Question about Elite Home Electronic Personal Bathroom Scale Clear
Need to know how to adjust the weight
According to 2 doctors scales, my scale is 10# off. How do I adjust the weight?
  • Anonymous May 08, 2009
    This is a new scale. No kids. It was off from the get go. Thanks for your solution.
  • Bestusefultips
    Bestusefultips Mar 14, 2017
    Use best android weight loss apps are perfect to improve your fitness & nutrition level, track diet & exercise, daily charts to track fats, carbs & proteins, record physical activities and other helpful tips and tricks for common weight loss. You can see details using below article. I hope it will helpful to loose some weight and make perfect body.
  • 77 Answers
Try putting brand new batteries in and letting the scale zero out and then shut off on its own. Sometimes it's "zero" is misrepresented by an old set of batteries. Also, do any kids live in the house that might have jumped on it? If so, it would be wise to buy a new one as the sensitivity will be ruined for life.
Posted on May 08, 2009
Just replaced battery - trying to reset the scale to 0.0
PDF]Instructions for use of Thinner® Bathroom Scales
Scales for the way you live® ... Tap on the scale and wait until "0.0" appears; press Set button, ... button to change the goal weight if necessary, once the ... NOTE: 1. When the scale traps zero error, "Err" will show. Please try again. 2.
How to Set a Digital Health O Meter Scale to 0.0 - Livestrong ... > Weight Management
Aug 12, 2015 - The scale may not register at 0.0 when starting out... ... The Differences Between Balance Beam Scales & Electronic Scales ... 10 High-Tech Health Tools toTry This Year; Are You in Need of a Digital Detox? How to Start Doing Parkour. References. FAQs; "Health o meter User Manual" .
Jan 05, 2016 | Health & Beauty
Need to know how to adjust tone arm and anti-skate
Get one of those little mini-digital scales that should sell for about $30 or less. Make sure it reads in 0.1 or 0.01 increments. Unplug the turntable (so the platter doesn't spin) and place the scale in the tonearm path. Most tonearm and headshell combos should work well in the 1.0 to 1.5 g range. Weigh the tonearm balancing on the scale about midway through the path (where it would be in the center of the record)
I used a flat plastic credit size card to protect the stylus on the surface. Don't forget to tare the scale to 0. Attempt to calibrate your weight scale adjustment on the tonearm to match the scale while you are at this. Once you have found a setting that works for you, match that marking on the weight scale adjustment on the anti-skate wheel.
You should have a turntable that sounds nice and is also gentle on your records!
Feb 18, 2013 | Audio Players & Recorders
I have two Weight Watcher scales, model WW11D. They weigh 4 lbs differently. One is 2 lbs heavy and the other is 2 lbs light relative to the weight registered at a Weight Watchers meeting. Is there a...
You say, that: "I have two Weight Watcher scales, model WW11D."
Can I have three guesses where you purchased them???
Do they come with any sort of warranty?
Their weight is inaccurate as compared to the official scales when you weigh yourself at the Weight Watchers meeting.
Are the people running the Weight Watchers meetings absolutely and totally unable to provide an answer regarding these scales?
Jul 04, 2011 | Vacuums
For the Health-o-meter physician's beam scale, how do you know when it is in balance? What should you do to get it in balance?
For any scale you need to have a known weight to calibrate the scale. Try using something like a 5lb bag of flour or 10lb bag of potatoes.
On the top of the scale set the scale to whatever known weight you have on the platform and see if it agrees, if it is just slightly off, then use the adjustment screw to fine tune the scale, it will be at the end of the left side of the arm.
Dec 27, 2010 | Health-O-Meter Health o meter 402KLWH...
I just purchased a Healthometer Weight & Body Fat Monitoring Scale. I successfully setting up my scale, I think? When I turn the scale on and weight for the 0.0 to appear, I get on the scale and it...
These scales use sensors to measure the electrical resistance of the human body to calculate body fat. If you are not stepping on the scale barefoot then that might be the reason why it is timing out. These scales require you to step on it barefoot so it can take a measurement through your feet. And using the height and gender information in combonation with the resistance measurement it can calculate your approximate body fat precentage. If you are stepping on the scale barefoot then make sure that your feet are properly placed into the sensors and avoid any movement. Let me know if you have any questions.
Feb 06, 2010 | Health & Beauty
Scale is not weighing correctly. Weighs correct
The scale must be on a hard, level surface. Make sure there is absolutely no dirt on any of the pivot points. Calibrate it with a KNOWN 25 pound weight.
Jan 04, 2010 | Health-O-Meter Health o meter 402KLWH...
Can I adjust the weight on the scales to match my doctors scales. Mine weight 6lbs less.
Adjusting the scale is not a solution but adjusting your weight all in 60 days.
No strees, side effect or bitter drinks but all natural flavour beverages. Tested & trusted ISO 22000-2005.
Oct 13, 2009 | Taylor & Digital Scale Lithium Scale
Need to reset scale weight
You have probably set your scale to kilogram and not pounds. There should be a button to set this underneath the scale or even a reset button to reset the scale to its original settings.
Jul 08, 2009 | Homedics Glass Top LCD Digital Lithium...
Conair weight watchers ww37gd scale
To set
1. Push the set button, you will get ------
2. Push the user
3. Push set again the user number will blink 3 times and show 0.0
4. Get on the scale- when it shows your weight push the set button. This is your start weight
5. Then it will automatically take 10% and show your goal.
6. Push the set button again this will set the goal
To Weigh
1. Push the user number that you set up the P-? number will blink 3 times and show 0.0
2. Get on the scale it will show in this order
a. your weight now
b. your weight since the last time you weighed
c. The total loss toward this goal
d. Total needed to reach your goal
Mar 18, 2008 | Computers & Internet
Elite Home Electronic Personal Bathroom Scale Clear Logo
669 people viewed this question
Top Elite Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
Jeff Tilburn
Jeff Tilburn
Are you an Elite Health and Beauty Expert? Answer questions, earn points and help others
