Question about Home
Kohler auto flush in urinal keeps running - Home
2 Suggested Answers
  • 13 Answers
SOURCE: my urinal is leaking at
There is a rubber gasket between the urinal outlet and the pipe it connects to in the wall. Pull the bolts holding it to the wall and pull it away carefully. If it has been siliconed to the way, you'll have to cut it. Swap out the gaskets. Be careful not to pinch the new gasket. Ask at your local plumbing supply for the gasket of your particular model. They'll know what your talking about.
Posted on Aug 29, 2011
How do you stop a kohler men urinal stall from consistently running?
Usually this is caused by a sticky valve. The "low-tech" repair method is to just thump the top of the valve fairly hard with your fist. The correct method would involve disassembly and cleaning of the valve interior, or even possibly replacement.
Oct 17, 2015 | Kohler Home
How to adjust flushing power for kohlertoilet model 974 166-cs-8b
974: 1997 Lamosa Sahara Toilet Tank Reshoot - YouTube
? 1:57
www.youtube.com/watch?v=CJRXAgszpHk
Feb 5, 2011 - Uploaded by toiletfan1
I Like This Toilet. ... 974: 1997 Lamosa Sahara Toilet Tank Reshoot ... 979: 1974 Kohler Dexter Urinal Reshoot (Mom's POV) - Duration: 0:54.
Sep 22, 2015 | Home
How do I fix KOHLER Touchless toilet it keeps flushing, it is less than 6 months old
We had a problem with phantom flushing. Call Kholer. They will send redesigned battery holder and top of flush unit for free. Seems to have fixed the issue.
Oct 01, 2014 | Kohler Home
Toilet running water
Flapper on flush valve is not setting good on bottom of tank inside.
Jan 04, 2014 | Kohler Home
My Kohler toilet K-4632-AA keeps running how do I fix it?
Plumbers Brisbane West : For any Plumbing Emergency please call us anytime - 0411 179 978. Your Local Plumber in Brisbane's West - On-Time - Everytime.
Mar 05, 2012 | Kohler Cimarron Comfort Height elongated...
Our urinal continually backs up. We've tried everything, including 2 plumbing companies. time to replace?
You either have a block drain line or a blocked air line. A snake down both should clear your problem.
Jun 01, 2011 | Kohler Urinal washdown pipe KOH-K-9198
I have a Sloan urinal that will not stop flushing. I have rebuilt it with a total rebuild kit. I cleaned the inside of all surfaces and I flushed the entire piping system to no avail. It will not stop...
The rubber vacuum relief needs to also be changed if you have not. It is located in the tube that runs down to the urinal from under the flush valve. The handle could be hanging up.....or there could still be sediment stopping the diaphragm from working properly.
Nov 21, 2009 | NRS 180-1.5 Sloan Exposed Urinal...
I need a blue print on how a sloan urinal flush valve works and how the water flowes through it. if posable exactly how it works.
SLOAN FLUSH VALVES ARE SIMPLE. IT DEPENDES ON THE PROBLEM. IF THE VALVE KEPS RUNNING AFTER IT IS FLUSHED THE RUBBER DIAPHRAM IS DIRTY OR OLD AND THE RUBBER DIAPHRAM IS GETTING HARD. AND STICKING. THE VALVE WORKS ON A VACUME TO CLOSE THE DIAPHRAM TO STOP THE FLUSH PROCESS. WHEN YOU PULL ON THE FLUSH HANDLE YOU BREAK THE VACUME THAT FORM ON THE TOP OF THE DIAPHRAM WHICH ALLOWS THE WATER TO FLOW AS THE WATER FLOWS IT IS ALSO STARTING TO PULL A VACUME IN THE TOP OF THE DIAPHRAM TO CLOSE THE DIAPHRAM AND STOP THE FLUSH.
AS THE DIAPHRAM GET OLD AND WORN IT GETS HARD AND DOES NOT MOVE AS FREELY AND STICKS OPEN AND WON'T LET THE VACUME CLOSE THE DIAPHRAM AND THE URINAL WILL CONTINUE TO FLUSH. HOPE THIS ANSWERED YOU QUESTION
Oct 01, 2009 | Sloan Regal Flushometer 111 Toilet 1.6 Gpf
Home Logo
46 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
