Question about Ariens Zoom 34" (Stamped Deck) Zero Turn Lawn Mower NonPowered Bagger
Ariens Zoom 34 will not move forward or back - Ariens Zoom 34" (Stamped Deck) Zero Turn Lawn Mower NonPowered Bagger
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
Suspect a damaged belt or tensioner spring for the drive belt... these units have no servicable trans-axles. or did you just remove both rear wheels ???
Posted on Nov 27, 2013
My ariens zoom 34 belt keeps slipping off the pulley and is difficult to fix
This machine is known for having belt guides installed improperly from the factory. Check to make sure none of the metal guides are touching the belt when installed.
Ps check with the machine off!
Good luck
Joe
Feb 10, 2011 | Ariens 34 In. Zoom Series Riding Mower
While trying to remove blades on Ariens Zoom 34, the spindle moves
you're gonna need to use an impact wrench on those spindle shaft nuts because they tighten themselves over time and they wont come loose with a ratchet and socket.
Dec 07, 2010 | Ariens 34 In. Zoom Series Riding Mower
Hi, i have a Ariens Zoom M 2148 xl tractor model
Probably you can get what you need at a lawn mower shop, they have exploede parts diagrams on microfilm.
Sep 28, 2010 | Ariens 34 In 344 CC Briggs Stratton...
Ariens 34 zoom blade binds at mid-height blade
Sounds like the mower deck is lower on one side. I am having the same problem with my older tractor mower.
Jul 24, 2010 | Ariens 34 In. Zoom Series Riding Mower
Not sure, but i think the electronic clutch is not engaging when i push the control levers forward or backwards. the engine and the mower deck both run, but the mower will not move
The electric clutch is to power the blades/mower deck. There is a belt that drives the hydrostatic pumps to power the wheels. Make sure the Parking brake is OFF. Could be a belt, spring, idler pulley.
Nov 19, 2009 | Ariens 34 In. Zoom Series Riding Mower
My 1999 Ariens EZR 1742 will not move. Cranks and
if both belts are present are they both moving? Could be tensioner froze up and it is not applying tension. mine had and i had to remove and free it up.
Sep 26, 2009 | Ariens 34 In. Zoom Series Riding Mower
Ariens ezr 1742 will not move. everything works fine except it will not go forward or reverse.
There is one common problen that causes this. Infront of the rear wheels there are two housings for the indepentent hydrostatic transmissions. There is one gold colored shaft with a ninety degree angle on it sticking out from EACH of the housings on the top front. Again these are on both sides and they each need to be pushed downward so that the rods can then be pushed backward into the transmissions to inguage them so both of the wheels are powered. Give this a try.
Jun 07, 2009 | Ariens 34 In. Zoom Series Riding Mower
Blades won't turn to cut grass
On the chute where the grass comes out there is a black piece of metal under the edge of the deck held on by the 2 big thumb screws is probably bent. You will need to try to move the blade on the side near the chute by hand (Make sure the mower is not running when you do this) if the blade touches the black piece of metal it will kill the mower if you engage the blades and try moving forward. Anyway you need to take the black metal piece off and bend the corner out of the way (I used a crescent and clamped it to the hitch on my pickup). I am guessing i went over something like a street curb with the deck when it was to low and that bent it. Now when ever I move the mower from someones yard or drive it across the street I always raise the deck up all the way. I hope this helps
Apr 19, 2009 | Ariens 34 In. Zoom Series Riding Mower
Blower does not go forward
check drive belts and pulleys. replace as required.
Jan 25, 2009 | Ariens 34 In. Zoom Series Riding Mower
Ariens Zoom 34" (Stamped Deck) Zero Turn Lawn Mower NonPowered Bagger Logo
199 people viewed this question
Top Ariens Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Paul Sikkema
Paul Sikkema
Are you an Ariens Garden Expert? Answer questions, earn points and help others
