Question about Garden
How do I get to the oil pump on a 025 - Garden
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
Remove the clutch assy
Posted on Nov 28, 2013
How to replace oil pump in stihl 031 chainsaw ?
Remove the worm, sealing ring and washer, loosen the pan head screws on the oil pump and replace. Check if the gasket is re-usable.
Jun 11, 2014 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
Can i use an oiler out of a stihl 025 in a stihl ms 362
no you cant use the 025 oiler in an MS362 they are two different styles of oil pump. here is the parts manual for the 362 so you can see the way you'd access it and get the part number. http://www.mediafire.com/download/fauw3x2hzwicxrz
Feb 03, 2014 | Garden
Oil pump does not work
Checlk the oil worm gear is driving the pump. If this isnt the problem then try the following:-
The type of oil pump fitted to these models is prone to getting blocked.
Remove the oil pump. The gear on top should turn freely, give the pump a clean and clean the oil pipe to the tank by removing the oil cap and blowing through with an air line. If the oil in the tank contains alot of dirt, empty/clean and replace. The filter on the oil is an open plastic cage type and often will draw large sawdust particles through it. Easily rectified tho.
Aug 24, 2012 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
Chain oil leaking on 025 stihl chainsaw
Their is a oil passage that has a plastic plug in it by the muffler. It might be gone like mine is.
Nov 29, 2011 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
I HAVE AN O17 STIHL CHAIN SAW AND IT LEAKS CHAIN OIL EVEN WHEN IT IS NOT BEING USED
That can happen. When you go to store it, open the oil cap and then close it to lose the pressure the pump builds up inside.
Oct 01, 2011 | Stihl Chain Saws, 017, 019, 021, 023 & 025
Ms 170 leaks bar chain oil out bottom, no oil on chain
Your clutch drum bearing has gone bad, letting the clutch drum to move around and cut into the oiler behind it, so now it just pumps the oil out that hole. You have to get that fixed to use the saw, otherwise you're going to cause catastrophic damage to the saw very soon.
Sep 25, 2011 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
Have a stihl MS180 and it is not pumping any oil out of the hole and slot that makes contact with the bar. How do you remove the oil pump?
To remove the oil pump you need the following:
Assembly tool 1123 890 2200 Removing oil pump Puller 1130 893 1400 Installer 1130 893 1500
I would recommend trying to clean out the oiler first.
Please comment on this and tell us what type of oil you were using. There are rumors of wrong oil clogging or wearing the oilers. Was it used motor oil? Thanks Joe
Feb 16, 2011 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
Bar not recieving oil
The problem is related to the internal oil pump. The followings are the possibilities:
  • Clogged line from the oil reservoir to the pump.
  • Clogged line between the oil pump and the chainsaw bar orifice.
  • Faulty oil pump itself (common in well used/old device).
Hope it helps.
Jul 28, 2010 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
OILER NOT WORKING
Poulan Pro 260 LE chain saw chain bar lube system is not working.
Mar 17, 2009 | Garden
Garden Logo
16 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
