Question about Canon A3300 IS Digital Camera
On?Off switch failure - Canon A3300 IS Digital Camera
    Top Expert:
  • Canon Master
  • 6,702 Answers
Not sure the A3300 has two AA sized batteries, but if it had:
Sure your batteries are still tip top?
Try two new AA sized NiMH rechargeable batteries or if you have some new alkaline batteries, put them in. the alkaline batteries won't last long, but it it could hint if the camera is still working and worth buying new rechargeables.
AA manganese (Zinc-Carbon) batteries cannot be used with this camera.
But even if it has one battery, check the battery.
Read other parts about batteries, in other help text I wrote for other users.
Posted on Nov 27, 2013
Where is the multifunction switch on 2003 ford ranger located for the wiper and dash light
What seam's to be the problem ? Would hate for you to replace the switch an have it not fix the problem .
The wiper's not working ? There is a whole list of thing's that could be the problem . Same for the dash light's ?
Symptom Chart Condition Possible Sources Action
  • The wipers are inoperative
  • Central junction box (CJB) fuse:
    • 16 (30A)
  • Circuitry.
  • GEM.
  • Multifunction switch.
  • Wiper run/park relay.
  • Wiper HI/LO relay.
  • Wiper motor.
  • GO to Pinpoint Test A .
Hooking up a scan tool an checking for DTC'S - diagnostic trouble code's in the GEM module .
GEM Diagnostic Trouble Code (DTC) Index
GEM Diagnostic Trouble Code (DTC) Index DTC Description DTC Caused By Action B1431 Wiper Brake/Run Relay Circuit Failure GEM GO to Pinpoint Test A . B1432 Wiper Brake/Run Relay Circuit Short to Battery GEM GO to Pinpoint Test A . B1434 Wiper Hi/Lo Speed Relay Failure GEM GO to the Symptom Chart. B1436 Wiper Hi/Lo Speed Relay Coil Circuit Short to Battery GEM GO to Pinpoint Test C . B1438 Wiper Mode Select Switch Circuit Failure GEM GO to the Symptom Chart. B1441 Wiper Mode Select Switch Circuit Short to Ground GEM GO to the Symptom Chart. B1446 Wiper Park Sense Circuit Failure GEM GO to Pinpoint Test D . B1450 Wiper Wash/Delay Switch Circuit Failure GEM GO to the Symptom Chart. B1453 Wiper Wash/Delay Switch Circuit Short to Ground GEM GO to the Symptom Chart. B1458 Wiper/Washer Pump Motor Relay Circuit Failure GEM GO to Pinpoint Test E . B1460 Wiper/Washer Pump Motor Relay Circuit Short to Battery GEM GO to Pinpoint Test E . B1466 Wiper Hi/Low Speed Not Switching GEM GO to Pinpoint Test C . B1467 Wiper Hi/Low Speed Circuit Motor Short to Battery GEM GO to the Symptom Chart. B1473 Wiper Low Speed Circuit Motor Failure GEM GO to the Symptom Chart. B1476 Wiper High Speed Circuit Motor Failure GEM GO to the Symptom Chart. B1840 Wiper Front Power Circuit Failure Open/Short to Ground GEM GO to Pinpoint Test A . - All Other DTCs GEM REFER to Section 419-10.
The multifunction switch has nothing to do with the dash light's
Instrument Cluster and Panel Illumination The instrument cluster and panel lighting system is powered through the headlamp switch and the panel dimmer switch. The instrument cluster illumination is controlled by the output of the panel dimmer switch. The instrument panel lighting circuit provides illumination for the:
Oct 23, 2017 | Ford Ranger Cars & Trucks
Tip
Switching Off your TV in standby mode & power failure
When there is power failure, immediately switch off the switch supplying power to your TV. After restoration of power, there are incoming surges on the line which can damage your TV. It is also a good idea to switch off in standby mode. It consumes some energy & we may not know when there is power failure.<br /><br />sonsunny
on Jul 06, 2011 | Televison & Video
I have 87 celica ... brake lights failure, checked fuse, brake pedal switch, replaced globes. The equivalent camry model has a light failure censor.I can not find any lamp failure box on this car.
