Question about Packard Bell Computers & Internet
Problem charging screen keeps going light & dark , battery full then charging constantly.
  • 6 more comments
  • Tricia Martinez
    Tricia Martinez Nov 27, 2013
    The Laptop is only 1 month old, and is always plugged in whilst I am working on it.
  • max carson
    max carson Nov 27, 2013
    Open the Control Panel, select Power Options, select High Performance, open change plan settings, set to your preference, select dim to never. You didnt post the Make, Model of Laptop or the OS you are using.
  • max carson
    If that doesn't solve the issue, you may want to consider returing the Laptop. You shouldn't have ANY issues a new laptop. You purchased it new?
  • max carson
    If you use it with AC plugged it, remove the battery, it will last longer. Always shut down and unplug when not in use.
  • Tricia Martinez
    It is a new packard bell easynote TE11HC
  • Tricia Martinez
    Thank you for your help, I will try all the things you have suggested
  • max carson
    What is the Operating System? Windows 8 or 8.1?
  • Tricia Martinez
    Windows 8
  • Packard Bell Master
  • 7,627 Answers
On battery it goes light and dark? How about on AC? How old is the battery? It may need replacing.
Posted on Nov 27, 2013
Testimonial: "The laptop is only 1 month old and always plugged in whilst I am using it"
  • max carson
    You may find the Windows 8.1 upgrade more intuitive. Be that as it may, open the Control Panel in Windows 8 by moving the cursor to the bottom right of the monitor, select Settings, Control Panel, Power Options, Tick/ckeck High Performance, select Change Plan settings, set Turn off display to your preference, set Put computer to sleep to Never; select Change advanced power settings, scroll through the settings and set to your preference, set Dim 100% and sleep/hibernate to never. If you require further assistance respond to this post.
Why red charge light keeps blinking?
Is your battery a LiPo (Lithium?) If so ... These special batteries are charged by a computer circuit that holds the charge amperage constant and adjust upward the charging voltage until the required battery voltage is reached. At this time the charger hold a constant voltage and decreases the amperage as the battery capacity is "topped off". the charger circuit charges the entire battery at once but monitors each cell (cells are about 3.7 volts each) and controls the charge so that all the cells are ballanced.
When one of the cells that makes up the battery starts to go bad, the ballance circuitry prevents over charging the others, so one weak cell hold all the cells back from full charge and better charger circuits will signal you with an led or such that the battery is' going' bad.
May 07, 2014 | Radio Shack Accurian LMD-5108A Portable...
How do I check the battery is charging on my nv8 camera
While using the camera, you can see the battery logo on the screen.
When the logo is white, the battery is full, after a while 1/3 will be dark. little longer, 2/3 and when the battery is (almost) flat it is complete dark. Then you must stop shooting and recharge the battery.
On the end of the charging cable, the plug that goes into your camera, has an indication light.
As long as the battery iOS charged, the light will be red. When the battery is fully charged, the light will be green. But if it starts flashing, something is wrong with the battery. Or at least the charging went wrong.
When you are using the AC adopter, an orange led can come on on the cable, meaning the battery is discharged.
All to be found in the manual, page 15 and 16
Feb 25, 2014 | Samsung NV8 Digital Camera
I purchased a Nikon D3100 yesterday. I tried taking some pics today but I cannot view the pictures in LiveView. When I click the button all I can see (in LIveview) is a dark or balckened screen. HELP!
Hi dear mount11zion, are the battery full charged?,please verfy.Charge the battery about 2 hs..
If still remains dark without any information go to dealer asap.
Regards
Mar 13, 2011 | Nikon D3100 Digital Camera
My camera works fine for awhile, and then the screen goes dark, but you can still see some movement. Pictures turn our dark with blue tint. I've tried charging the battery, and battery appears to have a...
This sounds like a problem with the image sensor within the camera. I doubt camera charge will affect picture or LCD screen image quality. Such problems can occur with old camera and in most cases buying a new camera is indicated as repairs are expensive. Ask at the Casio website support.
Please rate Fixya Answers.
Feb 18, 2011 | Casio Cameras
Our new battery won't charge up fully, and is gradually going down 1% every few days. Now at 95%. Just like why we replaced the last batter.
a battery will not hold full charge when its not being used it will slowly lose charge over time keep your battery in a dark cool place if it is connected to your thinkpad it will gradually lose charge
hope this helps
Oct 03, 2010 | IBM Lenovo ThinkPad T60 ThinkPad T60P...
Magellan Roadmate 2200T -dark screen
its probably not charging...very common problem with this and many others.
make sure green light is on the car charger and let it plugged in for awhile, then hold the power button (up to ten seconds) until it starts..if that fails
the following magellan 2000,2200t,2500,3000,3100,3140,4000,4040,4050 and the 6000 are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port...
you can get it repaired, here
or buy the port here
if you need further help, just let me know.
Oct 09, 2009 | GPS
Charger makes my screen dark
GO into the control panel and check your power settings. You might have it set to use less power when plugged in.
Oct 03, 2009 | Compaq Presario Notebook
Battery charge
Dave you are correct. You should never over-charge anything like a Roomba, Cel Phone, etc. That will kill a bettery very quickly.
Jan 11, 2009 | Roomba Robotic Floor Bagless Vacuum
Need Help
Press the middle key and menu key at the same time until the apple screen comes on. This will reset your settings but usually when my iPod does something funky like that I just do that and it's fine. If that doesn't work, contact your local Apple store.
May 02, 2008 | Apple iPod nano
Computers & Internet Logo
57 people viewed this question
Top Packard Bell Computers & Internet Experts
Alun Cox
carey w mason
carey w mason
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
