Question about TP-LINK TL-MR3420 Wireless Router
HOW TO SET UP TL-MR3420 USING GLOBE POSTPAID CONNECTION
    Habit-Forming:
  • 33 Answers
Follow these steps:
1- connect your pc with router
2- open browser.
3- type the ip address of router : 192.168.0.1
4- press on quick setup.
5- choose the first option 3g/4g
6- press next
7-set location , AT&A , username , password
8- press next
9- finish
make sure your wireless usb was connected with router in the area range of wireless of your isp .
Posted on Feb 10, 2014
2 Suggested Answers
  • 1768 Answers
SOURCE: Must be reset router tl-mr3420
1.You will possibly need to configure the router for what is called "port Triggering"
2. from what I read is that there is no IP via the Hikvision external there fore requiring a new IP each time for connectivity.
Instruction set from the manual states:
To add a new rule, follow the steps below.
1. Click the Add New... button, the next screen will pop-up as shown in Figure 4-40.
2. Select a common application from the Common Applications drop-down list, then the
Trigger Port field and the Incoming Ports field will be automatically filled. If the Common
Applications do not have the application you need, enter the Trigger Port and the
Incoming Ports manually.
3. Select the protocol used for Trigger Port from the Trigger Protocol drop-down list, either
TCP, UDP, or All.
4. Select the protocol used for Incoming Ports from the Incoming Protocol drop-down list,
either TCP or UDP, or All.
5. Select Enable in Status field.
6. Click the Save button to save the new rule.
check the "Local management" in the router
you must allow certain devices to obtain an IP via either MAC address or IP address.
Posted on Sep 12, 2011
Di ako makapagfb using myphone Q19i...paano po b dapat gawin para makakonekta ako gamit ko ung cp n un? ty.
APN Settings for Globe, Smart, Sun, WeRoam Cellular
The following settings are applicable to Smart, Globe and Sun Cellular for their APN settings (Access Point Name). The settings should work with majority of smartphones in the market.
Postpaid APN: internet.globe.com.ph
Prepaid APN: http.globe.com.ph
APN Settings for Smart Bro
Postpaid APN: smartbro
Prepaid APN: smartbro
APN Settings for Smart Buddy, Smart Gold
APN: internet
APN Settings for Sun Cellular
Prepaid
APN (static): minternet
Authentication: PAP
IP address: dynamic
Postpaid
APN (static): fbband or minternet
Authentication: PAP
IP address: dynamic
APN Settings for PLDT WeRoam
Postpaid: WEROAMPLANor internet
Note: If you’re using a variety of postpaid or prepaid SIM cards in one dongle, make sure to create a Setting Profile for each SIM card so it’s easier to set the APN when switching SIM cards.
Leave all other settings blank or as is.
Mar 05, 2014 | Computers & Internet
Bsnl adsl modem configure with TL-MR3420 router!
make bsnl adsl router as abridge router , then connect tp link router from wan port with any one of lan port of adsl router , then configure tplink router connection depending how you get internet from your ISP
Jan 30, 2014 | TP-LINK TL-MR3420 Wireless Router
Setting nat type
you must reset the router disconnect the power cord by 40 seconds, after that with smal pencil eraser, touch the small switch for hard reset, and try again.
However you must sure the Internet has a good signal.
Run the utility from open network connection, and select the network troubleshooter. and fix it.
God bless you
Jul 29, 2013 | TP-LINK TL-MR3420 Wireless Router
Bsnl broadband configure
the router without any Modem WITH internet is useful. You must have Moden with BSNL broaband. Remember the router the only function is amply the signal for internet for use in wireless.
God bless you
Jul 11, 2013 | TP-LINK TL-MR3420 Wireless Router
TL-MR3420
insert your 3G Card adapter to the USB port and thenuse your PC come to http://192.168.1.1 log in to the admin with name admin, password admin .
Open the operating status, it will show being identified, waiting about 20s it will done. else if it can't be recognized. You need to set the BIN file by you self, you can download the file from www.tp-link.com
Then set it step by step as it show
May 02, 2013 | ASI Tp-link Tl-mr3420 300mbps Wireless N...
TP-LINK TL-MR3020 need DUC or not i connect only hikvision dvr
Remotely would imply a different building or location. What exactly are you trying to accomplish? Do you mean hook it up in one room and record and watch shows in another? Or over the internet? Give more info.
Feb 02, 2013 | TP-LINK TL-MR3420 Wireless Router
I csl modem can not be used due to wrong settings
Push and hold the reset button for 30 seconds or so, release. A user manual can be found here: http://www.tp-link.com/us/products/details/?model=TL-MR3420#down
Jan 24, 2013 | TP-LINK TL-MR3420 Wireless Router
How to set up..please help
Default IP adress to enter the configurationis http://192.168.1.1
user: admin
pass: admin
Then run the QUICK SETUP (installation wizard)
For more details get the User guide
Jul 29, 2012 | TP-LINK TL-MR3420 Wireless Router
Must be reset router tl-mr3420 tplink time to time after connecting DVR Hikvision externally via NO_IP. the router has DDNS enabled and open port-forwaring
TCP, UDP, or All.
Sep 12, 2011 | TP-LINK TL-MR3420 Wireless Router
TP-LINK TL-MR3420 Wireless Router Logo
94 people viewed this question
Top TP-LINK Computers & Internet Experts
Martin Murray
John Anderson
John Anderson
Are you a TP-LINK Computer and Internet Expert? Answer questions, earn points and help others
