Question about Dual Presidian DVD Recorder
Presidian remote code - Dual Presidian DVD Recorder
How do i get an rca universal remote to work on a presidian pdr 3222
You need to use the code search feature of the remote (refer to the user manual), if that fails then the remote will not work on that brand.
Nov 17, 2016 | RCA Televison & Video
Can I use a universal remote for the Presidian DVD/VCR Combo 16-3826?
The universal remote you choose must be able to produce the necessary Presidian code(s)
May 26, 2013 | Dual Televison & Video
Phillips universal remote codes for Presidian PDR-3222
Check these codes. 003/ 004/ 006/ 008/ 062/ 068/ 069/ 074/ 075/ 076/ 086/ 087/ 089/ 133/ 163/ 183/ 184/ 205/ 206/ 207/ 208/ 212/ 213 Check these links for more details
Feb 21, 2013 | Televison & Video
I can not program a presidian remote control
Download the user manual to your remote control. It will have details.
Jun 03, 2012 | Toshiba Televison & Video
How do you hook recorder up to tv and dvr cable box
Simple. Connect the composite output from the VCR to the composite input on the back of the Presidian. Then connect the coaxial output from the back of the DVR to the coaxial input on the back of the Presidian. Then connect the coaxial output from Presidian to the coaxial input on the back of the TV. Turn everything on and enjoy! :-)
Jan 05, 2011 | Dual Presidian DVD Recorder
I need a manual for a presidian pdr 3222. Can you e-mail one? Carl
download manual from>>
http://club.cdfreaks.com/f89/presidian-pdr-3222-manual-discrepancy-220252/
Jan 16, 2009 | Radio Shack 15-2142 Remote Control
DVD tray will not open
When a disk is stuck inside the player , try following the procedure below:
Unplug power cord.
Plug back power.
Turn on the unit and press repeatedly the eject button at the same time. If you successeed in ejecting the disk before the player starts reading TOC(disk initial track), then the disk will eject.
If that does not work, then there is an internal fault, in that case the unit must be taken apart to remove the disk.
Feb 25, 2008 | Dual Presidian DVD Recorder
i have a presidian dvd recorder and when i put in
a new blank dvd-r disc it only gets it prepared up to
21% and tthen it stops and opens
Nov 25, 2007 | Emerson EWD7001 DVD Player
Televison & Video Logo
49 people viewed this question
Top Dual Televison & Video Experts
Jonathon summesfield
Are you a Dual Televison and Video Expert? Answer questions, earn points and help others
