Question about Estate EGD4400SQ Gas Dryer
Dryer runs does not turn off and does not heat
    Sergeant:
  • 479 Answers
If the dryer is set to automatic cycle and it does not heat it will not advance be sure to check power for 220v , could be broken element , thermostats, timer , motor switch
Posted on Dec 01, 2013
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
Gas dryer initially heats then heating stops
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 15, 2010 | Whirlpool LGB6000KQ Gas Dryer
The timer doesn't work. The dryer just runs until
is the heat working?when the dryer heats up and then the heat will shut off then the timer advances,when the heat turns back on the timer stops,heat shuts off the timer will move again,if the heat is working you could have a bad timer
Mar 12, 2010 | Frigidaire GLER341A Electric Dryer
Whirlpool dryer WED5530SQ0, heats but does not run
So,. basically your drum doesnt turn. SO your getting heat still even though the drum isnt turning. Is this right? Sounds strange??? Do you hear any humming noise when you push the start button? I need to know a little more about the problem because im kinda confused as how you decribed the problem. Iv never seen a dryer heat but the drum not spinning. especially your model dryer. Its electric heat right? because if the drum doesnt spin, maybe your motor is bad. and if your motor is bad, then your heating element wont heat up because the centrifical switch in the motor is not switching to complete the circuit to the heating element. So this is why im confused when you said" Dryer heats when knob turned but when "push button" pressed, drum doesnt run." Because your belt wraps around the motor pully and the motor is what makes the drum turn. Like i said, i never seen this model dryer heat with out the motor operating. So if you can give me some more info, ill do my best to help you out....Thanks!!!!
Jul 30, 2009 | Whirlpool WED5500S Electric Dryer
Dryer doesn't turn off or heat
Is this Kenmore dryer gass or electric?
I need this information to beter assist you.
thank you
May 18, 2009 | Kenmore Dryers
Dryer continues to run but heat fuse blows when turned on.
You would need to check the amp draw to determine if it is the dryer or your house circuit. A dryer typically draws a steady 24 amps when it is heating.
Apr 07, 2009 | Whirlpool GEW9250 Electric Dryer
My dryer runs but there is no heat to dry the clothes.
any heat at all? clogged vent pipe number one issue(if some heat is present) check 220 rec for 220! could be bad breaker motor will turn on 110 but needs 220 for heat....then go for element
Mar 13, 2009 | Dryers
Dryer runs and heats but drum won't turn.
you need to replace the belt on your dryer
Dec 26, 2008 | Whirlpool LGR8648 Gas Dryer
Will not run
check your recepticle .most dryers will run on half power but willnot heat. if your recepticle is bad ` it may have lost all power.
Feb 18, 2008 | Whirlpool LER4634J Electric Dryer
Estate EGD4400SQ Gas Dryer Logo
54 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
