Question about Euro-Pro 605 Mechanical Sewing Machine
Grears are tight - Euro-Pro 605 Mechanical Sewing Machine
What to do if sewing machine is puckering?
Depends on why the seam is puckering. Read this: http://www.amefird.com/wp-content/uploads/2010/01/Minimizing-Seam-Puckering-2-5-10.pdf
Offhand, it sounds like you need to reset the top tension properly.
http://quilting.about.com/od/piecingtechniques/a/How-to-Adjust-Sewing-Machine-Tension.htm
The top two photos here are the upper and underside of a single ply of muslin sewn with a balanced tension. The blue thread is on top, red in the bobbin: http://www.picturetrail.com/sfx/album/view/22521551 -- that will give you something to shoot for.
Jun 12, 2014 | Kenmore 19233 Computerized Sewing Machine
The top tension is very tight
check that there are no pieces of cotton or other matters stuck. Turn the tension to its most loose position and by hand move a string of cotton through the tension slot. If it feels tight, remove any foreign matters and then slowly tighten it again to suit your needs..
Jan 12, 2014 | PfaFF Creative 7570
I have a singer Sew Mate 5400 and the top thread gets so tight
Ok, you definitely have something going on. So you'll need to try the following.
1. Re thread the machine making sure the presser foot is in the up position.
2. Make sure your needle and thread are the right size for each other.
3. Check that your thread spool or spool keeper disk doesn't have a burr that is catching the thread.
4. Make sure the thread isn't wrapped around the thread spindle.
Aug 15, 2012 | Singer Sewing Machines
How do I get Featherweight out of first gear?
Hi, unless you have thread caught up in the hook area the problem may very much be that the belt is too tight. It should be seemingly loose or just tight enough to turn the machine. There is a big screw to the motor mount. Loosen the motor and adjust it to loosen the belt. Belt too tight and slowing machine is common issue.
Rick
Jun 06, 2012 | Sewing Machines
Why is the hand wheel of my new consew 206rb-5 so tight? the machines hums when sewing, like beeind forced, is this part of the breaking in?
contact the one you bought the machine from & tell them how
tight the hand wheel is & see what they recommend
Jun 04, 2012 | Consew Sewing Machines
The stitch is to tight can't get it even
Most likely the upper tension dial is too high. Turn it to 4 and try pulling the thread through the needle and see if it moves easier than before. If not turn it to 3. This should be a good tension on your upper thread so it won't make the stitch so tight. Also, be sure that the thread spool holder isn't too tight against your spool of thread. Let me know if this works.
Sep 10, 2010 | Brother Sewing Machines
I just replaced the belts on my Necchi 535FA, but
If the belts are not tight enough they will slip, they should all be fairly tight but not like a piano string if you know what I mean.
As you do not describe what the machine is doing wrong I can not really say any more at present, except make sure there is no oil on the belts and the machine has no tight spots when you turn it over by hand.
Jul 07, 2009 | Necchi 6015 Mechanical Sewing Machine
Euro-Pro 605 Mechanical Sewing Machine Logo
18 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Derek Massey
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
