Question about Alarm Remote Casecover Accord Odyssey 02 03 04
Car wont start dont turn doesnt make any noise
It was running
  • Honda Master
  • 20,706 Answers
This is called, NO CRANK.
no engine can start if it can not crank.
(exception M/T tranny push started in 2nd gear)
what year, (exactly)
is the immobilizer happy? (dash light for same tells you)
no crank are:
1: dead /bad or discharged battery (or main lugs rusty (corroded)
2: bad starter.
3: bad key line
jump start car, with jumper cables. or try a fresh charged battery.
if that fails , hot wire the starter solenoid, (it will crank and not start, key in pocket , hand brake set and wheels chocked)
no crank, now ? bad starter
yes crank now,, bad key line.
the above steps find the fault or lead you the pesky key line.
hint1: wiggle tranny shifter as you crank, (key) or try starting in neutral.
hint2: hit side of a starter motor to wake it up.(can save a life)
buy a volt meter.
Posted on Nov 28, 2013
Turning over but not starting
sounds like a faulty starter possibly the selinoide on the starter
Mar 03, 2014 | Kia Sephia Cars & Trucks
1984 300zx non turbo......the car was running fine and then it wont start. it has spark. and i disconnected the fuel pressure regulator and turned it over and fuel comes out of the fuel lines going to the...
if the car has been sitting up for a while like months or a year or so , its possible that the fuel pump stuck, the gas now a days is very bad about turning into lacqure like substance an that could be the problem? you need to check fuel preasure, autozone will loan you the tool to check it with, just leave deposite, at least you can rule out that much, also check the fuel pump relay could be sticking good luk
Nov 28, 2010 | Nissan 300ZX Cars & Trucks
My car doesnt start its not the battery and i
possibly a faulty solenoid or maybe your car has not recognised the signal from your key and the anti-theft system is blocking you, from starting.
Jul 06, 2010 | 1998 Mitsubishi Diamante
2004 Saab 93: A/C doesnt turn off, car now wont start
remove the AC relay to shut the AC off all the time. Not sure why it wont start but you may havea security lockout. Fully charge the battery to proceed.
May 31, 2010 | 2004 Saab 9-3
2002 renault scenic wont start, turns over ok but wont fire
hi
if it has the 1.9dci engine there is a small low pressure fuel pump below the car tucked in behind the front sub frame. its about the size off a redbull can with a pipe at either side. turn the ignition on and listen for a buzzing noise almost below drivers footwell. if you dont here anything your pump has gone. new pump costs around £100 but if the car is worth fixing it is a good investment.. dont bother with 2nd hand because they give ALOT OF BOTHER.
Jan 29, 2010 | Renault Sportwagon Cars & Trucks
I forgot to put oil into my engine now my chrysler grand voyager is not running right now,it is now making a tapping noise,do i need a new engine and how much will it cost
When you say "tapping noise" it names off several problems, please clarify :)
- Can the car "turn over" (aka try to start)
- What do you mean it "doesnt run" it wont start - or - does it not drive forward/backward (but will start)
- When does this tapping noise happen?
- How hard do you drive the voyager?
- Can you do your own mechanic work (for small - medium sized projects)?
Apr 04, 2009 | 2000 Chrysler Grand Voyager
1997 Mazda Protege LX 1.5
replace the fuses and check all the wire connections unter the dash by the pedals and under the hood if that doesnt work get your computer checked
Apr 02, 2009 | 1997 Mazda Protege
Grand cherokee 1999
1. is the engine turning over. If it is then you probably have a timing/fuel problem.
2. If all you get is a click sound and no engine turn over then flat battery could be a starting point.
3.if it starts and runs rough plugs and or plug leads may need looking at. Or maybe fuel injection system.
4.Not enough information to get more specific.
Aug 24, 2008 | 1999 Jeep Grand Cherokee
Alarm Remote Casecover  Accord Odyssey 02 03 04 Logo
88 people viewed this question
Top Honda Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
Spud Howell
Charles T Nevin
Charles T Nevin
Are you a Honda Vehicle Part and Accessory Expert? Answer questions, earn points and help others
