Question about Nikon D5100 Digital Camera
Nikon D5100 Built in flash won't pop up
Won't pop open on any setting. Shoe is hot and works with other flash
    Top Expert:
  • Nikon Master
  • 6,702 Answers
Not even when you press the button on the left side of the class? the one with the flash symbol.
Switch on the camera and then press the button.
Look in the manual how you can setup the flash in all other than the automatic mode.
Posted on Nov 27, 2013
robmcd27
  • 423 Answers
SOURCE: Nikon D40 built-in flash...
Hi and thanks for coming to FixYa.
You can set the parameters for the manual flash in the Custom Settings Menu. Select Full to set the manual flash adjustments.
Hope this helps. Let me know if you have any questions in a comment.
Rob
Posted on Feb 27, 2009
  • 8 Answers
SOURCE: nikon d40 built in flash not firing but it popped up
there is a sensor in there that tells the camera the flash is up you need to take it to a repair shop its not a at home thing
Posted on Mar 20, 2009
  • 148 Answers
SOURCE: Nikon D40X built in flash doesn't pop up automatically
This is a common fault with the D40x. You will need to contact Nikon for repair details.
Posted on Apr 02, 2009
SOURCE: I got the nikon D5000 on christmas day and as of 3
Hey check out this video. the solution to the d5000 is same. the hook is a bit different though on the right.
Posted on Jun 13, 2010
  • 61 Answers
SOURCE: I have a Nikon D80 and I hit the open flash and
Contact your local Nikon authorized service center for repair on this issue. If you're in the east coast or in the New York City area you can contact us for this.
Hiram
Photo Tech Repair Service
110 East 13th Street
New York, NY 10003
212-673-8400
Posted on Jul 06, 2011
Which of the following Vivitar flashes will work on a nikon D5100? Vivitar auto thyristor 2800 or vivitar electronic flash 1900?
they should both fire, but they were not meant for modern digital cameras, and the auto features the the camera may have won't be able to control this flash. so it just a manual strobe, to set your camera on manual and experiment.
that little pin on the bottom as well as the 2 on the inside of the flash shoe should fire the flash.
good luck.
Sep 13, 2017 | Nikon Cameras
Nikon D5100 camera flash does not pop-up. Any suggestions?
You can't pop up the flash in the Auto mode. In this mode the camera decides whether to use the flash or not.
Try switching to one of the PSAM modes. Does the flash then pop up when you push the flash button?
Jan 17, 2014 | Nikon D5100 Digital Camera
Nikon D90 flash will not pop.
I suggest you take your camera to a Nikon camera repairer.
Apr 18, 2013 | Nikon DSLR D90 Digital Camera
T3 built in flash won't pop up. Says I have an external flash attached, but I don't.
There is a small flat leaf spring under the hot shoe rail where an eternal flash slides in. If an external flash is mounted the leaf spring is pressed against a small button telling the camera that there is an external flash mounted. Take a toothpick and rub under the hot shoe rail gently to more the leaf spring or unjam the leaf spring. You may even see the button depressed, poke at it a time or two with a toothpick, even a drop of rubbing alcohol may unstick this button if a sticky beverage sprayed on it.
Dec 25, 2012 | Canon EOS 1100D / Rebel T3 Digital Camera
D90 Built-in flash won't fire
Go in menu go to bracketing /flash then set for TTL
you should work to test leave lens cap on push button on left side with lightning bolt on it.
Oct 18, 2012 | Nikon DSLR D90 Digital Camera
Can i use the nikon sb50dx flash with the nikon d5100
Yes, you can use the SB50DX on the D5100, however not in the TTL modes. It will only work in the manual or rear-curtain sync modes. For more information, look on page 204 of your camera's manual. You can download it for free at this link: https://support.nikonusa.com/app/answers/detail/a_id/17325
Jul 09, 2012 | Nikon SB 50DX - Hot-shoe clip-on flash -...
Can I use one nikon d5100 with one sakar mc zoom 80-200 No. 803489
If your lens has a Nikon mount then yes, you can use it on the D5100. You'll have to switch to the Manual exposure mode and you won't get any exposure help from the camera's light meter.
May 31, 2012 | Sakar "Digital Photgraphy Macro Ring Light...
My Rebel T1i's built in flash stopped working after I used a 580EX external flash on it. It won't even show up on the LCD screen.
Really? the best solution available is to take the top of your camera off?
i don't think so.
Here's a very simple solution I found to get the flash to pop up without destroying your camera.
http://forums.dpreview.com/forums/read.asp?forum=1031&message=31993875
the person suggests using a fingernail. (s)he must have long fingernails. I had to use a piece of paper folded in half. Swipe the paper from back to front, as in, from the eyepiece side towards the lens side.
Here's a picture: http://www.flickr.com/photos/dougpardee/133066175/
good luck
Sep 25, 2009 | Canon EOS 500D / Digital Rebel T1i Digital...
My powershot G9 built in flash is not working
There is a switch on the hot shoe to detect the external flash. When you use an external flash, the switch will be pressed down, then the unit will bypass the internal flash and won’t let it fire. If the little switch gets stuck somehow, you won’t get your internal flash on.
Check this switch on the hot shoe (either on the left side or the right side), blow some compressed air then plug/unplug an external flash several times. Hopefully you can get it back
Feb 06, 2009 | Canon PowerShot G9 Digital Camera
Nikon D5100 Digital Camera Logo
152 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
