Question about Samsung DV328AE Electric Dryer
Drum won't turn
All control lights work, says drying when started but drum does not rotate. No noise. Belt is ok.
    Prodigy:
    An expert who has answered 500 questions.
  • 512 Answers
Most likely a broken belt
Posted on Dec 01, 2013
hunter19_46m
  • 7482 Answers
SOURCE: Dryer 6 months old. When in the drying cycle, a
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers are in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Please do not forget to rate me,
Thank You
Posted on May 24, 2010
SOURCE: the drum will not rotate
I did the same thing this morning... It was going to take a couple of days before repair technician was going to be able to repair it. So, I took the back cover off, and the idler pulley tensioner spring had fell off (that was the sound you heard... Then, I had to re-index the belt back to its groove on the drum. When I did that, I realized that the idler pulley had to be pulled all the way to the right and actually held the belt around the drive pulley. Hope that helps someone.
Posted on Oct 06, 2010
hunter19_46m
  • 7482 Answers
SOURCE: I was drying and heard a kind of banging pop noise
http://www.applianceaid.com/images/belt-config.JPG
If you hear a loud bang while your dryer is working, and you notice that the
drum has stopped turning, chances are the drivebelt has snapped.
Fortunately, replacing the belt is a fairly straightforward operation that
can be handled with a few simple tools.
First, unplug the dryer. Lift the lint-screen cover and pull out the lint screen
If your dryer has a lint screen on the inside of the door, skip this step.
Then remove the two screws that are under the cover. To unlatch the dryer top,
insert a thin-blade putty knife between the top and front panel,
about 2 1/2 in. in from one corner. Push in on the knife to release the locking
clip, lift the corner, then release the clip on the other side. Swing the top
up and lean it against the wall.
Next, move to the lower toe panel. Slip the putty knife between the lower panel
and the door panel at one side and twist the knife to release the clip
Then release the opposite clip and lift the panel up and off the hinge springs.
To support the dryer drum while the belt is being replaced, place scrap wood
under the front of the drum.
Loosen the two screws at each side of the bottom of the front panel.
Move to the top of the panel and remove the screws from the inside of the
cabinet that hold the front panel to the sides.
Slide the old belt off the drum.
Installing the belt
Lean the front panel out slightly and allow the drum to rest on the scrap wood
support. Drop the new dryer belt between the front panel and the drum, and
loop it over the drum. Then, lift the drum slightly while pushing the front
panel back into position.
Replace the screws at the top inside of the front panel, tighten the lower panel
screws and remove the scrap wood from under the drum. Check to make sure that
the rear drum seal fits properly over the lip on the rear bulkhead.
Position the new belt where the old belt was, with the grooved side of the belt
facing down.
Now, move to the motor area and pull out the old belt. To route the new belt
around the idler and drive pulley, first pass the entire belt, doubled up,
under the idler pulley. Then, push the idler belt toward the motor, slip the
belt around the motor pulley and release the tension on the idler pulley.
Open the dryer door and rotate the drum counterclockwise a few times to make
sure the belt is tracking properly. Lower the top and press down at each
corner to engage the clips. Lift the lint-screen cover, replace the two screws
and reinstall the lint screen. Finally, secure the lower front panel and turn
on the dryer for a test.
This is a FREE answer
Please RATE me
Posted on Jan 04, 2011
heatman101
  • 43501 Answers
SOURCE: dryer drum making noise but
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Posted on Aug 11, 2011
Macmarkus
  • 2605 Answers
SOURCE: dryer the drum won't turn when start
Hello Terry, welcome to FixYa.
I hope this works for you. I've answered similar questions many times with these LG dryers. When the belt "pops" off it usually is not broke, just off the idler pulley/tensioner.
I've attached a link to just such a question posted some time ago and my solution to that post is there.
http://www.fixya.com/support/t10216567-lg_2050w_dryer_wont
Let me know how you make out. if there is any problem with the link/solution...or if indeed this solves your problem. Good luck.
Regards,
Macmarkus :)
Posted on Nov 04, 2011
While cleaning the inside drum and turned the drum by hand. She heard a "loud noise" and will not turn. The control panel will come on andselect the mode, but when start is pushed nothing happens.
When you rotated to drum you caused to belt to pop off the pulley .it has a safety switch so it won't run if belt breaks . With unit unplugged remove top than control panel than front panel to access bottom to put belt back on just enough room for hands to fix inside
Mar 26, 2016 | Samsung DV218AEW Electric Dryer
Dryer makes clicking noise but won t start
The heating element is working or the belt is slipping.
the drum does NOT turn?
See manual. un plug and pop the front off to see if the belt is attached.. Try to rotate the drum by hand.
Aug 26, 2013 | LG Dryers
LG WM3431hs drum won't turn on dry cycle
Broken drive belt tho your model number is not for a dryer.
Feb 04, 2018 | LG WM3431 Front Load Washer / Dryer
My dryer makes a groaning noise on each rotation ... especially the load is very light. I manually turn the drum clock-wise and it seems to help for while. If we add more clothing to the load it also help....
The belt that rotes the drum has a belt tensioner that keeps the belt tightly fitted on the drum. You may have a dried up belt or a dried up bearing in the roller for the belt tensioner. An inspection can be done by removing the top and front panel of your dryer to see
May 08, 2010 | Dryers
Dryer is scraping as it turns. Is there a belt that is worn? Started doing it after 3rd load. Did the same last time we used it.
The dryer drum is suspended between the front panel and the back panel by extrusions that protrude into the front and rear of the drum. There are thick felt pads attached to the protrusions that support the drum and isolate the metal of the drum from the metal of the front and rear panel protrusions, allowing the drum to rotate freely. A large belt encircles the drum and a pulley attached to a motor mounted under the drum. A spring "thing" applies tension to the belt to prevent the belt from slipping. If the noise is a metal on metal sound, check the condition of the felts. Other causes of noise have been stretched belt slipping on drum, weak spring "thing" not keeping belt tight, motor bearings dry (oil) or worn (replace motor), and pulley on spring "thing needs lube (lube). Hope this helps.
Jan 12, 2010 | Maytag Dryers
Dryer drum stopped rotating, dryer blower continues to work.
The belt probably broke, and coincidentally happened while drying the shoes. The belt is easy to replace. Open the back and you'll probably see the belt laying on the bottom
Nov 10, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Dryer makes rumbling noise intermittently
It sounds like a faulty roller under the drum. Need to pop the top of the dryer, then remove the front -- you'll probably easily spot the faulty part.
May 06, 2009 | Maytag Dryers
Samsung DV328AE Electric Dryer Logo
75 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
