Question about Nokia E61 Smartphone
E 61 won't power up European model.will not even synch with laptop
E61 (european model) will not power up,won,t even synch with laptop.
  • tony1894 Apr 14, 2008
    Hi i have a nokia e61 and it wont charge or turn on. i barely used it yesterday and let it to charge overnight but nothing. what should i do?
Take the battery out for one minute and then re insert and try again. If this does not work check if your charger is working, and check the battery as it may be defective.
Posted on Mar 26, 2008
SOURCE:
HOW DO I CHANGE THE BATTERY
Any idea what model of headlamp you have?
http://blackdiamondequipment.com/en/faqs.html
Call: (800) 775-5552
Monday - Friday 8am-5pm, Mountain Time
Email: [email protected]
Fax: (801) 278-5533
If you're in Europe and have a question, you can reach us at Black Diamond Europe by sending an email to [email protected] You can also reach our European office via phone or letter:
Black Diamond Equipment AG
Christoph Merian Ring 7
4153 Reinach, Switzerland
p: +41/61 564 33 33
f: +41/61 564 33 34
Oct 22, 2014 | Black Diamond Sport & Outdoor - Others
Can I use Maxi-Cosi Mico seat in a familyfix base? Tks
Hi Renata
The Maxi-Cosi FamilyFix base is a European product designed for use with European model carseats.
The Mico is a USA model carseat and is not suitable for use in this base. You should use a Mico base if you are in USA / Use a European carseat if you are in Europe.
Mar 16, 2014 | Baby Gear
Genysis evo wont communicate with european or asian cars anymore.
You are in the wrong department this is pc laptop section you might have to post it in the motor car catagory to get the correct answer
Dec 19, 2012 | Computers & Internet
Washer will not let water in
What is the model number. I am dealing with a similar situation. Right now ththe solution is replacing the water inlet valve just inside the cabinet where the intake hose enters. My model is European.... only one hose for Cold water. I have a secondary problem.... bigger.... the actual owner attempted his own fix.... now the timing gears for water inlet are out of synch...!
Nov 20, 2012 | Washing Machines
Convert US 220V to European 220V
all you need to do is to purchase a power converter also known as transformer that converts the European 220v to110 v, so that American appliances will operate on European current.
Dec 01, 2011 | Miele W1926A Front Load Washer
The ideal 61-165 is listed to 240v. Is that L-L, or L-N as in European voltages?
In the United States Line to Line (L-L) for residential services is 240 volts at 60 Hertz (Hz) US Line to Neutral (L-N) is 120 volts. United Kingdom residential services L-N is 240 volts at 50 Hz. The Ideal 61-165 is intended to be used in the US.
Apr 30, 2011 | Ideal 61-165 Arcfault 165
Can I plug my American bought triton in European standard electricity Korg 61 key Triton
Only if it has a switch that changes over to 220. I beleave, if not ten you will have to get a power inverter for the power difference and plugs for the different styles that they have over in europe. I hope this helps.
Aug 15, 2009 | Music
RAdio skips two numbers when tuning
You have a US tuner not a European one. Only European tuners can change the even numbers. USA uses the odds. As far as I know, the US models aren't capable of tuning to the evens.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 22, 2009 | JVC KD-G310 CD Player
Nokia E61 Smartphone Logo
48 people viewed this question
Top Nokia Computers & Internet Experts
Anthony Ward
Anthony Ward
k24674
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
