Question about Star trac 4500 Remanufactured Treadmill
15 amp fuse part number - Star trac 4500 Remanufactured Treadmill
    Top Expert:
  • Star trac Master
  • 12,223 Answers
Go to www.fitnessrepairparts.com and get the part. However you must understand, that this kind of fuse you can buy it from any electronic store , like Radio Shack, or another. Always use the same rating in this case 15amp, for 115vca +glass or ceramic? you must see if the fuse is glass or ceramic.
God bless you
Posted on Nov 28, 2013
Where is radio fuse on 05 taurus
There are three fuses for your radio. Your car has two fuse boxes one under the hood and one inside the cabin. the radio fuses are in the inside fuse box. Number 32. 33, and 22. 10 amp,15 amp and 15 amp.The #32 is hot in start or run, the #33 is hot all time, and #22 hot in run or acc.
Aug 01, 2015 | Cars & Trucks
What size fuse for cig. lighter and brake light
CIG lighter usually 15 amp brake lights about 20 amp sounds like all fuse problem. Check owners manual for fuse number
Apr 22, 2015 | Cars & Trucks
Buss class G Fuss,type SC, Amp 25, time-delay
There are a number of places that have these for sale. I've attached the link to the Amazon page that has these listings Amazon com sc 25 fuse
Home depot shows them in stock also Cooper Bussmann 15 Amp Class SC Style Fuse SC 15 The Home Depot
A fuse like this is not repairable, just replaceable.
Mar 19, 2015 | Cars & Trucks
Number 15 fuse keeps blowing
Possible causes:
- Fuse is under rated.
- Short circuit in wiring.
- Fuse No. 15 is overloaded.
- Positive wire is shorted to ground.
- Check all the loads one by one which are put on this fuse.
Apr 25, 2014 | 2010 Peugeot 206 SW
I don't have a cover for my fuse box and need to
Thanks for the inquiry.
Fuse Numbers and Locations:
EXPLORER FUSE PANEL Fuse Position Rating Circuit Protected 1 10 Amp Power Mirrors/Antenna 2 10 Amp Air Bag/Blower Relay 3 15 Amp Parking Lamps 4 15 Amp Left Headlamp 5 10 Amp On Board Diagnostic II System 6 15 Amp HO2S Sensors 7 10 Amp Illumination Switches 8 15 Amp Right Headlamp/Fog Lamp System 9 10 Amp EATC Mem./Seat Mem./Mess. Ctr./Cell. Phone 10 10 Amp EATC Sys./Rear Blower/Spd. Control/GEM Sys./Brake Interlock/OH Console Adapt. Susp. 11 10 Amp Warning Lamps 12 10 Amp Front and Rear Washers 13 15 Amp PCM Sys./Stoplamps/4WD/
ABS/Spd. Control/Trailer Tow 14 10 Amp Anti-Lock System 15 15 Amp Air Bag System/Alternator 16 30 Amp Front Wiper 17 30 Amp Cigar Lighter 18 15 Amp A/C System 19 25 Amp Ignition Coil/PCM System 20 10 Amp Radio/Power Ant./GEM Sys./Anti-Theft/Cell. Phone 21 15 Amp Hazard Lamps 22 15 Amp Turn Signals 23 15 Amp Rear Wiper System 24 15 Amp Starter Relay/Anti-Theft 25 10 Amp Speedometer/GEM System 26 15 Amp A4LDE Trans/DRL Sys./Backup Lamps/4WD/Rear Defroster 27 15 Amp Under Hood LP/Map Lights/Glove Box Lamp/Dome Lamp/Visor Lamps/Accessory Delay/DR Switch Illum./4x4 System 28 10 Amp Memory Seat/GEM System 29 15 Amp Audio System 30 - Not Used 31 10 Amp Aux. Blower System 32 10 Amp Heated Mirrors/Heated Backlite 33 20 Amp High Beam Lamps 34 10 Amp Audio System/Power Antenna 35 - Not Used 36 - Not Used
Hope this helps helps. Please keep us updated and remember to rate this answer.
Kind regards,
TF
Jun 05, 2011 | 1995 Chevrolet S-10 CA Edition
Which fuse controls the lighter and dome light
Hello Lisa.
Two separate fuses.
The dome lamp is a 7.5 AMP fuse, number 26 in the fuse box.
And the lighter socket is a 15 Amp, number 6 in the fuse box.
I hope this solves the problem.
Thank you for using FixYa.
