridge freezer
check that the temp setting knob has not been turned to zero for the fridge. The light is only to let you see what is inside the fridge and is not an indicator of the fridge working.
Jun 26, 2013 | Ovens
The oven trip switch was tripped last night. After I swirched the switch back on the oven won't work. The lights and the stove are both working and the gigital screen is working.
If you were using the oven at the time it is likely that a short circuit occurred in the element causing the circuit breaker to trip. After switching it back on the oven wont work. You probably need to replace the element.
The switch may have tripped for another reason. If it did when you turned the power back on the electronic clock/timer generally reverts to the auto. function. You need to set the clock/timer back to manual so that the oven will work.
Feb 10, 2011 | Bosch Ovens
Went to switch oven on fan works when you turn the temp knob it trips the trip switch every time help
HI, Sounds like your from the UK
If you are referring to a trip switch as being equivalent to an American circuit breaker. (Electrical safety device designed to shut down power to an electrical appliance). Then we are on the same page.
Do the following diagnostic procedure:
1 SHUT DOWN THE POWER SUPPLY TO THE OVEN. I.E. THE TRIP SWITCH/CIRCUIT BREAKER.
2 Open the oven door and look very carefully with a flashlight at the heating element. Look at the the entire element. If it blew (similar to when a light bulb blows) you will
find white powder around the hole in it or it will be completely broken, or have bubbles in it. Some indication like that. If so it has failed and must be replaced. It is probably tripping the switch because it is shorting out somewhere. There is also the possibility that the internal wiring connectors to where the element is mounted into the oven walls is broken off and short circuiting against the oven chassis (walls). That being the case, it may be just a wiring repair in which you install new appropriate electrical contacts and re-connect the element.
Hope this helps,
Happy New Year,
Mark
Dec 31, 2010 | AEG B3101-4 Electric Single Oven
Power tripping off at mains when switching oven on
It will probably be the main oven element that has failed.
This is located at the rear of the inner oven compartment behind a removeable cover.
Jun 03, 2010 | Neff B1641 Single circotherm super...
Our power went out tonight for 20min and after it came back on, the light and temp displays in our Frigidaire fridge/freezer does not come on. The freezer light appears to be working and it sounds like the...
Your display panel went out and needs to be replaced. This is a fairly easy part to replace. Just call us and we'll ship your part out asap!! We look forward to working with you!
Oct 18, 2009 | Frigidaire FEB27S5A Electric Single Oven
GE Monogram Fridge/Freezer
A frosty freezer in the back panel is an indication of a defrost failure issue. Problem may lie in the the control board, heater or defrost terminator. The problem usually is a broken defrost element. Hope that helps :)
http://tclaundryrepair.com/
Feb 25, 2009 | GE Monogram ZET3058SHSS Stainless Steel...
Oven keeps tripping when switched on
The reason why you oven is tripping is because the oven element is most likely burnt out...
The electricity supply going out should not have affected this... it is easily replaced and is not to costly..
Jan 30, 2008 | Ovens
Ariston Technologies Ariston FO98P Stainless Steel Electric Single Oven Logo
22 people viewed this question
Top Ariston Technologies Ovens Experts
ashburton
Dan Webster
Dan Webster
Are you an Ariston Technologies Oven Expert? Answer questions, earn points and help others
