Question about Coffee Makers & Espresso Machines
Telkom Ultimate B100 -Can not make or answer calls but phone rings, base 1 shows all the time
SOURCE: Answering drops call when answering
I have had the same problem when trying to connect the GE-29569 to my PBX. The PBX manufacturer suggested the the answering machine might be pulling too much power, which would result in a dropped call. I have not resolved this problem yet. However, the machine works fine when connected to my home line, but still does not work with the PBX. Since both work fine separately, I can only assume that power requirement might be the problem. RFR-US
Posted on Jan 08, 2007
eagle338
  • 4889 Answers
SOURCE: faulty phone
Sure sure i will help you out but please specify the model of your phone..If its GE then you will need to keep it connected to the power supply...If the power supply is cut it will br un-registered automatically..
Posted on Oct 30, 2007
SOURCE: Every handset is showing me connecting ...
I am having the same problem. I unplugged everything, and nothing changed. Phone #2 comes back sporadically. Has anyone gotten word from Vtech?
Posted on Jul 11, 2008
SOURCE: phone doesn't ring on incoming calls
i cannot fix the number of times for the ringer on my vetch phoneset
Posted on Oct 19, 2008
SOURCE: phone won't ring with incoming calls
I just bought a new Uniden DECT 6.0 phone and had a similar problem. It wouldn't ring when plugged into my Linksys voip router, but my old 5.8 GHz did ring. It would get a dialtone and make calls, but when called via an outside line, it would appear as if it was ringing. If I picked up during this "silent ring," it would answer and take the call. It wasn't a ringer volume issue. I called tech support, they said on the main headset, unplug the battery, then unplug power from the base, then unplug the phone cord from the base. Wait 15-30s. Plug the phone cord, then power, then reinstall the battery. Press the End button on the phone. Put the phone on the base for 15-30s. Pick up the phone. Press and hold the Find button on the base. Do this Find thing 3 times. Put the phone back on the base. Wait 10-15 minutes. Then try calling it to see if it rings. Worked for me, finally got it to ring before I decided to return it.
Posted on Jan 13, 2010
How can i limit the number of rings before the answering machine kicks in on my panasonic 6.0 phone
Answering system settings Number of rings before the unit answers calls You can change the number of times the phone rings "Ring count" before the unit answers calls. You can select 2 to 7 rings, or "Toll saver". The default setting is "4". "Toll saver": The unit's answering system answers at the end of the 2nd ring when new messages have been recorded, or at the end of the 4th ring when there are no new messages. If you call your phone from outside to listen to new messages , you will know that there are no new messages when the phone rings for the 3rd time. You can then hang up without being charged for the call. 1 {MENU} i {#}{2}{1}{1} 2 {V}/{^}: Select the desired setting. i {Save} i {OFF}
Jan 17, 2018 | Panasonic Lands Phones
My att cellphone only rings 4 times before voicemail
If the problem is with an AT&T cellphone you will need to call them or go log in online to change that feature, however if it is with a Uniden Cordless Phone (the product this question is linked to) the directions below found in their manual should help:
From the base
1) Press [clock/menu] three times. The base displays the current number of rings (2, 4, 6, or TS for toll saver) and announces the setting.
2) Press [>>/select] or [<</select] until the desired ring time appears.
3) Press [set]. A confirmation tone sounds, and the answering machine announces the new ring time.
From the handset
1) Press the MENU soft key. Select the ANSW. SETUP menu, and then the RING TIME submenu.
2) Move the cursor to select a Ring Time (2 TIMES, 4 TIMES, 6 TIMES or TOLL SAVER).
3) Press the OK soft key. You will hear a confirmation tone.
Hope this is of help
May 05, 2014 | Uniden Cordless Phone
My phone rings only once or not a complete ring. if I answer it at 1 ring i can connect with the caller, otherwise it disconnects them we have been away for several months. the first day back it...
First try dialing 73#. Also try *73. Depending on you phone company, one of those will cancel call forwarding if it was inadvertently set. If that doesn't solve your problem unplug any answering machines or cordless phone base units that have an answering machine built in. Also unplug any fax machines or computers that are connected to the phone line. If this solves the problem you can plug things back in one a t a time and test to see which item is the culprit.
Apr 17, 2010 | Lands Phones
When someone calls my phone rings 4 times then
You must turn off your internal answering machine. There should be an on and off button somewhere on the main base.
Jun 06, 2009 | Vtech CS5121-2 Cordless Phone
Phone won't ring with incoming calls
Jun 02, 2009 | Lands Phones
The base "charge/in use" light is blinking two blinks each time.
Called comcast (phone service provider) and requested that voicemail isn't activated until phone has rung 7 times. My answering machine is set for 5 rings.
Feb 02, 2009 | GE 25942GE2 Cordless Phone System
Uniden 5.8Ghz phone.
You need to reset the main base unit. Unplug the power from the back of the base. While the power is disconnected, press and hold the delete key while reconnecting the power. Wait for a long beep tone. When the display shows 88 or P, press play button one time. If you have a phone without an answering machine, disconnect the power from the back of the base, press and hold find hs button while reconnecting power.
Jan 20, 2008 | Uniden Cordless Phone
How to change Flash timing
The only reference to flash timing I can find in the manual is shown below for you, also here is link to manual :
I hope it helps !
http://www.uniden.com/products/productdetail.cfm?product=TRU8885-2
If you have Call Waiting service and a call waiting
tone sounds while you are on a call, press talk/flash
on the handset or flash/find hs on the base to accept
the waiting call. There is a short pause, and then you
will hear the new caller. To return to the original
caller, press talk/flash on the handset or flash/find
hs
on the base again.
Setting the Ring Time
Ring Time allows you to set the number of rings the caller hears before your
answering system plays the outgoing message. You can set the ring time to answer
after two, four, or six rings. If you enable the Toll Saver (TS), the answering system
picks up after two rings if you have new messages and after four rings if there are
none.
1) Enter the Answ. Setup menu, and then the Ring Time
submenu (see "Entering the Menu" on page 16).
2) Press volume up/down to select a Ring Time (Toll
Saver, 2 Times, 4 Times, or 6 Times).
Setting the Record Time
Record Time sets the duration for recording the incoming messages. You have three
record time options. The options "1 minute" or "4 minutes" set the duration for
recording the incoming messages. "Announce only" answers the call but prevents
the caller from leaving a message.
1) Enter the Answ. Setup menu, and then the Record
Time submenu (see "Entering the Menu" on page 16).
2) Press volume up/down to select Record Time
(1 Minute, 4 Minutes, or Announce Only).
May 03, 2007 | Uniden TRU8885-2 Cordless Phone
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
