Question about Electrical Supplies
How to remove and replace the stator from a champion generator
Would like to know how to remove the stator from the generator and replace
    New Friend:
You don't state what model you have. I just replaced the rotor on a Champion Model 41302 but removing the stator is the same process.
You will need to remove the muffler and muffler outer protection. Remove the bolts that hold the muffler outer protection. Remove the two bolts that hold muffler to the engine exhaust.
Take a block of wood and place it under the engine to support the generator. The supports on the generator head end will be removed so the generator will tip down and make it difficult to remove the stator.
Remove the generator end cover by removing two bolts.
Remove the two bolts that hold the muffler to the end cover.How to remove and replace the stator from a champi - 0834b898-460f-41f6-b0a0-6704ae605277.jpg
Remove the bolt that holds the ground from the generator to the frame.
Remove the two bolts that hold the end cover supports to the rubber supports to the fraHow to remove and replace the stator from a champi - d955ba9c-75cc-4bef-9c96-598398fd22d8.jpgnet/uploads/images/d955ba9c-75cc-4bef-9c96-598398fd22d8.jpg" alt="dHow to remove and replace the stator from a champi - d51dedd7-180a-495d-93ed-a2ccbc522672.jpg class="h_mi" />
Disconnect the quick connect elecHow to remove and replace the stator from a champi - f0fa6b82-0964-434b-bd37-2541c4ecc1ff.jpg volt wiring from the terminal block. See second picture below.
How to remove and replace the stator from a champi - 792dfaeb-0636-44c1-aec0-160241e0d58f.jpget/uploads/images/f0fa6b82-0964-434b-bd37-2541c4ecc1ff.jpg" alt="f0fa6b82-0964-434b-bd37-2541c4ecc1ff.jpg" class="h_mi" />
Remove the ground from generator to wiring cable asseHow to remove and replace the stator from a champi - aae206bd-1318-4c51-a0c6-b6bb9201052f.jpgit to the end cover. Yellow and green wire in picture above.
Remove the bolt from DC brush assembly and pull out of generator. Picture below shows assembly removed.
The stator and cover now can be removed from the generator. Take a rubber mallet to tap on the back of the brackets on the end cover to loosen it. The rotor bearing is seated in the end cover making it hard to remove by pulling by hand. Once lose pull straight out.
The stator can now be removed from the generator end by taking the four bolts out.
The installation process is the reverse.
Posted on Nov 29, 2013
2 Suggested Answers
  • 905 Answers
SOURCE: I have a generator that does not produce any
As long as you have continuity through the stator and rotor windings, and no continuity from the windings to the core, you should be good.
If the brush block was replaced due to it being defective, take a look at the diode and capacitor regulator as well. Using a multimeter, the diode should indicate continuity in one direction, infinite resistance in the other. If you get this, then replace the capacitor. If not, then replace the diode, and likely the capacitor as well.
Posted on Jun 12, 2010
Bad gas champion 6800 generator
You need to:
1) replace the fuel in the tank
2) Remove the petcock and clean filter located on top
3) Rinse out tank with clean fuel
4) Clean the carb (replacement carb or carb rebuild kit might be required if damaged by ethanol in fuel)
5) Put it all back together and run the generator.
If you do need a carb or carb repair kit you can purchase them on our website:
http://www.generatorguru.com/champion
Nov 27, 2016 | Electrical Supplies
How to remove generator rotor to replace piston rings.
There should be a long bolt in the end of the rotor that screws into the crankshaft of the engine. Take that one out and if the rotor doesn't fall off then a gentle nudge with a rubber mallet will be necessary.
Mar 11, 2016 | Electrical Supplies
Northstar 5500. Voltage good. sounds and runs good. But, makes bad noise from gen head area when under any load. I replaced the bearing. Anything else?
Stator is contacting the rotor, did you replace both bearings? remove the stator and look for damage on the stator and rotor laminates
Feb 26, 2015 | Northstar 5500/4500 Watt CARB Compliant...
My Champion 6.5HP Generator has a gas leak under the gas tank. The gas shut off valve is missing a rivet (one of two). I've got it unscrewed but am not sure how to get a replacement part. I have the...
They have a website at http://www.championpowerequipment.com. Click "support" and they tell you "If you need to order a part please call our tech support line. Our professionally trained technicians will be able to assist with placing orders. Orders ship within 1 business day - orders received before 2:00 PM (PST) will be shipped same day." The number is 1-877-338-0999. They also have many service bulletins thee thay will help solve many problems.
Apr 23, 2011 | Champion International Champion Power...
Motor runs fin but smoke major pouring out of generator end and circuit breaker will not stay on
If you were drawing major power from generator, you may have fried capacitor or voltage regulator. Both of these parts tend to make smoke when they fail. Stator winding can fail also but rare. Remove end cap to generator. Look for melted strings that bind coils together or melted wires. This would indicate failed stator. If stator looks ok, look for capacitors that look swollen or leaking that my be easily replaced. Caps have a value printed on them and reading should be within 5%. If caps are good, look at half moon shaped regulator. Failed regulator will have melted potting compound. Good luck
Nov 10, 2010 | Honda Electrical Supplies
The coil rope broke I would like to know how i can repair it. Generator 5500 watt champion.
If I understand correctly, you have a pull-start generator.
The rope to the pull-start broke.
This happened to us out on the job one day.
Our equipment might be different than yours. Our pull-start assembly is held with 4 bolts. Simply remover those bolts and lift off the cover ... carefully. The rope is attached to something I will call a pulley. The rope wraps around the pulley several times.
Do not lift out the pulley that the rope attaches to >> or the spring that re-winds the rope will come un-sprung (at least it did on our machine). If the spring comes unwound, then you got another job, and have to put the spring back also. Your machine might be different.
Keep pulley in place. Remove rope. Get another rope with same diameter and length and put it in.
Oct 18, 2010 | Champion International Champion Power...
2008 kawasaki ninja 650 R generator cover replacement
You can take the cover off, nothing should fall out.
Jan 02, 2010 | 2008 kawasaki Versys
I have a Hobart Champion 10,000 welder generator. It runs but I am getting no juice out of it. Won't weld or put out power to run anything.
measure ouput on ALL available sockets - anything?
Take cover off electric motor-generator, visually inspect windings.
Measure continuity of all stator windings (2 or 3 points usually)
Measure continuity of stator thru brushset.
If all measures ok - has to be AVR module.
There is no mistery in generator - just stator to induce and rotor to obtain voltage.
Jan 01, 2010 | Hobart Champion 10,000 All-in-One...
Have crafsman 5500generac generator need to seperate genhead from
Remove all wiring. Remove four stator bolts. Remove stator. remove rotor through bolt tap end of rotor us a shaft in the rotor tighten bolt in tapped hole to remove rotor.
Mar 25, 2009 | Watts Onan Portable Generator - 4000 ,...
Electrical Supplies Logo
1,161 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
