Question about HP LaserJet Office Equipment & Supplies
The printer is telling me to replace Printhead
Hplaserjet6500A
    New Friend:
    Problem Solver:
  • 14 Answers
So replace the printheads. They do go out just like the ink cartridges do and need to be replaced.
Posted on Dec 03, 2013
How to take out printhead for Dell P703w user guide
Remove the cartridges as you normally would. Then instead of replacing an empty cartridge, lift the latch on the top of the printhead. Now pull the printhead up and out of the printer. For pictures see the User Guide section on replacing the printhead: http://support.dell.com/support/edocs/systems/P703w/en/UG/maintena.htm#wp1187645 .
For some printers, you can clean the print head with bottled (or distilled water) and lint free clothes (Q-tips). Just dampen a bit, squeeze out the excess water. Then wipe away from the nozzles. Wipe the contacts on the inside of the printer as well. Then dry with additional clothes before reassembling. Make sure that the printhead latch is fully down before replacing the ink cartridges.
See if this solves your problem. You may need to power cycle the printer to clear the error. Unplug the data cable (if USB) and unplug the power cord from the printer and then from the wall. Wait a few minutes before reconnecting the power cord. Some printers may need a printhead replaced or additional service. (Usually the printhead is a non-refundable item if it doesn't solve your problem.)
I hope this helps.
Nov 11, 2011 | Dell P703w Printer
Message reads error Press I. code 07.010.43:94437, can you please tell where the problem occurs.
7,010.43: The Printhead is stuck in the tilted position, or is not able to tilt
forward to the print position, due to problems.
1 Reboot the printer.
Did this correct the problem?
2.Do the Printhead Restraints rotate
correctly? if no. then Repair or
replace the
Printhead
Restraints.
3.
Has ink spilled ink around the Printhead
that prevents the Printhead from moving
to its center position? You should be able
to push the Printhead right to left. Make sure the printhead area is cleaned.
4.Is the Printhead stuck to the Wiper Blade?
Start the printer in diagnostics mode and run diags test Exercise Heater - toggle Printhead heaters to soften the ink. Manual separate the wiper and Printhead. Set them in their home positions.
5. Does the X-Axis Motor drive the Printhead
to its center position (so it can tilt forward)? if not
Troubleshoot
the X-Axis
drive.
Well hope this helps.
Nov 09, 2009 | Xerox Phaser 8400 Laser Printer
My Canon BJC-85 Printer beeps 3 times and the cartridge printhead comes to the center and the green power light continues to blink. I have replaced the cartridges I have replaced the printhead with the...
3 beeps is still telling you that the printhead has a problem. Did you put in a new printhead? You also have to tell your printer by holding the resume button for the correct amount of beeps to set it for the printhead you have installed.
Jul 23, 2009 | Office Equipment & Supplies
Lousy Color - Lousy Printer
Kodak is sending me ANOTHER replacement printhead .... third replacement in 19 months.
Jul 18, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
I replaced my black cartridge on my injet 2230 but it keeps telling me that i need to replace black printhead. I've tried two so i know it isn't a problem with the cartridge
The cartridge does not have a printhead included as part of it.
The printhead is a separate thing normally located behind the cartridges.
You need to replace the printhead, not the cartridge.
Jul 13, 2009 | HP Inkjet 1200dn Printer
The printer is tell me to ionstall the pint head
Assuming that you have actually read or looked at the installation instructions and been using this printer this error usually means that there's a problem with the printer being able to "sense" or connect to the printhead.
Best way to resolve this is to check the following:
  1. Remove all the cartridges and remove the printhead from the printer
  2. Check the printhead copper contacts (found at the back of the printhead) and remove any ink smears, hair or other foreign material that may be causing connectivity issues
  3. Check that the printhead carriage (the bit that the printhead normally sits in) has no damaged or broken contact pins.. These can be damaged when a printhead is forced into the carriage.
If you've checked and resolved or found none of these to be a visible issue, try turning off the printer, turning it back on and then installing the printhead (without cartridges!) and see if the printer is recognising it..
Then try installing the cartridges carefully and see if that solves the problem.
If not, it's probably either a blown printhead in which case a new printhead can be purchased from Canon or a service center.. or you have damage to the printer that you cannot see and perhaps it's time to replace the printer or take it to a service center.
Hope that helps.
Mar 08, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Printing quality
Printing quality on this printers is great, yet there are some trouble with older printheads.
You should follow this in order to fix the problem:
- Remove both ink cartridges
- Remove printhead (press release button on the inner left corner of the printhead, above where the black ink cartridge goes)
- Close the cover and wait until it tells you that the printhead is missing. When it does, open the cover again and place the printhead inside (put it in and press towards the back of the printer, make sure it makes a loud snap).
- place both ink cartridges in
If the printer says "press start to copy", press the menu button and select calibrate printer, and then select "print calibration sheet".
If it just tells you that there is a new printhead detected and calibration is requiered, follow the instructions it will give you.
Once you calibrate the printer,
- Press menu, scroll down to "clean printhead" and select "deep clean"
Once that is completed, go ahead and print.
If it is still not working, you got a defective printhead and you need to replace it.
You will need to go to kodak.com/go/itg for additionl troubleshooting and the replacing of your printhead, or you should just call 1 800 421 6699 and have then replace the printhead for you. This is free of charge.
Dec 18, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Display says printhead not installed or loose
Make sure when you put it in, you are firmily pushing it towards the back of the printer, until you hear a loud snap. When you put it in the first time, DO NOT put the ink cartridges in. Close the cover and wait until it tells you that the ink cartridges are missing. If it is still telling you that the printhead is missing, it should be replaced. You may contact kodak support @ 1 800 421 6699, and have them help you to replace it, free of charge.
The printhead is not for sale.
IF after replacing the printhead you have the same problem, then is the printer the one that needs replacing.
Dec 15, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Looking for a white ribbon cable
This is no sparepart and belongs to the printhead which is only sold in one part (Flat white cable, printhead and printhead cover).
Aug 14, 2007 | Brother MFC 420CN All-In-One InkJet...
24 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
