Ecoflush b8106 constant running warter/tank has water in it.
  • 7,627 Answers
Wrong category.
Posted on Nov 28, 2013
I have a 36 gallon utilitech water tank hooked to a 1/2hp shallow well jet pump my pump runs constantly and I think it's because my tank has no water in it any help would be greatly appreciated
do you have a pressure tank or what, are you doing a gravity type deal with a pump to back it up, all pumps need pressure tank too. or your pump will constantly be on or your tank fill hole is not tight a pump is designed to trip the breaker if it wired direct, if it is not wired direct like wired to an extension cord, then who knows what it will do burn up I imagine if it is constantly going on without water pumping thru it need more details
Nov 17, 2015 | Jet Plumbing
Ecoflush Model B8104 toilet leaks from handle when flushing.
The manual and troubleshooting information is here. This is a plumbing feature I have never come across before.
https://wdiecoflush.files.wordpress.com/2013/05/b8104-service-manual.pdf
Amazon will sell you a replacement module;
http://www.amazon.com/EcoFlush-B8104-Pressure-Assisted-Control/dp/B00FHB8CAM
Jan 06, 2013 | Home
Peugot 106 got warter under rocker cover and white creamey gung going from the breather from the rocker to the air filtter been told its not head gasket
So it's not the head gasket? And you are still losing coolant? Well, okay, you will have to find how the water is getting into the rocker, and whether it's your lost coolant or plain water. IDK, possibly an intake manifold leak?
Even though the oil looks clean, the water and gunge in the rocker area will drain into the sump and contaminate the oil. If it's not the coolant, run the engine until it is hot, then give it a few minutes for the oil and water to drain down from top of the engine into the oil sump. Then change the oil and oil filter. Good luck, hope you find the problem.
Jul 07, 2012 | Peugeot 106 Cars & Trucks
Have Flotec pressure tank style fp7120-08 .Pressure gauge with nothing running goes up and down constantly. I've drained the water in house shut off power to holding tank znd there is no pressure
check the foot valve for leaks it at the end of the pipe in the well also if its newer than 30 years there is a cupler where the horizontal pipe meets the vertical on at the well head
Apr 24, 2012 | Plumbing
I have a EcoFlush B8100 and it does not want to flush even if i turn the knobs.
First check the filter in the supply line ( this is where the hose from your house hooks into the tank ( inside the tube( tank side) (youll need needle nose pliers) pull out screen and flush screen with water. if that doesn't work ....change the flush cartrage with a B8106 replacment( its the thing in the middle under the tank lid that has hoses comeing out). You have a ecoflush system that is covered for 10 years from the manufactorer. call 1-800391-9821...I have 301 of these in a hotel and im the chief engineer.. good luck... there easy to change
Jan 02, 2012 | Coffee Makers & Espresso Machines
Water level in bowl too hogh
Try bendig the float rod down so th resivor dont fill so much
Oct 19, 2009 | Elements Of Design EVWC320 EcoFlush Close...
Warter coming out of the motor on top when using on wet cleaning my carpet.
It is too full and/or the float is working.
Take the top off and set it away from the tank and run the motor for 10 minutes to dry out the vacuum motor. Check that the float isn't stuck and be sure to empty the tank regularly
Jul 03, 2009 | Numatic GVE370 Canister Wet/Dry Vacuum
Computers & Internet Logo
91 people viewed this question
David Payne
David Payne
