Question about GE Refrigerators
Freeze temp is not holding zero - GE Refrigerators
    Top Expert:
  • GE Master
  • 12,962 Answers
When the compressor shuts off the freezer temps will slowly go up until the compressor recycles. The temp will not stay at a constant zero but fluctuate back and forth in accordance with compressor function. My temps vary from -2 degrees to about +4 degrees when the compressor kicks on again.
Posted on Nov 28, 2013
Freezer will not freeze ice ceam
Before you go any further it is important that you check for freezer temps. Yes, you have frozen items but remember that water freezes at 32 degrees and many items will get hard at that temp. And also remember that the lower the temp the longer frozen items will keep.
But ice cream needs proper freezer temps close to zero degrees. Use a digital thermostat and check for your freezer temp - bet it it is no where near zero. I had the same problem and attributed it to the fact that I was not using a name brand ice cream!!!! I was wrong ! LOL.
Aug 31, 2015 | Refrigerators
Is this a common problem?
THATS BECAUSE IN ORDER TO CONTROL BOTH TEMPS IT USES THE HELP FROM THE FREEZER AND FRIDGE THERMISTORS AND THE COLD CONTROL THERMOSTAT. A BAD DOOR SEAL OR SEALS CAN ALSO CAUSE SOMEWHAT SAME ISSUE? ALSO NEED TO CHECK UR DAMPER CONTROL MAKE SURE ITS WORKING CORRECTLY.
Jul 29, 2014 | Hotpoint Refrigerators
Ge bottom freezer not freezing
Check to see that the evaporator is not covered with layer of ice. The latter serves as an insulator and prevents freezer temps from going down to about zero degrees. If the defrost heater/timer is defective that will certainly be a cause. Since the freezer air is not cold enough to freeze, then the refrigerator temps are also high. Using a digital thermometer will confirm this.
Leaking door gaskets can also be responsible for higher internal temps
May 17, 2014 | GE GFSF6KKYWW 25.9 cu. ft. French-Door...
How to set temperature on GE Profile PSS26NGPA WW?
Press and hold temp up button then press quick freeze button at the same time, your temp settings will be displayed on display for fridge and freezer, fridge temp is + and freezer -, cycle by pressing quick freeze, set temps by up and down temp buttons, once done, push vacation button. your temps are now set, turn the unit off for 2 mins the turn on. reaction is now set and normal. regards Russ
Jul 03, 2012 | GE Refrigerators
How lpw of a temp. Can this freezer reach..and and if only 0 degree could the thermostat temp control be changed out so it could reach les than 0 temperatures like negative 20 or so?
There are different models made for holding different products. Yours has a 1/3 hp compressor for above 20 degs. It may have 0 on the thermostat and may well pull down that far, but -20 would be out of it's reach. Where as it's sister model is made to freeze to below zero has a 3/4 hp compressor. Larger compressor for the lower temps.
Sep 18, 2011 | Beverage-Air 44.9 cu. ft. / 1271 liter...
My Sub Zero Model 525 is starting to freeze drinks in the refrigerator section. We've turned the temp up and it's still doing it.
replace the cold control . and clean the coils and ck the fan that its running fast enough there famous for slowing down with age .. mm hope this helps .. and thanks for using fix ya
Oct 21, 2010 | Refrigerators
TV storage in sub zero temps
All electronics devices,can't be on exposer to cold 20 degrees or hot 110 degrees very long only a couples hours.Than the componnents on the pc board will malfunsctions or dies all together.Bring it with you and store it at 45-50 degrees should be no problems.
Apr 26, 2010 | Vizio VW22L 22 in. LCD HDTV
I need to drain and flush my car radiator outside the temp. is below zero would this be safe to do
It will be cold work, but as long as you don't let your vehicle sit with just the water and flushing solution to freeze (like a few hours) there is no hazard of damaging your cooling system. Safe conditions in below zero weather are as follows:
Vehicle running (it will produce enough heat to prevent freezing no-matter how little anti-freeze is in the system while running)
Coolant system drained - if there is no water in the system to freeze - no hazard.
Coolant system filled with the appropriate amount of anti-freeze solution in the coolant.
Make sure you take adequate protection against the cold for yourself too!
Jan 03, 2010 | Dayton Electric Heater
Sub zero 700 TR error code 06
Error code six means: from SZ
Refrig. evaporator thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
Erratic temp can be many things such as an open door. Clear the code by holding the bell key for 15-30 seconds or until you hear a tone. Keep an eye on your temps for a couple of days. If it comes back its time to call a service tech. If you are in OC I have the number of the best tech for Sub Zero in all of SoCal. There is more tests that can be done depending on how tech savvy you are.
Jan 21, 2009 | Sub-Zero 700TR
Refrigerators Logo
63 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
