Having a problem connecting my wireless Laptop to my PCs wireless Router? Laptop will not connect but Tablets do with ease!!
Why does my wireless Router not let me connect my Laptop to my desktops wireless Router Group!!
    Sergeant:
  • 341 Answers
You need to give a bit more information as to which OS you are using, if you are using win 7 go to your main machine and click start, and select "control panel" check you are viewing by "category" (top right), then under the "network and Internet" click "choose homegroup and sharing options" near the bottom you will see "view or change the homegroup password", make a note of this exactly as it is caps included, then on the machine you want to include in the network do the same and look for "join a homegroup" and type in the password you got from your main machine. that should sort it. If you get ipv6 errors use google to find the fixit from Microsoft. hope tha helps a bit.
Posted on Nov 27, 2013
4 Suggested Answers
SOURCE: I just got a Zyxel
Try reseting the prestige, theres a reset button in the back, hold it down for 30seconds it will restore the zyxel to factory defaults and it should work instantly.
you can find the user manual from here
http://us.zyxel.com/web/product_family_detail.php?PC1indexflag=20040812093058&CategoryGroupNo=AC5783AE-9475-41AD-BDA5-0997187F44AA
just incase you need help in setting its settings.
Anything else?
Posted on Nov 15, 2008
chiploon
  • 32 Answers
SOURCE: Eee PC 900 has problem with wireless connection
Hi terryandy,
I am using the Eee PC from Taiwan also. It is running good.
Based on your scenario, have you tried changing another new router?
Your description of having "out of range" is highly probable due to router hardware failure.
Try replacing the router and update us again.
Thank you.
Posted on Jan 06, 2009
  • 130 Answers
SOURCE: Wireless issues with my Dell XPS/Dimension One desktop
Even if it's a new Dell, you may need to update either the drivers for the wireless card or the BIOS.
Also, verify which protocol your Dell is set to use (i.e. 802.11g, 802.11b, auto-select, etc.). Dell may have fixed to to a slower protocol for compatibility.
Posted on May 02, 2009
Only one of my laptops can access the wireless network. When trying to log on the others we enter the pass word and i say can not connect I have a Belkin G wireless router and a road runner cable ISP
Can you provide details of the other PCs Try the following
1) remove wireless profiles http://mgmcc.forumotion.net/networking-tutorials-f17/removing-an-existing-wireless-profile-t109.htm from your PCs and then try to reconnect 2) Log into the router and remove the wireless security and see if the PCs can now connect and if so - try adding security again
Mar 28, 2010 | Computers & Internet
#3 laptops having problems connecting to wireless at random times
check the configuration of your. try and configure it to be AP CLIENT. i think this would solve your problem.
Nov 23, 2009 | Computers & Internet
I have my epson stylus dx6050 upstairs in my house,and I have my laptop downstairs.I want to use the printer without having to connect to it upstairs.Wirelessly ?
Apple Airport wireless router allows a printer to be networked by plugging it into the router. The Airport will work with Windows PCs.
Jul 23, 2009 | Office Equipment & Supplies
How do I reset paswrd for DL524 router so my laptop can connect
- Press and hold the reset pinhole at the back of router for 10 seconds with a paper clip.
Mar 10, 2009 | D-Link AirPlus DI-524 Wireless Router
Wireless driver can not read my wireless router
If you're having trouble with a router, it most likely has nothing to do with your laptop at all. If there is a problem with your laptop's wireless adapter, you may be able to find updated wireless drivers through the laptop manufacturer.
Please keep in mind that a wireless router and wireless adapter are completely different. The router is external and relays the signal from your modem (the internet) to your connected PCs. The adapter is in your laptop and sends/receives information from wireless routers such as yours.
Mar 04, 2009 | 2wire HomePortal 1800HG Router...
Hi terryandy,
Thank you.
Jan 06, 2009 | HP Pavilion a305w (DM181AR) PC Desktop
Internet access problem with a Linksys 54g router
Try setting the default gateway on the laptop to the ip address of your ICS gateway machine. Some routers separate the wireless and LAN connections on different subnets.
Try comparing your laptops ip information with that of one of the working wired computers. You can do this by going to Start up to run and type cmd then click "ok"
At the black prompt screen type "ipconfig" without the "".
You want to compare the IP Address, Submet Mask, and Default Gateway.
If one has an ip of 192.168.1.* and the other has 192.168.0.* then the wireless and wired are on seperate networks.
If the subnet masks are something like 255.255.255.0 and 255.255.255.1 they are on seperate subnets. Both should be fixable by putting in the same default gateway.
For example if your ICS gateway is 192.168.1.1 then set that as the default gatway on the wireless laptop. This can be done by going to start >> Control Panel >> Network Connections then right click your wireless connection and goto properties then double click on the "Internet Protocol (tcp/ip)" option. This will list all of your ip information (if its static) if its dynamic (ip gotten from router) you can still click "Use the following DNS server address" and set preffered dns to the gateway ICS ip. Or click "Advanced" and click Add under Default Gateways and add the gateway ICS ip there.
Jun 20, 2008 | Computers & Internet
DLink DIR 625 Wireless Router
It is the wireless computer setup with the same network name?
Feb 08, 2008 | D-Link DIR-625 (790069292637) Wireless...
Wireless router blooking
You can block other users by enabling the MAC Filter and only accept connections from your PCs MAC numbers.  To determine the WiFi MAC numbers of your PC, click on Start, click on Run, type "ipconfig /all" on all your PCs. Look for the Wireless networking cards and their numbers which should be something like 00:A1:B2:C3:D4:E5. In the Web Configuration of the router, enable MAC Filter and enter those numbers in "Allow". Save and Exit. From thereon only the PCs with the MAC numbers entered would be allowed access to the Internet.
I personally find this preferable rather than WEP or WPA which causes slowdown in WiFi connections.
Hope this be of help/idea. Post back how things turned up or should you need additional information.
Good luck and kind regards.
Nov 01, 2007 | D-Link 802.11g Wireless Router WBR-1310...
Connections
YES> If you will install a router into your network, it will share the internet conenction among the two computers. Both wireless and wired. So the connection will be from
Modem ----> Router (wireless/wired capable)   ------> PCs (two Pcs both the desktop and the laptop
and you can also add up another PC if you want to.
Oct 13, 2007 | ASUS WIRELESS ROUTER |WL-520G - RT...
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
