Question about RealWorld Graphics RealWorld Icon Editor
How to get rid of the liscence
I have a problem i got realworld icon editor but it expires and needs a liscence. Is there like a file i can delete to make the program free?
How to remove icon from pc destop screen
right click on it and then delete or remove
May 22, 2012 | E-Machines Computers & Internet
Tip
How to install a trial version of software again when its 30 day trial time...
PROCESS TO INSTALL A EXPIRED SOFTWARE AGAIN.
Sometimes it happens that by chance we get some software which are not very popular but excellent in their utility in that case we are not able to get the serial key or crack of that software.Then we have to use the trial versions with no any other option.
Note:-
1 This tip works only for that software which asks for path or provide opportunity to install software in any other place then program files in c drive during time of installation of software
2 Careless registry editing can cause irreversible damage. Thus,performing backups of the registry before editing it is highlyrecommended by Microsoft
STEPS TO PERFORM THE OPERATION
1 UNINSTALL THE SOFTWARE WHICH HAS TO BE INSTALLED AGAIN.
2 TRY TO INSTALL THAT SOFTWARE AGAIN BUT CHANGE THE PATH FROM THE PREVIOUS ONE.IT WILL BE BETTER TO USE SOME OTHER DRIVE ALTERNATELY.
IF IT DOES NOT WORK THEN
USE THE REGISTRY EDITOR OF WINDOWS OR TUNE UP UTILITY SOFTWARE ( http://www.tune-up.com )
3 FOR OPENING WINDOWS REGISTRY EDITOR TYPE REGEDIT.EXE IN RUN (FOR XP USERS)
VISTA AND WINDOWS 7 USERS CAN GET IT BY TYPING IN SEARCH REGEDIT ONLY
4 OPEN THE TREE BY DOUBLE CLICKING THE HKEY_CURRENT_USER (HKCU) FOLDER PRESENT IN THE LEFT SIDE AND UNDER THAT AGAIN DOUBLE CLICK FOLDER NAME SOFTWARE . LOCATE THE FOLDER OF THE SOFTWARE WHOSE TIME HAS BEEN EXPIRED (IT MUST BE PRESENT THERE WITH THE NAME OF THE SOWTWARE OR BY ITS VENDOR NAME) AND DELETE THE WHOLE FOLDER FROM THERE.
5 HKEY_LOCAL_MACHINE (HKLM) REPEAT THE STEP 5 IN THIS FOLDER TOO.
6 CLOSE THE REGISTRY EDITOR AFTER DOING STEP 4 AND 5.
7 SERACH FOR THE FOLDER WITH THE NAME OF THE SOFTWARE OR BY THE VENDOR NAME IN APPDATA AND PROGRAM FILES ALSO
8 IT MUST BE IN THE C:Users<USER NAME>AppData, AND C:Program Files
LOCATE AND DELETE THE FOLDER FROM HERE ALSO, IF IT IS PRESENT.
9 NOW INSTALL THE SOFTWARE AGAIN AND CHANGE THE PATH FROM THE PREVIOUS ONE .
10 NOW YOU ARE READY TO USE THE EXPIRED SOFTWARE AGAIN.
on Dec 17, 2009 | Computers & Internet
RealWorld Cursor Editer When I save custom colors in Swatches, certain colors won't allow the saved file to load. I get an error code 0x80004005. Any way to fix this? It's a real pain to have to...
Try opening the saved file in Notepad. Maybe the problem would be obvious. Otherwise, if you paste the content of the file here as text, I could have a look.
Sep 10, 2011 | RealWorld Graphics RealWorld Cursor Editor
How to replace missing cmicnfg.cpl file
This error occurs after trying to uninstall the updated (and overrated) C-Media WDM Audio Driver for onboard sound that appears after upgrading to XP SP2 and/or going to WindowsUpdate. Likely the driver didn't work, so you tried uninstalling the driver and were going to put back the old Realtek AC'97 driver, but couldn't get rid of the updated driver.
To fix: Start, Run, type in "regedit" (no quotes), and delete the cmaudio string from
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run. This makes it so it will not run on startup and try to find the cpl file that was deleted during the uninstall or not installed correctly by the installer in the first place, whichever your case depending on when you started seeing the error. If your sound was working perfectly before this, you are done. To get your sound working again if it isn't, read on -
While still in the registry editor, click on the top computer icon in the Registry Editor to highlight it (so that it will do a complete search of the registry and not just from your present point forward), do a Find (Ctrl+F) and find and delete all KEYS related to cmaudio and C-Media, not just the string entries, but the KEYS, except for that entry in the Run key I mentioned above, just delete the cmaudio string for that one.
