HP LaserJet 4600 Printer Logo
Posted on May 08, 2009
HP 4600 printer with error message 51.2M and loud noise when calibrating. Any solution?
Anonymous
Level 1:
  • Contributor 48 Answers
  • Posted on May 25, 2009
Anonymous
Contributor
Level 1:
Answers
48
Questions
0
Helped
25160
Points
93
Replace your magenta cartridge first. If the problem persist I strongly recommend a service tech. Error 51.2M is an magenta scanner(laser) error or DC controller.
1 Related Answer
Anonymous
  • 62 Answers
  • Posted on Jan 06, 2010
SOURCE: Noise from back center area, loud humming/fast
possible fuser issue..in the control panels.. you can go into diagnostics and actually run individual components.. give that a tray..
5120 code error
Any of these error codes (51.20 51.21 51.22 51.23) points to a failure with one of the laser scanner assemblies on the HP Color LaserJet 4610 an 4650 series. To solve these error codes, replace the corresponding laser scanner. Sometimes when the laser scanner fails you will also hear loud noises (often higher-pitched noises like screeching sounds); the noises can be another sign that the laser scanner needs replacing.
51.XY
PRINTER ERROR
For help press
alternates with
51.XY
PRINTER ERROR
A printer error has occurred.
X Description
1 beam detect error
2 laser error
Y Description
0 no color / black
1 Press to continue.
2 Turn the printer off and then on.
3 Reseat the connectors between the
laser/scanner and DC controller PCA
(J1009 - J1012).
4 Replace the defective laser/scanner
assembly. Calibrate the printer after
replacing the laser/scanner.
Making noise then displaying error asking to turn printer off
Just we cant judge reading the sound if we hear the sound we can say the fault, any how check fuser assembly seated properly or not? open side doors then observe where you are getting the sound..
My laserjet 4600 is showing 51.2k error can someone help to fix it
This error due to black scanner scanner no 1,take the help of expert or open with common sence first remove all the covers remove the formatter from back side then you will find the laser scanner ,you will find the two lever locks(arms)left & right.
pull out the no 1 scaner open the cover & clean the scanner internally with soft cotton & also clean the spendel motor phase. I think your problem will be resolved.Dont forget to calibrate the printer at least three times. thanks reply if resolved
Noise from back center area, loud humming/fast vibrating noise when doing calibration on my hp 4600 printer
1helpful
Need to have 4600 laser printer in just black ,because of broken
Sorry, my friend, there is no way to force it go B/W and override the error message.
1helpful
Hp 4600 error message 51.2c The message appears as soon as i insert the cyan cartridge. It was working properly but after printing 2000 pages (mostly blue color) there was noise and after that the message...
errors in the 51 range are laser scanner errors, it's saying either the laser is out or the scanner motor is not turning, or not turning fast enough. A good shop repair.
1helpful
HP Color LaserJet 4600 Keeps Calibrating
Replace the Jet direct card in it. I had a similar problem and replaced the Jet Direct card, all was good never had that problem again.
3answers
Insert C toner cartridge
Have you tried upadtaing the firmware?
k24674
Grand Canyon Tech
Grand Canyon Tech
