We have recently purchased a new home and the UBHK-25J21SFA air handler makes a whistling little tune and then the heat comes on. Never fails to work but noise is annoying.
    Master:
  • 571 Answers
Make sure the air is balanced... air handlers are rated @ a certain design static pressure. The static rating is on the air handler tag. Have someone measure that static. Too often hvac installers don't know much about airflow & they will undersize ductwork. Then again it could just be a dirty coil.
Posted on Dec 07, 2013
  • 400 Answers
SOURCE: Home AC Air Handler is making Annoying clicking sounds randomly
It sounds like the problem is with the louvre swing motor which is either opening or closing the louvre but not stopping at the end. This is due to a faulty intergrated circiut (IC) programmable chip on the PC board. Only way to get around it is to replace the board.
Posted on Jun 10, 2009
james3751
  • 614 Answers
SOURCE: Air Handler leaking
First make sure unit is level. Drain pan may be dirty. On the rheem or Ruud unit the back of the pan gets stopped up. Ithas small holes that let the water by and they get stopped up. Now even though your drain is clean you may have a stopped up dain pan. Check this > These are problems you can take care of your self. Open up the top panel of your unit and you can look down on the drain pan. Check for dirt and stoppage near the outlet of the drain pan. You amy also have a cracked drain pan but I doubt it. Rus
Posted on Jul 14, 2009
  • 34 Answers
SOURCE: air handler fan appears to cause thumping noise
If it's a belt drive check the belt or the pulley could be worn. If it's direct drive check to se if something is in the fan wheel causing it to be out of balance.
Posted on Sep 11, 2009
SOURCE: air handler running but nothing coming out of
Shut unit off, remove door that would have the blower
located in it. Make sure that the blower motor has not seized up. Try to spin it with your hand.
If the unit starts up ,fires up and shuts down all the time, more than likely the blower motor is the problem
Posted on Feb 13, 2010
  • 420 Answers
SOURCE: whistle noise from the air handler
Check the filter and change if dirty or restricted. Make sure the blower access panel is secured. Make sure the cooling coil is clean on the top (outside) and on the bottom (inside).
Posted on May 27, 2010
New Rudd air handler making noise like a jet taking off. Whirring noise like a yhigh pitcher tuning fork. Multi speed motor that makes sound when slo down also. Not a duct problem new unit
Likely have a bad motor module. Fans do commonly sound a little different when starting but not when staging or when shutting off
May 19, 2017 | Heating & Cooling
Howto hook up th8320R1003 to heat pump
Byron, unless you have thoroughly familiarized yourself with the terminal designations on all three components, t-stat, air handler and heat pump you shouldn't attempt connection of the control. There are many variations of what will work and many more variations of what will NOT work.
No mention of outdoor sensors, so fine tuning of the electric heating stages to match the heat loss of your house (for most efficient operation) doesn't sound possible.
I know, this answer didn't help but there is no simple answer without having all the components in hand.
Mar 05, 2015 | Honeywell TH8320R1003 VisionPRO 8000 w/...
Difference in seer
i would check fan speed. it's probably on high. you might be moving more air with new system. a dirty evaporater on old unit woud have gave you a larger temperture drop.
Jun 16, 2014 | Goodman Heating & Cooling
HE heat pump won't talk with old air handler?
The fact is, the air handler supplies the voltage, blower, and electric heat. In order for the heat pump to work correctly, the wiring from the thermostat and heat pump need to be hooked up right to the air handler. The thermostat is what tells which component to come on. If the fan stops, but the condenser keeps going, you either have a faulty fan relay on the air handler, faulty thermostat or wiring, faulty wiring at the heat pump, or the contacts on the new unit are sticking, which is highly doubtful considering it is working now. I hope I have helped you understand this a little more. Good luck and don't let them push you around, get someone that knows what they are looking at.
Jul 18, 2012 | Goodman Heating & Cooling
What supply house sells haier air handlers in Atlanta ga
any 4 tonnes air handler will fit if you respect de gas for the unit if r22 than than r 22 air handler if r410 than r410 air handler you can put r410 air handler if r 22 not avalable but be sure that expension valve is compatible.
Dec 13, 2010 | Haier HC48C1VAR Central Air Conditioner
AC BLOWS WARM AIR
Cooling comes from what is done outside, if air handler is blowing and you are hearing a sound , may be in the duct work. If you feel warm air in cooling mode then the outside unit is the prob, need more info
Jul 25, 2009 | Heating & Cooling
Air Handler leaking
Jul 14, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
I recently bought a second hand grand voyager and occaisionally when the car is started a little symbol on the dash comes on and stays on. when it stays on and i come to the end of my journey, the car...
It means that the pre heat is in operation.It is a system that burns diesel to create heat to warm up engine quicker so that warm air comes into car sooner.The smoke is the exhaust gasses from the system and normally the whistleing and smoke stops when engine reaches running temperature or on short journeys approx 1 minute after engine is turned off
During summer when no heat is required and air con is on cooling it should not light even when starting from cold
hope this helps
May 18, 2009 | 2004 Chrysler Voyager
Wiring connection for a Ruud air handler & seeking its wiring diagram.
we are trying to install a goodman heat pump with a rheem air handler, the orange wire is hook up and the unit is still staying in the heat mood. does anyone have a wiring diagram for the air handler, their is some white wires in the air handler one with a purple strip and one with a black strip we need help
Jan 05, 2008 | Heating & Cooling
Heating & Cooling Logo
59 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
