Question about Electrolux Ovens
Frigidaire fccw3000fs5 This is the model number on a commercial washer in a senior living facility. It has a burned up switch in the gizmo that takes the coins. I can't seem to find this model number. Any ideas?
Where is the speed bake switch located on a Frigidaire oven
Hello friend, thank you for your post!
Based off the information you have provided you need to know the location of the speed bake switch inside of your Frigidaire oven. I would be happy to provide you with that information, if you can provide me with your model number. You can locate the model number on the serial tag and that can be found on the bottom drawer frame. Once I have that information I would be able to assist you further. -Matt
Dec 13, 2015 | Frigidaire Ovens
Where are the fuses located in a frigidare stove
Good Afternoon Friend, this is Z. Thank you for your post!
I understand you are seeking the fuses location in your Frigidaire range. May I please have your model number? You can typically locate the serial tag (which lists your model number) in the storage drawer, on the right side. Please describe what your appliance is doing so that I can assist you better in pinpointing the problem before you take this step. Thanks!
Jun 07, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire gas oven fg60t11w manual
Hello - I found the manual on the Frigidaire website. Here is the manufacturer link and hope you find all the information that you need. I recommend taking off the last letter of the model number so you can pull up the information.
http://b2b.frigidaire.com/support/manuals.asp?NewSearch=New+Search
Jan 09, 2013 | Frigidaire Ovens
Self clean instructions
Hello jeffreyandje - Do you have the exact model number so I can provide you instructions on how to use the self-clean mode? Meanwhile, the manual and operating instructions can be found on the manufacturer link. I will recommend taking off the last letter of the model number so you can pull up the information.
Dec 10, 2012 | Frigidaire FGB24S5A Gas Single Oven
Frigidaire convection oven - have no instructions, can't get it started -help please
Hello Charlotte Philp - I understand you want to instructions on how to operate/clean your unit. May you please provide me the model number so I can further assist you better in pinpointing you the information or you may visit the Frigidaire website that I found.
Nov 12, 2012 | Ovens
I have a frigidaire gas oven Model Number FGF366ECC. The oven does not get hot.
9 times out of 10 the oven ignitor is the problem see if the ignitor glows when you turn the oven on it should be a bright yellow glow and not a dingy orange glow if it does not glow at all the ignitor could be burned out
Nov 18, 2010 | Frigidaire Ovens
The terminal block that the power cord plugs into sparks
The part is called the terminal block and is part number 5304409888
It gets burned due to not being connected tight when the oven was installed or worked on last.
Replace the block and repair any burned wire ends. Make sure connections are tight and you will be good to go
May 07, 2010 | Frigidaire FEB27S5A Electric Single Oven
Oven will not light. it is a frigidaire model #
When the bake igniter becomes weak or burns out, your oven will not bake. The bake igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
If the bake igniter glows red and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve will not let the gas out into the oven burner. A weak igniter must be replaced.
A faulty igniter is probably the most common cause, however there are others:
  1. Defective thermostat
  2. Defective selector switch
  3. Defective gas safety valve
  4. Defective gas valve coils
Dec 17, 2009 | Frigidaire Ovens
I started my oven on ''clean'' -- how long should this take?
Whithout knowing the model number in general it takes several hours for the cleaning cycle. My oven takes approx. 4 hours to complete a good cleaning. On my own oven, you can set the timer for as long as you want. Do you have an owners manual? If not, you can find one here...........
http://www.frigidaire.com/support/manuals.asp
Mar 20, 2009 | Frigidaire 30 in. Electric Gallery Series...
Ovens Logo
Top Electrolux Ovens Experts
ashburton
Mack Baxter
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
