Question about IBM ThinkPad T43 Notebook
3 volume buttons on keyboard
Typically when using the 3 volume buttons on the keyboard; green lines appear on the screen indicating the volume.  The 3 buttons still work fine but I have these green lines do not appear...?  This happened completely randomly too.
  • 32 Answers
U may have a software problem & u may have to remove and REstore the drivers for the[keyboadr] button\volume control.
Did u get a RESTORE disk\CD for your t43 pc?
2nd) your keyboard maybe dirty and may need cleaning.
they sell a small vaccum cleaner with a small brush attached to the 'sucky' part.
If not use a " smoking Pipe cleaner " [looks like the ties that keep bread from coming out of the plastic bag] but with soft material around the entire length.soke with lighter fulid,Stick the "pipe cleaner" inbetween the keypads on the keyboard . make sure that u AIR FAN the keyboard  V E R Y   G O O D   AND MAKE SURE THAT THE power is off before u do this.
Posted on Oct 11, 2007
SOURCE:
How to adjust volume
You can increase Windows' default volume by clicking on the speaker icon in the Notification Area (it is located on the bottom-right of your screen) and then using the slider that appears.
Jan 14, 2018 | Computers & Internet
Will not factory reset using power button + volume up button. What do I do?
some devices need you to press power button + both volume up and down.
Apr 19, 2015 | Tablets & eReaders
How do i unlock my android phone if i dont know my gmail account
first turn the phone on then turn it off by selecting turn off phone then OK.
next hold both the volume up and down buttons and then push the on button but stay holding all 3 buttons till the phone turns on,
You'll see the droid dude appear on the screen, then it will show some smaller red and green text. you can let go of all 3 buttons now.
You will be using the volume up and down to scroll and the power button to select
You'll want to select master restet, this will clear all saved data and passwords back to factory defaults. this selected by pushing the power button.
next screen will show a list of items that will have 1 long line of text as compared to the others, scroll and select it. the phone will reboot and will be cleared.
Oct 29, 2014 | Cell Phones
Nabi jr has a green android laying on it's back with red exclamation make, want do anything. How do I fix it?
1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the red Motorola logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up).
4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons.
5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections.
6. Use the volume buttons to move up and down through selection in this menu.
7. Using the volume down button, scroll down to "Wipe data/factory reset"
8. Tap Power hard key to select option.
9. Scroll down to select "Yes, delete all user data".
10. Tap the power button to select. Wiping and formatting data will take a few minutes.
11. You will return back to the Android recovery screen menu.
12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet
Oct 27, 2014 | Tablets & eReaders
Pattern reset
Press - 'Volume Button up + Scroll button + Power button' all at the same time. As soon as the phone starts, release the 'Power Button' but continue to press the other two buttons until you see the green Android logo. Then release the other buttons and wait until lines of text appear on the screen. Scroll down (using volume key) to the text line "wipe data/factory reset". Once highlighted press scroll button once and wait until phone is formatted. When the lines of text appear again, choose the top one which says "Reboot phone". Then follow whatever instructions that come on screen. Remember you need to update your Gmail/Google account before you can access applications on "PlayStore".
Oct 21, 2013 | Samsung GT-S5300 Galaxy Pocket
Acer laptop switched on light up on switch but no screen display
A blacked-out screen doesn't necessarily indicate a broken monitor. If the computer has run out of charge or is in hibernation or sleep mode,
if the screen is too dark, or if the display cable has come disconnected from the motherboard, the screen may appear black or fail to turn on.
To fix a blacked-out laptop screen, troubleshoot the screen settings, check the LCD connector and see if the computer is awake and receiving power.
Touch the touchpad or move the external mouse to see if the computer is asleep or hibernating. If the computer fails to respond, press "Enter" on the keyboard.
Press the power button if the screen remains black. Confirm that the power indicator light, found at the front of the computer or above the keyboard, is glowing solid green or blue.
