Question about Microsoft Windows XP Home Edition
Cadac Global Grill Code 7600 - Microsoft Windows XP Home Edition
  • softvar Dec 26, 2014
    Hi Alan Jackson, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    what exactly is the Cadac Global Grill Code 7600
    doing wrong for you? what did you do before you saw the error code? is it still happening?
    good luck
My cadac is burning black smoke
Check the venturi tube just behind the control knob and before the burner tube. You will probably find it full of spiders nests. You need to introduce air to the gas and that is where it is regulated.
Jun 04, 2016 | CADAC Safari Chef 6531 Grill
Which gas is recomended for use on a cadac eezy chef as mine is generating black smoke on propane
You get black smoke - and other unwanted & unexpected effects -
'cause 'false draft' occurs during mixture process in the venturi pipe,
PREVENTING THE BURNER FROM 'INHALING' ITS SPECIFIED
PERFECT COMBUSTIBLE HIGHLY CALORIC GAS/OXYGEN MIX.
THIS MIXTURE PROCESS CAN BE IMPROVED BY FOLLOWING
THE INSTRUCTION AS OBSERVED IN THE YOUTUBE VIDEO
'THE CADAC LEGEND',
AS PUBLISHED AUGUST 15, 2011.
May 03, 2011 | CADAC Safari Chef Portable Grill
How do i clean the grill normal scourers does not get it clean
Go to the hardware and get a good stiff wire brush. That will get you cleaned up.
heatman101
Aug 19, 2010 | CADAC Safari Chef Portable Grill
Cadac Carri Chef bbq replacement gas valve.
Remove grey plastic cover by removing two screws inside cooking area, then pop handle off valve, undo nuts to release valve body, carefully remove two screws in body, watch out for spring!
Take the small hexagon jet out of other end, find a small straight item that will pass through hole where jet was, tap the internal part out of the main body , clean everything up, probably carbon on it! Apply a tiny bit of oil to the plug you tapped out, avoid the tiny hole in plug! Now reverse the strip down, making sure that the valve goes back together the right way and still turns through right sequence! Normal cause of it sticking is not pushing it in whilst turning off!
Email me at grundy
Oct 08, 2009 | CADAC Safari Chef Portable Grill
Were do the parts go on the cadac bbq
hi i need a new gas igniter for my carrie chef, can you tell me where i can buy one
Jun 15, 2009 | CADAC Safari Chef Portable Grill
How do I use a Cadac smoker.
The cadac smoker cooker is probably the easiest to use. Lift all the inside bits out and put about 3 desert spoons of wood chip for smoking on the big plate at the bottom. Return all the other pieces except the lid. Use the low gill for chicken and bigger pieces of meat and the tall grill for flat pieces of meat and fish. It takes about an hour and a half for a chicken. Hope this helps.
Michelle.
May 02, 2009 | CADAC Grilling
Cadac safari chef
Hi Paul
I asked the same question and found this web site which sell a propane regulator.
http://www.flogas.co.uk/buy-online/gas-barbecues/cadac-carri-chef-deluxe-combo-8150/
Cheers
Sepp
Jun 11, 2008 | CADAC Safari Chef Portable Grill
Microsoft Windows XP Home Edition Logo
53 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
