Question about Meade Optics
I have an LX200 10" that will not function properly in vertical drive mode. In alignment mode, vertical drive seems to operate at high sped. When alignment star is selected, horz works normally but vertical goes straight up (quickly) and forces me to shut down to protect gears. In manual mode, the drive speed in Horz is normal and adjustable, but Vert is at max speed and seems locked on high. Accordingly it is nearly impossible to align this thing. What do you recommend?
    Problem Solver:
  • 8 Answers
Get a new one.
Posted on Nov 27, 2013
SOURCE: Meade DS-2114 ATS LNT
Also had the problem. I found that the LNT did not find north unless the bottom of the Smartfinder is close to parallel with the ground.
Posted on Dec 18, 2007
SOURCE: red dot finderscope alignment problem
point the telescope at some thing during the day and adjust the finder scope and at night point at a star look through the eye piece and center the object in the eye piece then adjust the finder scope.
Posted on Jan 02, 2009
SOURCE: Start Align with NexStar 4SE
Did you enter the correct TIME, DATE, and LOCATION? and yes you may have aligned on to the wrong stars -- they need to be "near" the center.
Posted on May 20, 2009
SOURCE: Celestron NexStar alignment problem
Several questions-
1. Are you SURE you are choosing the correct alignment star?
2. Are all the settings correct like-- Location, Time, Date, Daylight savings time.
Posted on Jun 19, 2009
SOURCE: problem with alignment of Meade LX90 8" telescope
Start from scratch-
RESET the hand controller.
Calibrate motors using the same power source you will use outside.
Re-train the drives
Calibrate sensors on Polaris
Use either the 110 volt power cord, or buy a 12 volt power pack and the proper Meade 12 volt cable. (www.scopestuff.com carries the right 12 volt cable)
If your scope is NOT the LNT or GPS model you must level the tripod before you align. Go to home depot and buy the $3 small plastic two way bubble level, or the bulls-eye style bubble level.
Further trouble, I suggest going to the LX90 Yahoo group forum, and asking questions there.
Good Luck
Posted on Aug 30, 2009
Why will the Pioneer RT 707 not work in playback mode?
No it is the same motor for both functions. Just check does the record/play switch operate or move when you operate the record function? I have a hunch that is the problem it may also be that the switch contacts are dirty or worn.Try to play a recording you made on another machine if it does sound and play on the other machine then the problem can only be this switch. Some more upstairs decks do have separate amplifiers for play and record .Nakamichi. Studer Revox Tandberg Uher and the such comes to mind These are those machines offering "Off tape" recording monitor. Then it will sport three heads and not only two I hope this gives clues where to start looking for problems
Sep 01, 2014 | Audio Players & Recorders
Specifications nec fd 1137c
what are you looking for? Here is what I have:
LED Indicator: Green
Interface Connector: 34-pin connector right-angled header connector
Operation Mode Write / Read: 2MB mode / 1.6MB mode / 1MB mode
Disk Used
(90mm / 3.5): High density (2HD) / High density (2HD) / Normal density (2DD)
Data Transfer Rate: 500KBps / 500KBps / 250KBps
Unformatted Data Capacity: 2MB / 1.6MB / 1MB
Rotational Speed: 300rpm / 360rpm / 300rpm
Track Density: 5.3 track/mm (135tpi)
Track to Track Time: 3ms
Required Power: +5V single (4.5V ~ 5.5V)
Signal Output Driver: Open Collector TTL
Input signal Pull-up: 1K Ohm 30%
Function Setting at Delivery: Interface Setting:Pin2: MODE SELECT input (LOW: 1.6MB mode) Pin12: DRIVE SELECT 1 input Pin34: DISK CHANGE Output Other Function Setting: 1. Automatic density setting for 2DD (1MB) disk or 2HD (1.6MB/2MB) disk 2. LED Turn on Condition: DRIVE SELECT 3. Motor Rotating Condition: MOTOR ON 4. Ready and seek-complete gate (full-mask) for INDEX and READ DATA output pulses 5. Auto-chucking at disk installation 6. Auto-recalibration at power on 7. Frame is electrically shorted to DC 0V
Dimensions: 101.6 W X 25.4 H X 145 D mm excluding front bezel
Weight: 345g
Mounting: Vertical/horizontal with spindle motor down
MTBF: 30,000 POH
Safety Standards: UL, CSA, TUV
May 27, 2014 | Teac Computers & Internet
Picture expanded vertically
First thing I would do is get iobit driver updater (assuming you are talking Windows os) and run that. Otherwise pl
please give me more information
Mar 01, 2014 | Computers & Internet
My TM won't work in the incline mode. We recently reset it up and started it before we had it in the proper alignment (walking surface to motor) and engaged the incline function. There was a bolt
Please RUN the software caibration for diagnose, troubleshooitng, and fix it Maybe you have speed sensor faulty or bad adjustment, clean it and tight wires connector.
