Question about Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer
My brother CIP-J140W is only printing in cyan. I had accidentally put the cyan cartridge in the black cartridge spcae. Despite changing them around, cleanre the head etc, it is still only printing in cyan. Please help! Thank you.
    Top Expert:
  • Brother Master
  • 6,702 Answers
Oops, You really have to print, selected black, till all Cyan ink is gone. This could take a while. Cleaning the head, won't solve anything.
If you really want to clean the ink out of the head and everything, you need special cleaning fluid. Refill shops do have this fluid. You should bring some cleaning fluid in the tube under the black cartridge, in the tube where the ink is going in. If you have a syringe you could try to gently press some fluid through the tube. Not to strong. could damage the head.
After placing back the black cartridge, select clean the head and let the printer do some black and withe print jobs, till the cyan is gone.
Posted on Nov 27, 2013
Testimonial: "Hi Harrie Thanks that really worked! What a relief!"
  • Harrie Nov 28, 2013
    Hello Louise, my pleasure. I'm glad it worked. Don't think you are the first this happened to.
Mix-it-up
  • 832 Answers
SOURCE: Only printing black and cyan
If you have used third party carts before you can't repair this problem due to the fact that the filter inside the printhead is clogged with particles. There is no chance to clean the filter. Sorry. Do use only dye ink. Pigmented ink is the printhead killer for brother printers!
Posted on Sep 07, 2007
Mix-it-up
  • 832 Answers
SOURCE: Brother Printer Cannot Print in Black
This could be because of several probs: 1. The ink cart is not original and wont let the ink flow, because the valve is not open. 2. There might be air bubbles within the capillaries. 3. The ink is not genuine ink and has pigments in it. Solution: see here, too: http://welcome.solutions.brother.com/bsc/public/us/us/en/faq/faq_top.htm?reg=us&c=us&lang=en&prod=dcp110c_us Insert another ink cart. Use, if possible, the genuine ink cart from brother. Do the cleaning cycle twice. This will extract the air bubbles out of the caps after the second time. If you dont have any success the printhead is clogged and cant be cleaned anymore!
Posted on Sep 17, 2007
komguy
  • 2306 Answers
SOURCE: Brother MFC-6490CW is not printing black
If it's under warranty you're in luck, you need a new printhead,LK3197001, around $80.00. I just replaced one yesterday in the shop for the same problem. I would call Brother customer service and see if they'll help cover the cost.
1-800-276-7746
Posted on Sep 04, 2009
Testimonial: "Thanks, 'komguy' :) !! That's helpful. I'll get hold of them ASAP! Cheers!"
  • 265 Answers
SOURCE: How to clean the print head - Brother MFC-685CW Inkjet Printer?
Replace the printhead !
Posted on Dec 11, 2009
  • 164 Answers
SOURCE: My brother printer dcp-165C can't print black
Routine maintenance and keeping full ink tanks will prevent this problem, however if you have the problem you can resolve it by doing the following:
1. Clean your print head using denatured alcohol solvent which can be purchased from most hardware stores. If unavailable, use 91% Alcohol (isopropyl alcohol (first aid antiseptic) which is available for less than a dollar at most Walmart pharmacy departments.
*Warning: You may want to use a pair of latex exam gloves as this is a messy process and can stain your fingers.
Time necessary 45-50 minutes
Supplies needed:
Isopropyl Alcohol or denatured alcohol
paper towels
latex gloves
sink, bowls and or basin
can of compressed air
very small screw driver
tablespoon or baby bulb type syringe
warm water
PROCEDURE:
1. Lift print head from printer. It pulls out easily because it is held in with the same down lever that holds the cartridge in place.
2. Put two layers of paper towels in the bottom of a dish to protect sensitive sprayer heads.
3.Put enough solvent in dish to cover the screens on which the cartridges sit when in use.
4. Take the two small screws out that hold the white ceramic piece
5. Gently, pry the ceramic piece back and away , to reveal the underside (No need to pull away the glued points on the sides.)
6. Gently, move head up and down to slosh solvent around it the best as you can. Use a table spoon or syringe to pour solvent over all orifices in the print head, turning it upside down and then back a few times.