Delete the string "CMCPlus" from HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Control Panel\Cpls to get rid of the Control Panel icon, and delete the file it points to that resides in C:\Windows\System32.
Download this remove utility from
http://ekiis.com/Freesoft/binary/remove11.zip
and run the file you find in the zip file - it can be ran without extracting it from the zip. Take out the C-Media Audio Driver line.
-- NOTE: This utility is for taking the name out of the Add/Remove Programs section only, and does not remove it from your computer, but it is very useful for issues like this when we are MANUALLY uninstalling a program to take it out of the Programs list and should work in 98/ME/2000/XP.
Delete these files from the C:\Windows\System32 directory (or "System" directory for Win98)
cmirmdrv.exe
cmirmdrv.dll
cmuda.dll
Delete everything you can readily delete in C:\Temp, C:\WINDOWS\prefetch (XP only), C:\WINDOWS\Temp, and C:\Documents and Settings\%YourName%\Local Settings\Temp (2000 and XP only), so that there will not be any files left for it to try to recover the driver from. You will likely have to leave things that start with hsperfdata_ and Perflib_Perfdata_***.dat files if you find them, but should be able to delete most others without changing attributes.
Now open the Device Manager (Right-click "My Computer", hit "Manage", then find Device Manager in the Computer Management console). Right-click the C-Media WDM driver under Sound, video, and game controllers, hit Uninstall. Then right-click the top computer icon listed there with your hostname beside it, hit "Scan for hardware changes". It should install a generic "Multimedia Audio Controller" instead of the "C-Media WDM Audio Driver", though you might see that C-Media Audio for just an instant before it reverts back to a generic driver (if it stays, you'll have to go back through the registry again, delete the system files again, and do a full search of your hard drive for those files so they don't get re-copied again). From here you can download your specific Realtek AC'97 Audio Driver setup.exe file here or use your motherboard's installation CD to re-install and you should have sound again.
good luck!!
pls feel free to visit my blog http://manual4users.blogspot.com
thankz!
Oct 07, 2009 | Computers & Internet
Can't get rid of bloodhound pdf 8 and now I can't get into my user profile
You are going to have to get your hard drive wiped and windows re-installed then you will be able to have your computer up and running again!
May 07, 2009 | Computers & Internet
Icons are clutataering up my home page and I want to delete them
delete your temp files
start/my computer/search (*.temp)
edit/select all
file/delete
any files needed to operate your system will not delete
May 04, 2009 | Google Chrome
All my songs say liscence expired
The license on the songs that you have transferred to your mp3 player have an expired DRM license. The only way to "unexpire" the license is to refresh your license through the music service that you downloaded the songs from. If you have let your subscription lapse, the licenses will stay expired.
Mar 02, 2009 | Sony NWZ-E436F MP3 Player
Spyware InstantShare removal
HI
go to start , run , type in regedit.exe
Registeration editor is displayed
go to HKEY LCM _MICROSOFT_WINDOWS/WINDOWSNT_UNINSTALL
Delete the uninstall entry. now go to search in the registery and delete all keys by typing the name and click search and delete.
Now delete all the program files that were installed with the programs
Nov 12, 2008 | Microsoft Windows XP Professional
Cant get rid of program
It may have put something into the registry so that it will always download and run on start up. You can try the following to get rid of it. 1) Open the registry editor. (To do this, go to Start -> Run and type: regedit ) 2) Browse to the following location HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run 3) Look at all the keys (items) in this folder. The program you are looking for may be listed here. If you find it, make note of where the file is located and delete the file that is mentioned in the key. Then delete the key. This will keep it form restarting after reboot.
Sep 18, 2006 | Dell Dimension 4600 PC Desktop
Deleting programs
Go To START > PROGRAMS > FILE EXPLORER Use File Explorer to navigate to My Device\Windows\Start Menu\Programs and delete the icon from there. - click and hold and then you'll see the DELETE command.
Sep 08, 2005 | HP iPAQ RX3715 Pocket PC
Computers & Internet Logo
22 people viewed this question
Top RealWorld Graphics Computers & Internet Experts
David Payne
David Payne
Are you a RealWorld Graphics Computer and Internet Expert? Answer questions, earn points and help others
