Question about Crane Evaporative Cool Mist Drop Shape Humidifier - Pink
Green light on. fan not blowing mist
Did all cleaning ect. green light comes on but fan does not come on or blow mist
My humidifier works but wont blow mist?
If it is an ultrasonic humidifier, it has a little disk about the size of a dime at the bottom of the well where the mist comes out. That metal disk gathers white scale on it, Clean that off. The best way I have found is with a Waterpik turned all the way up.
Feb 07, 2017 | Humidifiers
Have ultrasonic cool mist humidifier.....it is blowing cool air ...but no mist...what could the problem be?
It has a little disk about the size of a dime at the bottom of the well where the mist comes out. That metal disk gathers white scale on it, Clean that off. The best way I have found is with a Waterpik turned all the way up.
Feb 06, 2017 | Humidifiers
Cleaned with vinegar at end of season but now not blowing mist. It seems to be making some inside it's just not blowing it out.
What kind of water are you using? Sometime all you need to do is add a little salt to the water, like 1-2 tsp.
Oct 24, 2013 | E-Ware EW-5K128 Ultrasonic Noiseless...
Germ guardian h3000 not blowing air
I have a Vicks, similar, and it recomends a little table salt in the water to create a mist, read your manual and see if this helps. Don't go overboard on the salt, or you'll have old faithful instead of a mist!
Apr 07, 2013 | Germ Guardian H3000 Humidifier
Won't blow mist out
I have a similar problem. I found a crack in the tank. I am trying to find out if it is cheaper to replace the tank, or just buy another one. I have tried other types and like this one the best.
Dec 22, 2012 | Walgreens Cool Mist Humidifier, 1 ea
Wont blow out mist
it has a quiet operation when you got it brand new did it put out mist
Nov 02, 2012 | Vicks Cool Mist V400 Humidifier
Venta Sonic VS205 Humidifier turns and has the green light, makes a buzzing sound, but no mist is coming out.
If you see mist in unit and not coming out fan motor in base of unit bad. Four screws in base and fan unplugs
Aug 20, 2011 | Venta Airwasher VS 207 3.7 Gallon...
Blowing air, no mist and there is no diference between on full blast or on low
From the troubleshooting section of the manual (http://www.crane-usa.com/manuals/HumidifierManual2008.pdf):
The power light is green but there is no mist being emitted: ? Check that there is water in the tank. ? Check for possible lime deposits on the water level sensor or the nebulizer (see page 8 and 9). ? Make sure that nothing blocks the vapor output slots. ? Check that the fan vent on bottom of humidifier is not blocked. ? Empty the humidifier and rinse the water basin with cool tap water and allow to dry for 15 to 30 min.
Jan 08, 2011 | Crane Frog EE-3191 1 Gallon Humidifier
Hello, I have the vicks v420 humidifier. The green light on top is on but nothing comes on. Help!
http://www.vicks.com/products/vaporizers
If you are having problems getting the vaporizer to work, just add salt to the water (seems so crazy simple but it works!). Also, make sure the removable column is tightly fixed inside; give it a few minutes and it should start to blow.
Depending upon your model, start at the above link and read the instructions. Just click "details" under the model in question.
Dec 29, 2009 | Vicks Humidifiers
Working, but not blowing mist.
I think I found the problem.
unplug humidifer, remove top tank, empty all water out of base. dry off.
turn unit upside down.
unscrew five visible screws.
use a screw driver to pull off the black foam foot pads. you will find more screws there.
pull off the base.
look next to the fan, you will see a metal "tower" going up into the reservoir. Is it dirty such as white chalky substance on it? Clean it with cotton swabs. Clean the fan while your at it if needed.
You will see a small gray box with two metal tabs twisted. Untwist them and pull off the top.
On that metal "tower" you will see a small black chip connected to the circuit board where you just removed the metal top. Does black chip have black marks on the circuit board? Mine does. I suspect the "tower" which draws heat from this black chip was no longer able to cool because of the white chalk buildup on the tower, furthermore, the chip became too hot and caused the black chip to overheat (again black marks on the circuit board).
The chip has on it "FTR 02N" and a "54F" at the bottom. I tried doing some basic searching on internet to see if it could be replaced, but didn't find anything.
For those who don't have this problem yet, just keep that metal cooling tower clean.
Dec 08, 2007 | Sunbeam 701 Humidifier
Crane Evaporative Cool Mist Drop Shape Humidifier - Pink Logo
475 people viewed this question
Top Crane Humidifiers Experts
Danny Kuhlmann
Andrew Taylor
Andrew Taylor
Are you a Crane Humidifier Expert? Answer questions, earn points and help others