Confirm that the power adapter is plugged into the computer and into a wall outlet. Confirm that battery indicator light is glowing solid green or blue.
Hold down the "Fn" key. Press the up-arrow to see if the screen brightness increases. Some computers also use the "F6" or "F7" keys to increase screen brightness.
Hold down the power button for 10 seconds to turn off the laptop. Remove the AC adapter from the computer, close the screen, and then turn the PC over.
Slide the battery latch to eject the battery. Pull the battery out of its compartment.
Turn the computer back over, open the lid, and insert the edge of a flathead screwdriver or other flat, solid object beneath the bezel above the keyboard.
Wedge the edge of the keyboard bezel off of the top cover. Work your way along the edge of the keyboard bezel to loosen it. Pull the bezel off the laptop.
Trace the cable coming from the laptop screen to the connector found beneath the bezel. Reconnect the display cable to the motherboard if the cable has come loose from the connector.
Line up the tabs on the bezel with the slots along the top of the keyboard. Insert the right edge of the bezel into the gap above the keyboard, and then push the bezel back in place.
Turn the computer back on. If the laptop screen is still blacked out, connect an external monitor to the video port on the side of the PC to confirm that the video card isn't defective. If the external monitor works, the LCD screen could be broken.
If the monitor doesn't work, the motherboard or video card might need to be replaced.
hope this helps
Hope this helps
Nov 24, 2012 | MSI P45 Neo3-FR (MS-7514-010) Motherboard
I cannot see on screen the "dash line" when using volume keys
Volume is for hearing..... Just turn it all the way up and then back it down to what you want.
Feb 24, 2010 | Sony VAIO FW Series VGNFW275JH
Blinking red and green
How to connect the Bluetooth device to the computer loadTOCNode(3, 'moreinformation');
  1. Press and hold the Connect button on the bottom of the mouse. If your device has a battery indication light, it will blink and alternate between red and green to indicate that the device is discoverable.
  2. On the computer, open the Bluetooth software. The Bluetooth software is typically located in Control Panel. For more information about opening the Bluetooth software, see the "How to open the Bluetooth software" section.
  3. Click the Devices tab, and then click Add.
  4. Follow the instructions that appear on the screen.
Oct 28, 2009 | Microsoft Bluetooth 5000 Mouse
Green screen indicators
You need to reinstall the drivers from Lenovo (Formally IBM) for the spec:ial keys. The link at the bottom will take you to the Lenovo with a download with the follow description:
This package provides the utilities (sub packages) related to the special keys and buttons on the Notebook systems. These utilities enable full functionality of the special keys and buttons.
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-68000
Mar 14, 2009 | IBM ThinkPad T41 Notebook
LC-32SB24U LCD HDTV... Brand new, just out of box. Turn on, goes to language menu for about 1 second max,too fast to adjust, then screen goes black and little green led power light starts to blink. And...
Good Day, texxastam;
Do this:
1. UNPLUG TV
2. HOLD IN VOLUME DOWN &INPUT buttons on TV
3. Plug in the TV. (the TV will turn itself on).
4. A blue "K" should now be showing on the TV screen, release the buttons.
5. Press and release the VOLUME DOWN & CHANNEL DOWN buttons simultaneously on the TV. (A blue service menu will appear on the screen).
6. Using the remote, press the DOWN SELECT button once. (The highlighted line should read INDUSTRY INT (+CAUSE) OFF
7. Using the remote, press VOLUME UP once (OFF changes to ON).
8. Press ENTER. After a few seconds the screen turns green and shows - Industry INIT success - at the top of the screen.
9. Unplug the AC cord for 10 seconds then plug back in.
Good Luck, big IRISH.
PS; I did not make this up... it's from SHARP> again good luck...you may have to do this several times....too...get the timming down.
Aug 07, 2008 | Sharp Televison & Video
IBM ThinkPad T43 Notebook Logo
287 people viewed this question
Top IBM Computers & Internet Experts
Ekse
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
