Question about GE JES1142SJ Microwave Oven
Fuse location for ge model jvm1850sm2ss - GE JES1142SJ Microwave Oven
Where do i locate the fuse
Although you have not mentioned the model/make, take a look at the video here for replacing a Thermal fuse. Microwave Won Work GE Microwave Thermal Fuse Replacement part WB27X1127
on traditional fuse see
How to Fix Microwave Oven Simple Fuse Replacement
Mar 08, 2016 | GE Microwave Ovens
Would like specifications to JVM1850SM2SS
  • 1.8 CF Oven Cavity
  • Electronic Touch Controls
  • 950 Watts
  • Display On/Off Yes (option pad)
  • Add 30 Seconds Instant-On
  • Cooking System CircuWave┬«
  • Defrost - Auto / Time / 1 lb. Quick Defrost
  • Delay Start
  • Express Cook Instant-on 1-6 minutes
  • Instant On Controls
  • Micro / Time Cook I & II
  • 10 Power Levels
  • Wire Oven Rack
  • Cooktop Lighting - Bright/Night/Off
  • Demo Mode
  • Interior Oven Light - Halogen
  • Night Light (option pad)
  • Child Lockout
  • Easy Mount Installation
  • Exhaust Fan 3 Speed Plus Boost (315 CFM)
  • Cooking Complete Reminder
  • Timer (On/Off)
  • Reminder (24 hr)
  • Sound Volume Control - 4 levels
  • Sensor Controls
  • Beverage Instant-On
  • Popcorn Instant-on
  • Potatoes Instant-on
  • Reheat Instant-On
  • Sensor Controls
  • Vegetables Instant-on, 3 pads (canned, frzn, fresh)
  • SmartControl System
  • Clock Plus AM/PM pad
  • Concurrent Programming
  • Custom Pad
  • Electronic Scrolling Digital Display - 2 line
  • Help Pad
  • Variable Scroll Speed - 5 Speeds (Options Pad)
  • 14.25 " Turntable - Glass Recessed
  • Turntable On / Off
  • 2 Wire Oven Racks; 2 Positions
  • Recirculating Charcoal Filter Kit JX81B
Dec 15, 2014 | GE Microwave Ovens
Ge jvm1850sm2ss suddenly does not heat food any longer
time for a new one... new ones are cheaper then the parts
Apr 08, 2014 | Microwave Ovens
Where is the fuse located in a GE Spacemaker II microwave model number J EM824_ _ _ ? I can't read the rest of the model number.
If the microwave control panel doesn't light up, then your fuse is blown. unplug the microwave. unscrew the vent grill, (2) screws at the top of the microwave. then you should see 1 screw holding the control panel. after removing that screw, gently push up then out. there should be a metal plate on top of the control panel. remove that plate and the fuse will be in that opening. remove the fuse and check for continuity across the fuse. Replace fuse and microwave should begin working.
Feb 09, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
There seems to be no power. No clock. no nothing. It was working fine and then jut stopped. Circuit is not tripped. I tried unplugging and plugging again.
most likely you will have to remove the louvers or trim above the cooking cavity to get to the fuse, look for screws holding the trim/louvers on, if no screws are apparent, the piece may slide to the left or right and pop off.
Unplug your microwave. Although it might seem like no electrical current could possibly be running through your appliance, it could still have stored electrical current somewhere in the system. Be safe rather than sorry and unplug it before you begin.
  • 2
    Find the wiring diagram for your model of GE microwave. You can contact GE directly to get this if you cannot locate your owner's manual. Note the fuse locations and get a screwdriver. Some GE fuses are located under the louvers, while others are located in the door.
  • 3
    Open up the microwave and locate the blown fuse. Sometimes you cannot determine a blown fuse by visual inspection so check it with a multimeter for continuity across the terminals.
  • 4
    Replace the blown fuse. Go to your local hardware store and pick up a matching fuse. Make sure you check the model numbers of the fuse as well to be sure you get the right component. Install the new fuse and put everything back together.
  • 5
    Check the continuity of the circuit if you continue to have power problems. If you have a problem with continuity in the circuit, then you may have a bigger problem than just a blown fuse. Sometimes a power surge will fry a GE microwave's circuit board, which you will need to replace.
  • Dec 04, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
    GE PROFILE PURCHASED 2006 RUNS BUT NO HEAT MICRO/CONV MODEL JEB1095BB
    HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
    (((The fuse is located inside the unit along side the magnetron)))
    Sep 10, 2009 | GE JVM1630 Microwave Oven
    Replace fuse on GE Advantium Speedcooker Oven
    there is a fuse located underneath the outer cover, its called a ceramic fuse and is of cartridge type about 1" long by 1/8" diameter and has a white body and 2 silver ends and you can take it to a hardware store they have them but make sure to get correct amperage rating 15 or 20 amp
    Sep 05, 2009 | GE Advantium 120 Convection/Microwave Oven
    Where is fuse located in microwave
    Yes but need the model number to help you know where it is.
    Aug 28, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
    GE Advantium mircrowave oven
    The problem with my Advantium was the fuse inside the microwave.Thanks to all of your fixya emailers ,I was able to change the fuse myself.I would recommend your site to all as you were a great help to me. Thank you, wlpasko.
    Apr 09, 2009 | GE Advantium SCA2000B Microwave Oven
    No heat in GE XL1800 1100 Watts microwave
    model # JVM1870BF001 GE Profile spacemaker XL 1800 microwave
    after episode of using defrost which burned food--now stopped heating--still has power/fan--don't know how to change fuse--please help
    Jun 21, 2008 | GE XL1800 1100 Watts Microwave Oven
    GE JES1142SJ Microwave Oven Logo
    50 people viewed this question
    Top GE Microwave Ovens Experts
    William Miller
    William Miller
    Devabhakthuni...
    Devabhakthuni...
    Shekar Avadhani
    Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
