Question about Zebra 105Se Thermal Printer
Calibration Printer prints 1 label, skips 5, have to reset head, skips 2 labels, prints 1 label, skips 5 and so on
itdude4321
  • 13 Answers
SOURCE: TLP 2844 skips over labels
The first thing I would do is to default the printer then run a width calibration. The instruction are in the user's manual that should have come with the printer. If the instruction did not come with the printer I can provide the instruction.
Posted on May 08, 2008
  • 5 Answers
SOURCE: Printer = Zebra TLP 2844-Z Problem = will not calibrate
just switch off the printer ,and then hold the green button power on the printer now and wait upto 4 bliknks of green led then remove the fingers.now printer will calibrate the label..
if still the problem exist .check the notch in the ribbon core.an adjust the spring tenson of rippon supply and take of roolers in printer
Posted on Dec 05, 2008
SOURCE: TLP 2844 skips 15-16 labels then prints intended label
It sounds like they may need to set their "Q" values for the labels they are using.   If that isn't it, we may need more info - are they using Zebra brand or custom labels?
To start with, I would ask them to try adding these "Q" value commands: q456 Q152,24
If that doesn't work, then maybe they can provide the other info mentioned above so we can understand the problem better.
Posted on Jan 05, 2009
jwr1914
  • 31 Answers
SOURCE: Zebra 105SL label issues
I am surprised that you are using that sequence of buttons to solve this problem. I am pretty sure that they want you to go into the "Media Sensor Calibration" setup in the config menu. It is a bit more complicated than what you have described. I also believe that the size of the gap on two of your labels might be out of tolerance (they are usually 1/8" gaps between the labels). The black marks are a problem for the transmissive sensors. You may need to move the transmissive media gap sensor (remember it has two parts: upper and lower). I would usually setup mine for a place beyond the black mark so that you are looking at just the white paper.
To start out:
1. Load the backing of a 6" strip of media (no label attached).
2. Remove a ribbon (if you usually use one).
3. Close the printhead.
4. Press SETUP/EXIT and then NEXT/SAVE until "Media and Ribbon Calibrate" appears.
5. Press "+" to start the calibration procedure. You should see the "Load Backing" in the LCD Display. You already have the backing loaded so continue to the next step.
6. Press "+" to answer the message and the next screen should say, "Remove Ribbon". You have also removed the ribbon.
7. Press the "+" to continue. You should see the screen say, "Calibrating Please Wait". After the sensors are setup by the machine a new screen should appear, "Reload All".
8. Open the printhead, and move the labels until they are loaded correctly to print. Smooth out the ribbon and load it correctly.
9. Withe media and ribbon now loaded, press "+" to continue and the machine should say, "Media and Ribbon Calibrate".
10. Press the Setup/Exit button once. It should say, "Save Changes Permanent". Press Next/Save to finish the process.
11. Do a normal calibration of your stock and print a label.
You are done. The machine will run for the labels you have setup the sensors for. Unfortunately, you must do this for each of the media types. To automate this, you could run a Configuration listing, capture the settings you just created for each type of label. Take these to a programmer to have them send the setup to the machine before the job. This is beyond the scope of this type support to really help you.
Posted on May 29, 2009
  • 31 Answers
SOURCE: Zebra 2746e will skip leaving a blank label while printing.
You need to calibrate. Hold down the feed key while powering the printer on, then let go. The printer will calibrate, print a config label, then fo into dump mode. Press the fee key again to go out of dump. Of your issue persists, there could be a problem with yoru media, or with the commands that you are sending to the printer.
Posted on Jan 31, 2010
Advancing blank labels inbetween printing
Do you use adhesive labels? It looks like the printer is unable to make the difference betwen the labels. Verify that the printer it's not set on Continuous mode for the media type. Verify if there is any label (or pice of label) stiked on the upper media sensor (gap sensor). You can locate the upper media sensor using the User Manual (page 74). There is an User Manual available for download from Zebra website. You will find there precious information. The manual is very explicit and you will learn how to maintain your printer and how to troubleshoot some common errors. Clean your printer, assure to put the supplies on the right path, close the printhead and press Pause to enter in Ready state.
You can clean the sensor with an coton cloth dampened into isopropylic alcohol.
Here is the link to user manual:
http://www.zebra.com/content/dam/zebra/manuals/en-us/printer/105sl-ug-en.pdf
Dec 03, 2013 | Zebra 105Se Thermal Printer
Skipping labels
Nov 27, 2013 | Zebra 105Se Thermal Printer
Printer TLP2824 thermal printer prints too many labels. Prints one and then spits two more out(blank).
Clean media sensors. The blank labels are a result of the printer trying to calibrate label length.
Aug 12, 2013 | Zebra TLP 2824 Printer
Dmx i4308 skipping every other label
emelish: If is constant the print label and skip label, you have adjust the label size in your software. If the label skip is not constant, then clean the label sensor, position it in better place and perform a quick calibration pressing and hold FEED button by 5-6 seconds and release it. Maybe you can do it once more time. Roberto Martinez
Sep 02, 2011 | Datamax DMX-I-4208 Label Printer
Zebra stripe s500 skips 5 labels prints 1 skips 1
He are the steps you need to calibrate your printer
Label Length Calibration
Note: This is typically the only procedure required when first installing the labels.
1. Load the printer with media and ribbon.
2. Press the printer front panel MODE key until the CALIBRATE LED is lit.
3. Press the FEED key and allow the labels to feed.
4. When the labels have stopped press the MODE key once to save the value in memory.
Jul 10, 2009 | Zebra Stripe S500 Thermal Label Printer
May 28, 2009 | Zebra 2746e Thermal Printer
I get 2 labels(1 with data and 1 blank)for every label printed
THE LABEL SENSOR IS NOT SENSING THE BEGINNING OF THE NEXT LABEL
Clean the photo eye that senses the label gap with a q tip and alchol
Open side door release print head and remove label stock you will see small photo eye clean
put printer in manual mode( switch 1 on to and 1 on botom on
turn printer on it should advance one label and hit skip it should advance another
put back in computer mode
should work now if it still skips check yur label desigh=n software and label mode (continuous or sense label)
Best of luck to you
Dec 29, 2008 | Intermec EasyCoder 3400 Thermal Label...
Dec 04, 2008 | Zebra 110Xi III Plus Thermal Printer
Zebra 110XiIIIplus printer
Turn the Printer off and turn it back on. See if it skips a couple of labels. If it does not the printer needs to be calibrated.
Press the Setup/Exit Key and the press the Next Key until you see Media Power UP: IT should say Calibration if it don't then use the arrow keys to get to Calibrate press the Next key again and you will see Head Close select Calibration using the same method mentioned above. After that Press the Setup/Exit Key and Save Changes Permanent. Turn the printer off and on again and the first 2 labels should skip while the printer aligns the media.
Test Print and see if that fixes the problem. Good Luck
Sep 29, 2008 | Zebra 110XiIIIplus Direct Thermal/Thermal...
May 07, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Zebra 105Se Thermal Printer Logo
37 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
