Question about Medion md40298 Notebook
How to switch wireles on to medion md98300 - Medion md40298 Notebook
  • Paul Latshaw
    Paul Latshaw Nov 28, 2013
    Hi Bogdan Murarescu, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
Medion pc mt6 wifi switch? desktop no fn key
http://www.medion.com/gb/service/download/driver.php, go to this website, enter your msn number and download the software that will activate the hotspot keys to enable your wifi.
Mar 18, 2014 | Medion Computers & Internet
Cant turn on wireless on medion md98300
try right clicking my computer then device manager see if you have a yellow question mark if its there you need to download its driver if its all good then try fn + the blue antenna on f 8
Jan 09, 2013 | Medion MD-40954 Notebook
I have a medion MD98300 laptop . Last night went to power up with both battery and mains connected seemed to want to start (mains light was on, battery light came on and then immediately went off motor...
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
4. The motherboard could be defective & needs to be replaced.
Sep 09, 2010 | Medion md40298 Notebook
I dont find wireles in laptop
for first time switch the wireless on. There must be wireless led on board. there must be switch or button in keyboard to switch wireles on.
Apr 12, 2010 | Gateway 7330GZ Notebook
Medion akoya MD 96640. started with the screen going fuzzy and the whole thing locking up till the only way to switch off was to pull the battery out. Now when you switch on the lights light up and the...
Same problem with my sons 96640 In at Medion now waiting for supplies of new motherboard to come in-from what I have read elsewhere the graphics chip causes the same problem on other laptops, not just medion
Jan 20, 2010 | Medion Computers & Internet
How to turn on the wireles function capabilty
Should be a switch at the front left hand side of the touch pad that you switch. if it's off it should be orange when it's on it will be blue light
Aug 06, 2009 | HP Pavilion dv7-1132nr Notebook PC
Wirels connectiuon
you cannot just connect two routers one after the other- what you need to do is to set the wireless router as a "Wireless switch" - it means that it won't preforme as a router it will preform just as a broadcasting device.
you also need to set it to be on the same subnet that the first router is on- since you didn't specify the make and type of the first router it will be very hard to answer this question.
what I suggest is that you call the support of either the wireless router or the other router company and they let them know that you need to "set the wireless router as a switch to the first router" and they will be able to guide you how to do it.
May 18, 2008 | Edimax BR-6216Mg Wireless Router...
Medion md40298 Notebook Logo
44 people viewed this question
Top Medion Computers & Internet Experts
John Anderson
John Anderson
Martin Murray
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