Check that the switch is functioning on and off, check the connection for corrosion/corroded wiring. Check the tail lights wiring for the same and ground wires for corrosion. Swap out the pedal switch with another one after you inspect all wiring and that the wiring harnesses and connections are in good shape.
Apr 20, 2016 | Cars & Trucks
My microwave has stop heating up food. What is the cause?
There are several things that can cause this:
1. Bad high power diode failure (most common and usually causes a loud humming sound when it fails initially then never heats again)
2. Bad capacitor (open or shorted)
3. Stuck Magnetron oscillator (Makes a loud humming sound when the Diode and capacitor are known to be good.) / Magnetorn failure
4. Door interlock safety switch failure. (You should hear 3 clicks on most microwaves as the door just opens or closes... if your microwave light does not come on when the door is opened you only have 2 micro-switches and only hear 2 switch clicks.
5, Main control board relay failure / main board failure.
Those are the most common reasons listed in order of usual failures. Each one of the above possible failures has a different troubleshooting procedure.
Thanks for choosing FixYa,
Kelly
Sep 21, 2011 | Heating & Cooling
Can't open the oven door with an F9 and beeping
Here's the info from the service manual
"Fault Code: F9
Likely Failure Condition/Cause:
1. Door motor failure / jammed. Latch
motor switch failure.
2. Control software failure, or component
failure (relay stuck).
3. Wiring Problem.
Suggested Corrective Action:
1. Press CLEAR key.
2. If CLEAR key does not eliminate problem, turn off power for
30 seconds, then turn on power.
3. Check wiring of Lock Motor, and Lock Switch A and Door
Switch circuits.
4. Unplug P4, apply power (L1) directly to the Lock Motor, if the
motor does not rotate, replace Lock Motor Assembly. Plug
P4.
5. Check Lock Switch A for proper operation (do they open and
close, check with ohmmeter). The Lock Motor may be
powered as in above step to open and close Lock Switch. If
the Lock Switch is defective, replace Motor Lock Assembly.
6. If all above steps fail to correct situation, replace control."
Feb 24, 2011 | Frigidaire GLEB27S7A Electric Single Oven
My 1000 watt inverter has stop from supplying AC power
Unless the set is checked into , it cannot be confirmed if the fault is due to :
Failure of the switching semiconductors- drivers- Mosfets
Failure of the transformer
Failure of the switching frequency generator-IC
Failure of the in voltage detect or relays.
Oct 11, 2010 | Statpower PORTAWATTZ 1000 Watt Power...
Repeated IOGear KVM switch failures
As a wild guess, it sounds like a static discharge MIGHT be affecting the switcher causing it to crash.
Try increasing your humidity to 40% and grounding yourself before touching the keyboard... This is the season for these static electricity problems... get nipped all the time and you MAY not even feel it to be enough to zap the switch.
Jan 11, 2010 | IOGear MiniView GCS62 2-port KVM Switch
I replaced pressure switch and the light is still blinking three times what is wrong
that means pressure switch failure,
with that particular failure you may want to check
you inducer blower, and your ducting between
usually when you get this failure , its more than likely your inducer is not creating enough flow to trigger the pressure sw.
rather than an actual failure of thepressure switch
read you amps at the inducer it should read around .6 running
Oct 17, 2009 | Goodman GMS90703BXA Heater
Frigidaire oven f9 code
Here's the info from the service manual:
"Fault Code: F9
3. Wiring Problem.
1. Press CLEAR key.
Switch circuits.
P4.
- www.fixyourboard.com
Jul 25, 2009 | Frigidaire FEB30S5D Electric Single Oven
Canon A3300 IS Digital Camera Logo
70 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