God bless you
Jul 26, 2012 | Proform Quick Burn Pro Treadmill with 12...
The Lexmark x5495 printer is not printing correctly. The printout is not aligned properly. The printout is crooked. How can you solve this problem?
Try to re-seat your cartridges and make sure they are properly inserted in the cartridge carrier.
If that doesn't help, please do the Align Cartridges function on your printer. From the printer operator panel, while on Copy mode, press the Menu button > Tools > Maintenance > Align Cartridges. You printer will then print a test page that will help align the cartridges.
After the page is printed, try to print a document again to verify that the problem is fixed. Thanks.
Feb 25, 2012 | Lexmark X5495 Printer
Where is the printer head and how to align it
Service Mode
This printer has a service mode for service-related settings and for performing test prints. The operator panel buttons are used to enter the desired service mode.
Service Mode Operations
1) With the printer powered off, hold down the resume button and press the power button.
2) While holding down the power button, release the resume button and press the resume button twice in succession. Now release the power button. The
indicator will blink in green and remain lit in green.
3) Select one of the following service mode functions by pressing the resume button the specified number of times.
Press Resume Indicator Functions
Zero times Green Power off the printer
1 time Orange Service test print
2 times Green EEPROM information print
3 times Orange EEPROM initialization
4 times Green Waste ink counter setting
5 times Orange Destination settings
6 times Green Print head deep cleaning
7 times Green CD-R test print
8 times Orange CD-R print position correction (horizontal)
9 times Green CD-R print position correction (vertical)
4) Execute the function you have selected (except for model setting) by pressing the power button. The printer will switch itself off after performing the function.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 25, 2009 | Canon PIXMA MX310 All-In-One Printer
When i use the brake, especially at high speds it makes a loud vibrating noise, the sterring wheel vibrates and shakes a little. this starting happening after i got al alignment and new tires put on. i...
The alignment would not affect your breaking as the alignment only controles the direction that the front wheels face. You may need to check your rotors and make sure they do not need replaced and check the breaks while you are at it. The pads should be evenly worn and the rotor should be evenly worn as well. There should be no deeps grooves in the rotor or break pads.
Nov 13, 2008 | Toyota Matrix Cars & Trucks
Height is small in aiwa tv model tv-se2130k, and how to go in service mode.
this is the conversion chip and vertical deflection chip that need to be replaced
service mode will only make the color alignment worse since the conversion chip is failing so it won't align properly
it will need that repair
Oct 16, 2008 | Televison & Video
What is the focusing screen display?
There are two display modes newly added for the DiMAGE 7i, grid and scale. The grid mode is to show a grid over the entire screen. This makes it easy to align the camera to objects vertically or horizontally. In the scale display mode, horizontal and vertical lines cross at the image center to divide the view to four sections, and each axis is scaled. This function is useful for close-up photography. The grid or scale on display is not recorded.
Sep 15, 2005 | Konica Minolta DiMAGE 7i Digital Camera
Optics Logo
Top Meade Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Experi
Level 1 Expert
Greg Cann
Greg Cann
Are you a Meade Optic Expert? Answer questions, earn points and help others