Kl
Jan 30, 2011 | 1996 Nissan Maxima
Right power outlet not working
Hello. there are two fuses for the power outlets. check them both to make sure they are good. here is the fuses you need to check. both of these fuses are located in the fuse block under the hood.
CIGAR FUSE numbered 30 it is a blue 15 amp fuse.
the other fuse is AUX PWR numbered 29 it is a yellow 20 amp fuse
Sep 22, 2010 | 2004 Chevrolet Express
My fuse box cover has numbers to show what fuses go to what, I need a list of the numbers
1. 15 AMP Dome Lamps, Power mirrors (on 2 door models only), radio memory
2. 6 AMP front washer/ wiper
3. not used
4. 15 AMP stop lamps, 4 way flasher
5. 15 AMP back-up lamps, daytime running lights, rear defrost, turn lamps and turn indicator
6. 10 AMP speed control
7. 15 AMP instrument cluster warning lamps (explorer limited model #7 is 15 AMP heated outside mirrors)
8. 20 AMP horn
9. 10 AMP air conditioner switches, clutch coil
10. 15 AMP Park/ license plate lamps, trailer tow connection
11. 15 AMP radio
12. 20 AMP cigarette lighter, flash bright lights(from signal arm)
13. 10 AMP instrument panel illumination
14. 30 AMP power windows
15. 10 AMP ABS module
16. 20 AMP premium radio amplifier
17. 15 AMP rear washer/ wiper (explorer limited model #17 is 15 AMP warning gauges and lamps, 4 wheel drive)
18. 15 AMP heated exhaust gas oxygen
that's you list. hope it helps.
Aug 26, 2010 | 1992 Ford Explorer
Blown headlight fuse on 1998 Toyota Corolla.
When a fuse blows (regardless of the car make or model) there are two reasons this may happen:
1) There is a short circuit
2) The wrong fuse was installed
On both cases, the recommendation is that you:
1) Find the fuse box (on most Toyota vehicles it is located in the kick panel to the left of the driver's side.)
2) Remove the fuse box cover and look inside. There should be a diagram telling you which fuse is which.
3) Find and remove the fuse that serves each headlight (there should be one for each. They are both 15 amps or simply have a number 15 on the fuse). If your vehicle is equiped with fog lights, you will see a total of 4 fuses in the fuse box, labled as follows:
Head RH Head LH
Head RL Head LL
4) Inspect the fuses. Make sure the number matches the number in the diagram of the box (if no diagram on the box, then look in your owner's manual, but all I've seen have the diagram)
5) Replace any of the blown fuses WITH THE SAME amp rating fuse (15 Amp). If any of the fuses is not 15 amps, then replace with a 15 Amp.
IMPORTANT: Do not replace with a higher rating!!!!
A blown fuse may be caused by a short circuit. There is a real threat of ELECTRICAL FIRE if a short circuit is not caught in time. This is precisely what the fuses are for.
5) If after replacing the fuse with the correct 15 amp fuse you still have the same problem (i.e. you see the fuse blow when you turn on the headlights) turn the headlights off and consult your repair shop.
Cheers!
May 18, 2009 | 1998 Toyota Corolla
Radio fuse/cd changer
Number Fuse Amperage
Rating
Circuits Protected
7 7.5 amp Illumination switches
8 10 amp Right headlamp, fog
lamp system
9 10 amp Autolamps
10 7.5 amp Rear blower, speed
control, GEM system,
brake interlock,
overhead console
11 7.5 amp Warning lamps
12 10 amp Liftgate wiper/washer,
front washer
13 15 amp Brake on/off switch
14 10 amp Anti-lock system
15 7.5 amp Air bag system,
instrument cluster
16 30 amp Wiper run relay
17 15 amp Cigar lighter
18 15 amp A/C system
19 25 amp Ignition coil, PCM
system
20 7.5 amp Radio, power antenna,
GEM system,
anti-theft
21 15 amp Turn/hazard flasher
22 10 amp Turn signals
23 10 amp Rear wiper system
24 10 amp Anti-theft relay
25 7.5 amp Instrument cluster,
GEM system
Nov 11, 2008 | 1997 Mercury Mountaineer
Star trac 4500 Remanufactured Treadmill Logo
Top Star trac Exercise & Fitness Experts
Tom Chichester
Sportsmith LLC
Sportsmith LLC
greg kinsley
Are you a Star trac Exercise and Fitnes Expert? Answer questions, earn points and help others
