Question about Sony PS-LX300USB Turntable
Ps-lx300usb does not turn on - Sony PS-LX300USB Turntable
I just replaced the stylus on my sony PS-LX300USB turntable, but now there is a constant static on even my new records
You have either knocked the connections to the cartridge causing a loose connection, or not seated the stylus right. Or you have static build up, which can be caused by poor earthing.
Mar 12, 2014 | Sony PS-LX300USB Turntable
No sound with Sony LX300usb turntable
I just received the Sony PS-LX300USB turntable but cannot play sound through the computer speakers. States to setup Playback USB Audio
CODEC which shows working and Recording it shows Microphone USB Audio CODEC which is working. How do I get sound???
Apr 07, 2012 | Sony PS-LX300USB Turntable
How do I connect a usb turntable to a Yamaha HTR 6230? Sony turntable PS-LX300USB preamp switch set to 'line'
hi,
Select the switch to line. Then connect the red and white RCA pins to the corresponding red and white sockets of MD/CD-R play input of Yamaha. Select the MD/CD-R by pressing the button on the remote. Then play the turntable.
OK
Oct 15, 2011 | Sony PS-LX300USB Turntable
Just received our Sony PS-LX300USB turntable, but cannot get the stylus to stay on. Any suggestions on how to install the stylus?
Hold the stylus at an angle, rear up/needle down. Put the rear of the stylus in first and then push the front of the stylus up and clip into place.
Which stylus number did you use?
D.
Nov 09, 2010 | Sony PS-LX300USB Turntable
PS-LX300USB Turntable: I have hooked up the sony turntable to laptop, but...
Have you though of using a pre-amp? You'll probably need to go turntable --> pre-amp --> soundcard input to get acceptable sound
May 11, 2010 | Sony PS-LX300USB Turntable
Is there a mac os x driver available anywhere for the sony ps-lx300usb turntable?
You do not need a driver for mac... just plug the usb cable into your mac... go to sound settings in system preferences and set USB to default audio input device... then install audicity... it is free and open source... play your record and hit record in audicity. done.
Feb 06, 2010 | Sony PS-LX300USB Turntable
I need to determine appropriate stylus replacement for the Sony PS-LX300USB Turntable
any stylus should work i think radio shack sells them for pretty cheap and I know for sure that best buy sells them for cheap thats where I got mine. Best though from what I can remember is diamond tip but very coastly.
Apr 05, 2009 | Sony PS-LX300USB Turntable
Sony PS-LX300USB Turntable Logo
44 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