7. Use canned air with a plastic straw to blow into and through all orifices, alternately sloshing/swishing and pouring solvent over head (be careful not to touch any of the holes, screens, or sprayer heads with anything)
8. Empty dirty solvent from bowl and replace with paper towels and clean solvent. Soak for approx 10 minutes. Rinse again with clean solvent poured directly on all parts, letting solvent overrun and fall into dish or basin.
9. Gently shake the solvent off the head, take it outside and spray with compressed air into all orifices to clear out and help evaporate any remaining solvent. Let sit on a clean paper towel for approx 20 minutes. (There may be a little ink bleeding out of the head, but once it dries completely it does not present any problems.
10. Reinstall head, cartridges and it will print like a new printer.
SUGGESTION: For many years of problem free printing, keep a double set of ink cartridges, one set full at all times. Whenever a cartridge runs out of ink, replace it IMMEDIATELY, with a new one or a refilled one. This gives the print head no chance to dry out and create clogged heads. Routine maintenance of cleaning the heads every 24 months does wonders for keeping your printer in new condition.
Hope this helps. .
Posted on Feb 08, 2010
I have a brother J140 W i followed your instructions to clear purge full ink box and it worked,I thought great,But now when i print the black ink goes into the yellow when I do a test I have 2 black i cyan...
Did you actually change any parts or just reset a warning? If you were getting a full error, chances are the purge system was full and needs to be changed. Likely what the problem you are having is that ink from the purge system is backing up and polluting your print heads.
Jan 04, 2015 | Brother DCP-J140w Wireless Compact Inkjet...
Hello, I have a Brother DCP-J140W printer and the
You can still print in black using the 3 colors. See the printer configuration. After a while it will clear up.
Sep 28, 2013 | Brother DCP-J140W
My HPLJ3500 Color Printer wont print black even tho we just put in a new cartridge. Prints magenta, cyan, yellow, but no black. HELP!
Run the PQ troubleshooting diagnostic.
See if the black is printing.
If not, run the Disable Cartridge check. This will allow you print with only one cartridge in the printer. Take out all the cartridges. Put the black in another slot and put the cyan in the black slot(the top). Print the config page. If the black is printing, is the cyan printing. If black isn't printing the cartridge is bad. If black is printing and cyan isn't something is wrong with the printer. If they are both printing put them back in the correct locations along with the other two colors. It isn't the printer.
Jan 11, 2011 | HP Color Laserjet 3550 Printer
Printer will not print dut to other color cartige. being empty.
The color cartridges print text that appears black by mixing the three primary colors (cyan, magenta, and yellow) to make composite black. To achieve a realistic black, large quantities of colored ink are used. Because black cartridges use much less ink to create a similar shade of black, they print more pages in black than the color cartridge.
If the color cartridges on the printer are next to empty, you will not be able to get perfect prints at all.
Please have the cartridges replaced to do the printing jobs again.
Sep 10, 2009 | Brother Multi-Function Center MFC-240C...
Will not print text in documents, only headings.
When you go to print on your settings select print in black only. Did you buy Brother ink? Having old cartridges refilled or buying generic can pose a problem. I remember correctly brothers have a chip on the ink cartridge? I have gone through so many printers and its really not worth going any further, seems as though you have put sometime and effort in to this 100$ printer. Take 100$ & buy a kodak easy share all in one the ink is 15$ brand new.
Jul 24, 2009 | Brother MFC 490cw Color Inkjet...
Added new cyan ink cartridge and won't print the blue colors
Nope, It's just going to take lots of pages before it comes back...maybe the whole cartridge
Mar 03, 2009 | Brother MFC 420CN All-In-One InkJet...
Can't print
Ok, if your brother has four cartridges then I'll assume you have black ink available. There should be a printer setting to print in black only, especially if your trying to print a colored document. If your brother only has three cartridges then cyan is necessary to form black; you will have to buy a replacement cartridge.
Nov 27, 2008 | Brother MFC 210C All-In-One InkJet Printer
Red Menace
Try unplugging the printer for about ten to fifteen seconds; then replug.
This may clear the printer's memory about the low magenta. I had a similar thing with yellow, and when I replugged it stopped complaining about the yellow and told me that my cyan was out, and magenta low. I replaced the cyan, and voila! I can print!
Sep 05, 2008 | Brother MFC 420CN All-In-One InkJet...
Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer Logo
96 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
